06-10-2007, 01:56 PM | #201 |
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
It'll be either white/blue like the first rendering in this thread, or replace the blue with dark green and the white with silver.
Update on the hidden hinges: It's not as simple as I thought... I've determined that in order to use a single point (conventional) hinge I'll have to shave the rear drip rail. You just can't put the fulcrum high and aft enough to clear it. It doesn't matter what the rest of the hinge looks like, if it's a single point hinge the arch is fixed around the fulcrum, and this determines the hatch motion. The other option is to use a compound hinge like Sachse Rod Shop makes. This would move the virtual fulcrum to the outside of the panels providing the correct arch for the hatch motion. I made up some simple drawings to help illustrate this. The compound hinge diagram is exaggerated, but shows basically what a virtual fulcrum looks like: |
06-11-2007, 12:47 AM | #202 |
BlahBlahBlah
I like the stock style hinges. Keeps it looking more like a 69 Tahoe. Helps make it more of a guessing game...Is this truck stock? Once you start smoothing and modernizing the exterior you lose a little of that.
Of course Id still love to have it either way |
06-11-2007, 01:47 AM | #203 |
Ya, that's why I don't want to shave the drip-rail, just hide the hinges. Most people won't notice... even 67-72 truck owners. How often do people study the back of a 67-72 Burb (besides a few of us here)?
06-12-2007, 06:57 PM | #204 |
Looks like the hinges might have to go on the back burner for now. It may be more time/money than it's worth. We'll see...
I have a bunch of goodies coming in the Big Brown Truck over the next couple of weeks |
06-12-2007, 07:49 PM | #205 |
Awesome, awesome, awesome!!! And I was worried about cutting on mine!!!
06-12-2007, 07:54 PM | #206 |
The LuvShack Garage
Tease
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-13-2007, 12:00 AM | #207 |
I'M TRUCK CRAZY!
nice
06-13-2007, 06:50 PM | #208 |
Brown Truck delivery numero uno:
06-13-2007, 06:54 PM | #209 |
The LuvShack Garage
Sweeeeeeeeeeeeeet. I have the same one, uninstalled, was it easy to do?
06-13-2007, 07:25 PM | #210 |
What drop did you go with? Quit holding out, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-13-2007, 10:18 PM | #211 | |
The other thing I found is that you need to put the bar in place at both ends BEFORE you tighten up the passenger side U-Bolt. This is because there is some play in the bracket's U-Bolt holes. So if you install the bar you can clock the bracket correctly, then tighten the U-Bolt. Also, I already have lowering blocks and longer U-Bolts so the nice new one's that come with the kit are useless to me. You may be able to ask for longer ones if you already have blocks. Alright, alright Bags (SS RE7's) for all four corners, the top digital air management package from SD, KP step notch, and some of their weld-on shock brackets. I'm going to put the rear bags in the stock location for now and see how I like it. The 2.5" lowering blocks plus bags should get me pretty low I also have my quarter glass and all the rear seals on the way |
06-13-2007, 10:47 PM | #212 |
Barn Door Lovers avert your eyes...
This one will never again have the option to be a barn door truck (well, anything is possible...): These holes had to go... (don't mind the little scene stealer): |
06-13-2007, 11:07 PM | #213 |
You get more use out of fender washers than anyone I know! I did it the hard way, I cut them all out, . Are you filling the hole on the bottom?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-14-2007 at 07:37 AM. |
06-14-2007, 01:16 AM | #214 |
Yep, I used 1" OD 3/16" ID "fender washers." They fit perfectly and the 3/16" hole is easy to weld up. The BD hinge slots and the "trough" (as I call it) are next.
06-14-2007, 01:38 AM | #215 |
Commander Taco Bello
this is the setup i just completed on the rear of my truck and the bottom of my license plate sits 4.5" off the ground. that's with RE7's, 2.5" blocks, and a bolt in notch. If i had a bigger notch, i could easily get another 2" so really, the blocks are pointless with a bolt in notch. details are in my build thread in my sig.
sounds like you're going with a step notch. that should get really low with bags and blocks. |
06-14-2007, 07:39 AM | #216 | |
06-14-2007, 10:34 AM | #217 | |
They do when you have a step notch. Last edited by Frizzle Fry; 06-14-2007 at 10:40 AM. |
06-14-2007, 12:27 PM | #218 |
I'M TRUCK CRAZY!
very nice
06-14-2007, 03:17 PM | #219 |
I'm basing that on this:
This is the notch I'm going with. This truck has relocated bags and no blocks. You can see how close the trailing arms are to the frame. Mine will have bags in the stock location so the arms will be spaced off the frame by the hight of a collapsed bag when aired out. I'll make up for that with the blocks. You can also see why I went with the ECE super track bar over stock: |
06-14-2007, 04:54 PM | #220 |
I'M TRUCK CRAZY!
This Is An Awsome Build! Great Work!
06-14-2007, 04:57 PM | #221 |
I'M TRUCK CRAZY!
Oh, are you going to do the tail lights like Hart_Rod. I think the truck lights look great on the Burb... I mean Tahoe!
06-14-2007, 07:49 PM | #222 |
Thanks, I'm thinkin about it They won't be exactly like his though. His are definitely an inspiration though
06-14-2007, 10:31 PM | #223 |
can't wait to see it bagged, i'm planning on using he6's in front and he8's in the rear. i have the air ride ride pro e on my infiniti and i love it.
06-15-2007, 11:42 AM | #224 |
Me too It sits way too high in the back right now. You have a Burb?
06-15-2007, 11:44 AM | #225 |
Speaking of notches... :P
I can't put it in until the rest of the stuff gets here because of the upper shock mount/crossmember. Last edited by Frizzle Fry; 08-10-2007 at 01:56 AM. |
