04-05-2007, 12:02 AM | #1 |
PROJECT 7DEUCE
Re: Porterbuilt Blazer Project
Looks like she has a little rust. Why did you pull the outter skins off? Is it easier to work the inner structure or do you have som other plans?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-05-2007, 12:07 AM | #2 |
I will be replacing the quarters with SWB bed-sides... I did a lot of thinking (I know... look out!) and figured this would be the best way to get the new panels to line up best. There are a couple spots on the inner panels that need to be replaced as well. One other advantage is that I will be able to shave and metal finish the 'new' replacement quarter skins to near perfection before they go back on, as well as undercoat the inside of both panels, and it will be easier to do the new wheel tubs this way, and... and... and...
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-05-2007, 12:14 AM | #3 |
GET OUT OF MY HEAD! And leave those thoughts were you found them! I just got a very nice set of blazer sides for mine and I will be doing the exact same thing.
Looking good as always! You are so right about it being much easier to work those things off the rig. It almost makes it fun Kevin LFD Inc. Last edited by Rokcrln; 04-05-2007 at 12:15 AM. |
04-05-2007, 10:35 AM | #4 |
hey Kevin,those Blazer bed sides look like the one's form Fairfield. i was looking at the windsheild frame but it had real heavy surface rust ,so i can only imagine what was going on in the inside of that thing. Tony
04-05-2007, 07:24 PM | #5 | |
Kevin LFD Inc. |
