Old 08-13-2008, 02:21 PM   #126
lyrikz
PITbut
lyrikz's Avatar
Re: Dropmember Rear 63-72 Spy Pic
Originally Posted by porterbuilt View Post
more...
Do you have to cut the floor out for it to fit???
lyrikz is offline   Reply With Quote
Old 08-13-2008, 02:35 PM   #127
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by Longstep70 View Post
So this kit now is designed specifically to work with a 4 link and not with the factory trailing arms, correct?
-Andy
Correct, this is NOT designed to be used with trailing arms.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-13-2008, 02:52 PM   #128
gringoloco
A guy with a truck
gringoloco's Avatar
Will the notches be modular- say if someone wanted to change to a larger notch later for taller tires/wheels or just wanted to go lower- would it be a bolt-in swap?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-13-2008, 03:13 PM   #129
PBFAB.COM
PBFAB.COM's Avatar
The notches are a modular design. If one originally purchased a 26" notch and later decided to switch to a 32" notch, they would just need to unbolt the original notch, and bolt-in the larger one (sounds a lot easier than it really would be). All the drilled mounting locations are universal for the notches.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 03:58 PM   #130
jimmydean
jimmydean's Avatar
That looks awesome.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-13-2008, 04:23 PM   #131
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
<--- Drooling
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-13-2008, 06:11 PM   #132
jlaird
jlaird's Avatar
F9000.... of course!
What is the collasped height of the F9000?
jlaird is offline   Reply With Quote
Old 08-13-2008, 06:12 PM   #133
PBFAB.COM
PBFAB.COM's Avatar
4.5"
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 06:26 PM   #134
Kontrol Phreaks
Kontrol Phreaks's Avatar
How tall of a tire can you lay on a 26" tall notch ? 44" super swampers ...
Kontrol Phreaks is offline   Reply With Quote
Old 08-13-2008, 06:38 PM   #135
PBFAB.COM
PBFAB.COM's Avatar
The assigned a size to each notch in inches, that coordinates with what size tire you can lay frame on.
I know you're just playing with me Clint... enough with the "man crush".
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-13-2008, 06:58 PM   #136
jasonb72
PorterBuilt Man Crush
I call inland Empire, and they told me that the mounting holes were the same as stock. I really like this setup for HP applications.
http://www.iedls.com/images/page11-02.jpg
http://www.iedls.com/page11.html
Do you by chance have a dimensionon the mounting hole spread? If so, I can verify, and modify the mounting pad if necessary. I am assuming a generic mounting dimension isused... but that would make life too easy!
The carrier bearing crossmember can be moved up,down, forward or back to accomodate different configurations.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 08-13-2008, 08:19 PM   #137
98L150
///Relaxed Atmosphere
98L150's Avatar
wow it really looks nice. when will this kit be availabe? have one truck here in houston that is begging for this kit, the front dropmember could use its new rear dropmember "brother"
jeff
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 08-13-2008, 10:54 PM   #138
leftcoast66
leftcoast66's Avatar
Dang, is there anything that you don't think about when building these. The attention to detail is incredible. All universal bolt holes amazes me.
leftcoast66 is offline   Reply With Quote
Old 08-13-2008, 11:14 PM   #139
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
You do such nice work Nate! I cant wait till I can rubb my hands all over this masterpiece of nates creative mind, I know who's getting this one. SHHHH!BTW <------no man crush Nate just rules!
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 08-14-2008, 10:56 AM   #140
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
That ONE?! if you look in one of the pics there's enough parts for at least 10 more. Add in the front DM is got to be 200+ made by now. ALL welded and hand assembled by 1 dude I'd like to know when that boy sleeps? Looking at those welds and the productivity I'm convinced he's somesort of cyborg or clone.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 08-14-2008, 11:00 AM   #141
RunninLo
RunninLo's Avatar
I'm sure Nate will correct me if I'm wrong ( it happens ) but the last specs I got was the rear DM topped out at a whopping 12.5" above the top of the factory rail. I believe tyhe actual quote from Nate was " Your plywood floor is ready for the fire pile"
Josh
88 4x4 crew DD
Old 08-14-2008, 11:30 AM   #142
jimmydean
jimmydean's Avatar
Josh
Actually, Nate doesn't do any real work anymore. He does the design and sends it overseas to be welded. It's the American way.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-14-2008, 01:18 PM   #143
SCOTI
SCOTI's Avatar
I thought he was just having them built in Indiana . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-14-2008, 01:19 PM   #144
Riveted1
Tasty Cakes!
Riveted1's Avatar
No, it is not done overseas. I've been there and seen who he has doing his work for him! Here is a pic I shot of them. They sing and work at the same time!
Haha Just kidding Nate. The rear setup looks cool. Might have to get one of those + the front setup for my burb project.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-14-2008, 02:27 PM   #145
PBFAB.COM
PBFAB.COM's Avatar
Josh
We are just over the 200 mark on Dropmembers sold (including rears). It's been a good couple years, thanks to all my customers. I must admit, some days I get a little tired of welding!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-14-2008, 02:29 PM   #146
PBFAB.COM
PBFAB.COM's Avatar
Josh
The biggest notch I make (will lay a 32" tire) sits 12.5" above the frame-rail at the axle center-line, with the bridge piece bolted on. People ask... how much do I have to "trim" the bed floor? It's best to remove it and start over.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-14-2008, 02:29 PM   #147
PBFAB.COM
PBFAB.COM's Avatar
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-14-2008, 02:41 PM   #148
Hart_Rod
Hart_Rod's Avatar
You need some help? I'll be looking for a job in about a year, .
R/
Hart_Rod is offline   Reply With Quote
Old 08-16-2008, 08:59 PM   #149
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
i might have to lay frame on the ol' pro-streeter....i like the front setup as well, very nice work.
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 08-16-2008, 09:14 PM   #150
project 67 sub
project 67 sub's Avatar
hey porterbuilt, so whats the price going to be when it comes out? and would you sell just the notch and how much?
project 67 sub is offline   Reply With Quote
