Old 03-12-2008, 08:37 PM   #26
jlaird
jlaird's Avatar
Re: ART StrongArms, $639/set
Originally Posted by shifty View Post
I do not have the tracking #. I've been told by two board vendors that they are drop-shipped direct from ART, and the operator at stylintrucks stated the same - she told me ahead of time that the arms will not ship from the stylintrucks warehouse.
yea, thats what I figured. Who wants overhead.
jlaird is offline   Reply With Quote
Old 03-13-2008, 11:53 PM   #27
shifty
Questionable
shifty's Avatar
For anyone wondering -
The ART arms came in today. The box weighs nearly 100lbs, and is 24" x 24" x 24" in size, approximately.
So, IMHO, $65 is not an excessive amount for shipping.
And yes - the coupon above obviously works
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-14-2008, 07:15 AM   #28
sddwtcb
Guest
Posts: n/a
sweet! i'll be ordering a set soon.
Old 03-14-2008, 07:21 AM   #29
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Awesome deal shifty.
I sure was wrong in my thinking that such a large place would be drop shipping items like Stylin. I stand corrected. Maybe I should call about renting some of their empty warehouse space.LOL
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-14-2008, 08:14 AM   #30
gringoloco
A guy with a truck
gringoloco's Avatar
Gangster! Where's the mock-up pics? Get to work already
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-14-2008, 08:44 AM   #31
shifty
Questionable
shifty's Avatar
Man, I have way too much else to do. I got the rear of the frame taken care of, gotta weld in the notch, gotta finish welding up unnecessary holes which means I gotta mock up the drivetrain this weekend to figure out which of my tranny xmember holes I can delete, and then gotta decide what other holes I'll keep. You know, I'd hoped to have it coated already, figured that woulda been first to get done, but all these junkyard runs and parts runs and other BS have set me back!
The whole reason for tearing this thing down was to change the quick connect fitting on my T56! WHAT HAPPENED?!!
Old 03-20-2008, 04:02 AM   #32
csbatey
csbatey's Avatar
hey i order mine with bags ,shock ,upper arm, lower arms 885 ship to my door what a deal. 999 without the discount thanks alot
csbatey is offline   Reply With Quote
Old 03-20-2008, 07:21 AM   #33
shifty
Questionable
shifty's Avatar
Glad it helped someone out! Don't forget to post pictures once you get em installed!!
Old 04-02-2008, 06:50 AM   #34
BigTex
Thanks Shifty. Just ordered the full coolride with upper and lower arms and a musclebar.
I can't decide if you saved me $260 or cost me $1100+???
Richard
1970 Chevy (growing pile of parts)
2003 Silverado SS
BigTex is offline   Reply With Quote
Old 04-26-2008, 06:20 PM   #35
jimmydean
jimmydean's Avatar
Shifty,
If I order the 73+ arms, then I can just use the 73+ drop spindles for a set of 73+ brakes with my current crossmember, correct? Then all I need is the tie rod adapter to stick with the stock steering linkage until I go to the rack setup.
I will be using a dropmember once my motor is built, but I want to get the arms/discs/bags in now.
I used the cheater disc kit last time and paid way too much for ball joints and tie rod ends. I will convert the rear to 5 lug discs when I put the kp notches in.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-26-2008, 07:30 PM   #36
abadsvt
abadsvt's Avatar
Originally Posted by jimmydean View Post
Shifty,
Hey Jimmy! Did i miss something? You truck looks like it is raised not lowered. You were sitting pretty low to the ground. What happened? Tell me you didn't cross over to the other side.........
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 04-26-2008, 08:00 PM   #37
jimmydean
jimmydean's Avatar
Josh
I did, briefly. I bought a huge redneck truck that ended up being WAY more trouble than it was worth. I am currently working on a plan to build a '66 LWB.
I want to run a dropmember, but I won't be pulling the engine for at least a few months. My goal is to swap out the control arms, brakes, and install the bags. Then once my motor is done, pull the gasser, install the dropmember, then install a 6.2 turbo diesel.
I hope to start a build thread soon. The '66 will pick up where the '69 left off.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-01-2008, 11:17 PM   #38
19stepSide72
wanna be 67
19stepSide72's Avatar
is this still good? any pics of items?
19stepSide72 is offline   Reply With Quote
