Old 12-26-2008, 09:31 PM   #1
drivesfed
drivesfed's Avatar
Reassembly advice
Work on the 55 first series truck we bought a couple weeks ago is underway.
The front left cab corner was rotted out, so I removed the door and fender for access. I also took out the front grill and just to make things easier for painting and since I was in the mood, took off the right front fender and door as well.
So it is just the cab on the frame. Front inner and outer fenders and grill are painted and ready to put back together after the cab is painted.
My question is what is the best way to put it all back together? Would you recommend assembling the entire front clip and then install? Right now I am looking at putting inner and outer fenders together, then installing those on the truck, followed by the grill and bumper.
I could get it back together but realize there are many people out there with more experience than myself. Any suggestions would be appreciated.
Marc
drivesfed is offline   Reply With Quote
Old 12-26-2008, 10:34 PM   #2
50adrod
50adrod's Avatar
Re: Reassembly advice
I think you need to fit the hood first, and then the fenders adjust from there
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 12-26-2008, 11:23 PM   #3
solidaxel
solidaxel's Avatar
That is the process I am going to do this time on my 53, fit the fenders to the hood.I remember having trouble getting the fenders to fit the rad. core support and the inner fenders with out scratching them at the front. Maybe leave the bolts loose until you have the fenders lined up with the hood on the side and front. GOOD LUCK !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-27-2008, 12:24 AM   #4
drivesfed
drivesfed's Avatar
So.....put the radiator support in and get the hood fitted to the cowl.....then move on to fenders and such.
I'll give that a shot.
Thanks!!!
Old 12-27-2008, 12:43 AM   #5
50adrod
50adrod's Avatar
Thanks!!!
yes, everything adjust off of the hood. good luck
see the 5th reply it explains about the hood
http://www.stovebolt.com/ubbthreads/...rue#Post411000
