Old 02-01-2008, 03:25 PM   #1
Tomsriv
Tomsriv's Avatar
What color is your steering column?
I am preparing to repaint my interior with the same tan color you see on the dash. I am thinking of painting the steering column as well and getting a different steering wheel. Maybe one from an early 90's chevy truck if I can find one in a color besides black.
My column is out of a 79 Chevy truck. Does anyone know if I can replace the collar with one that is smooth? My key is in the dash and the shifter is on the floor so I want to get rid of the hole and the nub on the column.
Is your column black, the same color as the dash or a contrasting color?
Tomsriv is offline   Reply With Quote
Old 02-01-2008, 03:28 PM   #2
LILRED66
LILRED66's Avatar
Re: What color is your steering column?
The factory color of the steering column, mast jacket and steering wheel is the same factory color used on the dash.
LILRED66 is offline   Reply With Quote
Old 02-02-2008, 03:44 AM   #3
badriand
badriand's Avatar
Will a factory style steering wheel fit back on that column? Nothing like a big ol factory steering wheel.
badriand is offline   Reply With Quote
Old 02-02-2008, 03:53 AM   #4
LILRED66
LILRED66's Avatar
I am not sure what year, make or model vehicle your steering column came from, however, most likely you could retrofit a factory '60-'66 Chevy truck steering wheel. I may look a little odd, due to the larger diameter mast jacket, versus the small diameter factory column. Get a factory steering wheel and give it a go.
Old 02-04-2008, 03:10 AM   #5
protrash64
Resistance is Futile
protrash64's Avatar
........if you have a metal collar it could be welde smooth. Perhaps epoxy or fiberglass if its plastic. Im also considering running a stock steering wheel on my pick-up. After using Grant wheels it looks like you would have to notch your door panel to get it to fit!!!!!!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-04-2008, 12:39 PM   #6
Tomsriv
Tomsriv's Avatar
Well, the stock wheel is 17" diameter, the grant is 13.5. I am looking to get a stock wheel from an early 90's truck, which would be 15". That is the common diameter on most modern cars with power steering.
Old 02-05-2008, 06:26 AM   #7
kris's66lwb
resident wrencher
you could take the coulm out and grinde off the nubs and holes and weld patchers over tje key hole and jb weld ofe the shifte rhole and the body filler and paint i have seen it done befor real nice turnout i just repaintedny cab in side black coulm and all but the wheel it a stcok coulm and wheel and i have power stering
kris's66lwb is offline   Reply With Quote
