Old 03-24-2002, 04:30 PM   #1
phxboy
Post fuel filters?
I bought this truck recently. It has 2 in line fuel filters. One is glass and the other is plastic. Do I need these? I assume there is also a filter at the inlet to the carb. I read on this site that the glass ones can break and start a fire. Any suggestions would be appreciated. Thanks. Great site!
[This message has been edited by phxboy (edited March 24, 2002).]
phxboy is offline   Reply With Quote
Old 03-24-2002, 05:39 PM   #2
truckster
truckster's Avatar
Post
I remove the inlet filter from the carb, because it's just too small, and use an inline filter from a newer fuel-injected engine. The housing is metal, the mesh is finer, and the capacity is so large you'll never have flow problems and it will last almost forever. Just look for something with inlet and outlet approx. the size of your fuel line.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-24-2002, 06:06 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I run a metal one under the cab, adn the class one on top.
While it is true that the glass ones can bust, if you set it up right, nothing will happen. i had a lady slam into my truck at about 70 MPH and that didn't shake it up enough.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-24-2002, 06:23 PM   #4
71GMCstreet
Post
I had a glass filter on mine on my way to a show. On the interstate, at speed, she broke, and, well, it really REALLY sucked after that, no fire thankfully, but my many hours of detailing under the hood was trashed and the truck smelled like gas for weeks. I now use a billet filter.
71GMCstreet is offline   Reply With Quote
