Old 04-19-2007, 10:31 AM   #1
onedayjake
Getting closer!
Just a couple of pics but I still have a ways to go.
1947 1/2 ton, 5.3, 4L60E, 10 bolt
1974 Jimmy, 4 inch lift, 35" Thornbirds sold
onedayjake is offline   Reply With Quote
Old 04-19-2007, 11:12 AM   #2
stevehsd
stevehsd's Avatar
Re: Getting closer!
Nice truck!
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd
77 FLH
stevehsd is offline   Reply With Quote
Old 04-19-2007, 01:23 PM   #3
5Mike7
Re: Getting closer!
Great stance on the truck, a nicely tucked front bumper would top (er front) it off well.
55-9 stuff that need a new home http://67-72chevytrucks.com/vboard/s...d.php?t=226133
5Mike7 is offline   Reply With Quote
Old 04-19-2007, 01:49 PM   #4
onedayjake
Re: Getting closer!
Thanks guys. I have a front roll pan to put on but it is fiberglass and it doesn't fit too well. If I can't get to work I will try your tucked bumper idea. I never thought of that!
Old 04-19-2007, 04:36 PM   #5
Daniel U
Daniel U's Avatar
Re: Getting closer!
I like your wheels/stance. I know Wheel Vintiques carries them. What size are yours? Did you tub the rear? Thanks, Daniel U
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 04-19-2007, 10:13 PM   #6
onedayjake
Re: Getting closer!
Yes they are Wheel Vintiques 15X7", I can't remember the backspacing. The tire size is 235/60r15 all the way around. I didn't realize how little room there is in the rear for a tire without tubbing it which I did not do. I might have to consider mini tubbing it to get a bigger tire under it. I don't want to alter the frame but my 454 isn't going to be easy on the 235's!
Old 04-20-2007, 07:38 AM   #7
bondobob
bondobob's Avatar
Re: Getting closer!
Notice, the houses all look similar but I'll bet no one has a pick up like yours! Nice job.
bondobob is offline   Reply With Quote
Old 04-20-2007, 01:05 PM   #8
Daniel U
Daniel U's Avatar
Re: Getting closer!
Any chance you have time to take a shot from the rear(down low)?
Like this shot.
Old 04-20-2007, 04:03 PM   #9
onedayjake
Re: Getting closer!
No but I will try to take one and post it tonight.
Old 04-21-2007, 12:32 AM   #10
solidaxel
solidaxel's Avatar
Re: Getting closer!
LOOKS FINISHED TO ME !!!!!!!!!!
You mean you have way to go to the gas station !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-23-2007, 12:23 PM   #11
Daniel U
Daniel U's Avatar
Re: Getting closer!
Are those wheels as big as will fit in the rear? What rear end are you using? Thanks for the pics. Daniel U
Old 04-23-2007, 05:41 PM   #12
onedayjake
Re: Getting closer!
It's pretty tight back there, maybe a 1/2" to 3/4" on the inside by the box side and 1" to 2" at the fender. I wish someone made widened steel fenders for the rear. I might end up mini tubbing it to run a wider tire and just cut out the box side and cut rear fenders for the tubs inside the box. As for the rearend it's a 8.5" 10 bolt out of a 72 Nova with the perches cut off and the perches on it now are from the RB kit I got quite a while ago. The rear has 4.10's in it now but they will have to go unless I get a 700r4 to go in there. I would like to drive it on the highway once in while. If you have questions I will be happy to answer them.
Old 04-23-2007, 05:42 PM   #13
onedayjake
Re: Getting closer!
By the way here's a couple of pics without the box on.
Old 04-23-2007, 05:58 PM   #14
Daniel U
Daniel U's Avatar
Re: Getting closer!
Thanks for the additional pics. I think I've decided on these wheels for my '54. I'm trying to keep as many GM parts on it as possible, so these GM rally wheels will lend themselves to that theme. I've always liked them, just never considered them for my '54. After seing your truck, I liked the look. I will probably color match the wheel to my truck. They will wiegh less than the other 17's I looked at. Tires will be cheaper too! When I get it on the road, my local tire shop has a tool that measures the distance to get the most tire between the frame and fender. The front tires will match as there is plenty of room up front with the Must.II front end. Thanks again, Daniel U
Old 04-23-2007, 06:40 PM   #15
jchav62
1962 C-10
jchav62's Avatar
Re: Getting closer!
Looks great! I love the Rallys...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
