11-10-2007, 01:02 AM | #1 |
Is there an electrician in the house?
I have a compressor that I want to hook up and the motor draws 22 amps I guess continuously. Its 240, what would be the recommended wire/breaker make up for this install? This is all the info that I have, lost the manual. There is some stuff on the motor if it helps.
11-10-2007, 05:55 AM | #2 |
Re: Is there an electrician in the house?
10/3 wire 30 amp breaker
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour. - George Washington No free man shall be debarred the use of arms - Thomas Jefferson Later Darren http://www.myspace.com/dmurphy68 |
11-10-2007, 08:55 AM | #3 |
Son of a gun
It also depends on how far from the service panel the compressor is. The further it is, the larger wire you will need. But you don't want to buy larger than you need-copper wire is higher than a cat's back. If it is within 40 ft or so, 10/3 should be about right. There are charts on the net, google for one, they will tell you what you need with all of your info plugged in.
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 11-10-2007 at 09:00 AM. |
11-10-2007, 08:56 AM | #4 |
11-10-2007, 10:06 AM | #5 |
The panel is 2 feet from the unit. So you guys dont anticipate a draw upon stratup of more than 30 amps? My A/C has a 40 and runs on less than 10. (so i was told).
11-10-2007, 10:15 AM | #6 |
Is a bullfrog waterproof?
I'm guessing by the 22A current draw that's probably a 4 or 5 HP motor. 22A x 125% is 27.5A, 30A breaker with 10/3 wire should be fine.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt." Ben Franklin __________________ 1970 Chevy shortbed 2002 Harley Custom Chopper (Long sucker) 1998 K2500 5.7L 5-speed Longbed 1st two are My son's toys...they just live in my garage! 1997 GMC K1500 Suburban 1993 S-10 Blazer 4D (youngest son's daily driver) 2000 Dodge Ram 4WD Ext. Cab (5.9L) Wife is a late year 1951 |
11-10-2007, 10:33 AM | #7 |
Dave...Im not sure what that formula was but you absolutly sound like you know what your speaking about. Sounds good to me...thank you.
11-10-2007, 10:49 AM | #8 |
Questionable
Question for you: What does the unit say it is rated for, amperage-wise? You say up above "the motor draws 22 amps, I guess"...
When it comes to electricity, it's not something you want to "guess" about. You should look on the unit itself to find this information, or contact the manufacturer. Electricity is serious. You're basically talking about the difference between your house/garage/shop possibly burning down due to an electrical fire (or not). You can rest assured that if your house/garage/shop DOES burn down, the insurance company will be looking this information up, and refusing to pay out on the claim if negligent wiring is found to be the cause. Not trying to be a joykill here I'm just trying to look out for another board member!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-10-2007, 02:54 PM | #9 |
Shifty...what exactly am i looking for on the motor?
Blazer Project |
11-10-2007, 04:22 PM | #10 |
The name plate on the motor should have an area that says "AMPS" or "FLA" (full load amps).
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd Last edited by raggedjim; 11-10-2007 at 04:23 PM. |
11-10-2007, 04:23 PM | #11 |
Questionable
Try to find how many amps the motor draws. It should be listed on or around the motor, 15A, 20A, 25A, etc.
11-10-2007, 04:51 PM | #12 |
Skinned knuckles
You electrical guys are so shmart. I wish I knew half of what you guys know, but it's all really confusing to me. I got a D- in electronics in jr. high only because the teacher didn't fail anyone...
Just thought I'd give you guys some kudos. Now back to helping get this compressor wired in!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
11-10-2007, 06:42 PM | #13 |
okay, it says 22 amps.
Blazer Project |
11-10-2007, 08:11 PM | #14 |
From What you plate tells me is that the full motor draw is 22 amps... That is a start up draw it should run on less than that after start up. The only way to see the true amps of the motor is an amp probe once you have it hooked up. I do not forsee any problem with 10/3 and a 30 amp breaker
11-11-2007, 09:16 AM | #15 |
While a 30 amp breaker may be fine, you may look at getting a HACR rated breaker. At 22 amps FLA (which is low for a 5HP motor) the start up(LRA) could be as high as 45-50 amps(up to 225%).
The HACR(basically heating/AC rated) has a little longer time delay to help offset the start up amps. I'm sure you'll be fine with a 30 amp circuit. Ideally a disconnect switch with 30 Amp dual element time delay fuses could be used. To over complicate it even more... a 60 amp disconnect with fuse reducers fed with a 40 amp circuit and number 8 wire would be how I would do it at my house. The reason for the 60 amp disconnect is because the NEC(national electric code) states that you can up size the fuse for the "motor" protection up to 225% for start up if needed. The biggest fuse youcan put in a 30 amp disc. is a 30 amp. So if you trip the 30 you can put in a 35 or 40 amp fusein the 60 amp disc.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA Last edited by bigjimzlll; 11-11-2007 at 09:20 AM. |
11-11-2007, 02:12 PM | #16 | |
The fuses/breakers are only protecting the conductors and not the motor. The way I would do it would be a properly sized motor starter fed with properly sized conductors and fuses. I don't like saying too much on forums, I would hate for someone messing up with electricity and burning their house down. I am an industrial/commercial electrician licensed for 25+ years. |
11-11-2007, 02:27 PM | #17 |
Okay,
How about this. I will run a 30 amp breaker with 10gauge wire. Basic.
Blazer Project |
11-11-2007, 07:02 PM | #18 |
Keep it simple stupid if you were going to be using all the time like in a shop i might worrie but not at a house
11-11-2007, 11:47 PM | #19 |
Yes...I live by K.I.S.S
Blazer Project |
