Old 05-15-2008, 02:18 PM   #126
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: Project: Bolt one on
Looks great Dude!
Getting closer!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 05-15-2008, 03:09 PM   #127
FormerMember
A question, why aren't you using the Blazer doors?
FormerMember is offline   Reply With Quote
Old 05-15-2008, 09:41 PM   #128
vtblazer
vtblazer's Avatar
Already had these sitting in the shop and their gutted, which as you know means 'WAY LIGHTER' to work with along with the fact that when I was ready to hang doors, the blazer doors where buried in the snow bank.
vtblazer is offline   Reply With Quote
Old 05-15-2008, 11:48 PM   #129
jaros44sr
jaros44sr's Avatar
Nice work, nice gap...those strap tie downs work great at pulling things together, just wish you could rachet them out like a comealong. See ya soon
Don't tell me you still have a snowbank
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-15-2008, 11:51 PM   #130
FormerMember
Hopefully the gaps work out with the K5 ones.
Old 05-16-2008, 12:42 AM   #131
vtblazer
vtblazer's Avatar
K5 doors and truck doors have the EXACT same dimensions.
In fact, all K5 doors began life as truck doors, then modified at the factory.
Aside from that to address your concerns, the door openings in the blazer are within factory spec's.
Old 05-16-2008, 01:18 AM   #132
jaros44sr
jaros44sr's Avatar
Cool
SAFETY FIRST
AS usual, off topic
Jim
Old 05-16-2008, 01:21 AM   #133
FormerMember
Heh, it's not your work I had concerns about... it's the doors in the snowbank.
Old 05-17-2008, 11:28 AM   #134
vtblazer
vtblazer's Avatar
Pass floor patch is in but not finished yet due to time constraints of the day.
Spot welded the nines outta this install, I almost feel bad for the next guy.
In an effort to avoid having a welded seam in a tough to get at area, I decided to go around the 'pre-shaped' floor area.
Everything got sprayed with weldable primer prior to the final install.
Friday should produce finished floor and rocker areas.
K5 DOORS:
Knew there was another reason I hadn't used the K5 doors that came with the tub but didn't remember until I went out and looked at em again.
Old 05-17-2008, 11:33 AM   #135
vtblazer
vtblazer's Avatar
Drivers door has the imfamous 'shoulder check' opening method dent.
Fairly bad, not only bent but it also has a tear.
Old 05-17-2008, 01:37 PM   #136
Chevyman63
Chevyman63's Avatar
Floor is looking good...doors, not so good.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 05-17-2008, 02:39 PM   #137
FormerMember
How about the other two? (I think I gave you three... getting senile?)
Old 05-17-2008, 02:44 PM   #138
vtblazer
vtblazer's Avatar
Those pics are showing both of the blue doors, the third door is usable I believe.
Old 05-17-2008, 03:21 PM   #139
jaros44sr
jaros44sr's Avatar
What kinda spot welder do you have, I've only seen the one with arms, and they may not reach what I want to do
Never mind, looked at the pics again and seee what ya did
Clever solution to that problem area, woulda bin tough to do it the other way
SAFETY FIRST
AS usual, off topic
Jim
Old 05-18-2008, 12:17 PM   #140
vtblazer
vtblazer's Avatar
Pass floor installed.
Old 05-20-2008, 08:29 PM   #141
vtblazer
vtblazer's Avatar
Pics of the rest of the sheet metal I picked up from you:
*White passengers door is not good either, you can see the bow it has and those holes in the bottom of the door are there because someone once pushed out a dent in the lower portion.
That area of the door is full of bondo too.
Lastly, that inner corner showing rust will for the most part disappear when sand blasted, I'd bet.
*Of the tailgates, only the Ochra one will be worth trying to use.
Old 05-20-2008, 08:35 PM   #142
vtblazer
vtblazer's Avatar
*Passenger fender looks good aside from the lower cup area that has been cut off.
* Drivers fender needs a lot of work tough.
See the area where the bondo is coming through the holes?
Another previous repair, that whole area is still full of bumps and ripples.
Your choice but IMO, you'll be money ahead using a set of repro fenders.
Old 05-20-2008, 08:37 PM   #143
FormerMember
Did you have sheet metal that will work?
Old 05-20-2008, 08:47 PM   #144
vtblazer
vtblazer's Avatar
I do have a set of repro fenders as well as one set of good factory ones but need to figure out which set I'm using for my on going blazer build.
I have hoods, no good inner fenders tough.
I have a couple rad. supports but none that wouldn't need at least 'some' attention/rust repair/painting.
No doors either, sorry.
Old 05-20-2008, 08:50 PM   #145
FormerMember
How tough would it be to cut a set of truck doors down? I have a nice set here. I also have a decent radiator support and hood. Inner fenders can be repops and wait.
I don't care about the lower cups on the fenders, they will be cut off to clear the winch bumper.
Old 05-21-2008, 01:01 PM   #146
vtblazer
vtblazer's Avatar
Thread on it here:
http://67-72chevytrucks.com/vboard/s...t=blazer+doors
Old 05-22-2008, 12:17 AM   #147
vtblazer
vtblazer's Avatar
Rocker installed:
Old 05-22-2008, 12:24 AM   #148
Chevyman63
Chevyman63's Avatar
Very nice!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 05-22-2008, 12:32 AM   #149
FormerMember
I am looking forward to finishing this thing off.
Old 05-22-2008, 01:22 AM   #150
jaros44sr
jaros44sr's Avatar
Nice work, is this one done VT? How much gap are you left with between the rocker and the forward lower rear quarterpanel. Jon was asking me this, and I didn't know. I just usually center the rocker on the door. Thanks for the pics, it looks sweet
SAFETY FIRST
AS usual, off topic
Jim
