Old 10-13-2008, 03:56 PM   #51
jephs422
Re: 67-72 Bolt in pedal assembly
Originally Posted by stunna View Post
That makes 2 of us I'm in!!
well heck only 3 more to go
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 10-13-2008, 04:45 PM   #52
jlaird
jlaird's Avatar
Is the mc and booster from CPP as pictured?
jlaird is offline   Reply With Quote
Old 10-13-2008, 04:47 PM   #53
jephs422
Yes we buy them direct from CPP. There are upgrade options if you want a full billet CNC machined M/C.....but it's going under the floor, so, that's kinda pointless.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-13-2008, 10:06 PM   #54
stunna
you got the mc and boosters in stock? some people here have had bad experiences with cpp (customer service). How long to get these done once we get to the magic number 5.
stunna is offline   Reply With Quote
Old 10-13-2008, 10:32 PM   #55
gringoloco
A guy with a truck
gringoloco's Avatar
THREE. Two to go...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-13-2008, 11:01 PM   #56
VA72C10
VA72C10
VA72C10's Avatar
How long are you extending this i.e. when do you need payment to be in the group buy. I'm 90% committed but need to sell a few more parts first.
Old 10-14-2008, 12:02 AM   #57
jephs422
Yes, I stock all the items we sell if we don't manufacture it. I would guess off the top of my head that there are about 30 M/C's in stock ready to go. The pedal assembly's should be in stick, but I'll need to check. If they are not, it takes less than a week to get them out.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-14-2008, 12:36 PM   #58
stunna
Thanks, now we are only 2 away! I'm sure we will get enough members.
Old 10-14-2008, 01:10 PM   #59
VA72C10
VA72C10
VA72C10's Avatar
Old 10-14-2008, 02:02 PM   #60
jephs422
These pictures should help a bit.
You can see that the entire assembly can be moved up about 1-1/2" before it hits the bottom the floor. That would take the bottom of the booster just at frame level. However, understand that the front crossmember, and the rear mid crossmember (where the drvieshaft intersects with the trailing arms), both sit lower that the current position of the booster.
VA72C10-I guess it'll be extended until we reach the amount we need. But don't worry, I'll work out a way to fit you in
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-14-2008, 02:12 PM   #61
VA72C10
VA72C10
VA72C10's Avatar
Another question. Do you have a matching set of pedals that will work with this or a way to attach something to utilize the factory pads?
Old 10-14-2008, 02:18 PM   #62
jephs422
You know, I've never used a set of factory pads. I guess there should be no issue with hooking up a factory pad, I just need to look at it and see how it attaches now.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-14-2008, 06:23 PM   #63
jlaird
jlaird's Avatar
A lot of us here have either modified or aftermarket front and rear crossmembers, so the booster position is a concern. Do you think the pedal shaft would need to be shortened if we move the whole assembly up as far as it can go?
Old 10-14-2008, 06:28 PM   #64
jephs422
Actually I stuck my head under an installed one this afternoon, and the consensus is that it can move up with zero ill effects. If you look at the pictures you can see that the bracket bolts to your frame, and the assembly bolts to the bracket. You can simply unbolt the bracket and bolt it to the frame, then relocate the mounting holes (drill 4 of them). You should be able to move the entire assembly up about 1-1/2" and still fill the reservoir with a baster or brake bleed pump.
The only thing that may need to be modified is the pinch weld where the kicker and firewall meet. It'll probably just need to be trimmed a bit.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-14-2008, 06:29 PM   #65
VA72C10
VA72C10
VA72C10's Avatar
I appreciate you looking into this. I have a set of the deluxe pads w/ the stainless trim I planned on using. But will sell those and utilize other pedals if you can get matching ones for the gas and E-brake. Thanks!
Old 10-14-2008, 06:34 PM   #66
SCOTI
SCOTI's Avatar
It would be worth looking into for sure. I like the idea of the 'hidden' mounting but would want the pedals to look 'factory'. Let us know . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-14-2008, 06:40 PM   #67
jephs422
I'll look into the options. I agree, a set of matching pedals is a must.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-14-2008, 09:29 PM   #68
DrtyJack75
What are you guys going to do about that hole where the pedal comes through? Grommet of some sort??
DrtyJack75 is offline   Reply With Quote
Old 10-14-2008, 10:55 PM   #69
gringoloco
A guy with a truck
gringoloco's Avatar
Is the booster 7" or 9"?
-Chris
Old 10-15-2008, 01:26 AM   #70
jephs422
Originally Posted by gringoloco View Post
is the booster 7" or 9"?
it's a 7"
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-15-2008, 12:37 PM   #71
jephs422
The one in the picture ended up with a new kick panel and firewall, so it was not necessary to make the hole small. In most case the hole is going to be clearanced a lot tighter and you can fashion a rubber gasket of sorts.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-15-2008, 10:31 PM   #72
gringoloco
A guy with a truck
gringoloco's Avatar
Anyone thought about Hydroboost on this bracket? That may solve the hanging below the 'rails issue...
-Chris
Old 10-15-2008, 11:20 PM   #73
stunna
i actually talked to them about that, they said they can do that on a custom basis. That would solve the problem for you frame laying guys. I can work with the current setup. we are still looking for 2 more people!!
Old 10-15-2008, 11:56 PM   #74
Rokcrln
Rokcrln's Avatar
Very nice looking part. I do have a question for you, it looks like the pedal is now in the same location as the gas pedal. Can you get a measurement off the drivers side kick panel to the CL of the pedal? Also on your weld in kit is everything welded to a flat plate or is it truly a "Weld up kit", could you include a pic of what the weld in kit looks like as shipped? Thank you very much for your time on this product.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-16-2008, 02:13 AM   #75
nuke1
nuke1's Avatar
Very nice part, i am in with kevin on the cl of the pedal as i am interested in one also, thanks. James
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
