Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-11-2009, 06:36 AM   #1
AceX
>130dB Moderator
AceX's Avatar
Speaker Selection and Buyer's Guide
Copied from Car Audio and Electronics Magazine.
In no way am I claiming that this was written by me, it just saves me alot of time when it comes to writing one.
This is kind of a long read, but its a dam good article.
>> Original Article Link <<
Component Buyer's Guide - Techniques and Tips
By Mark Eldridge
There is very little room for debate about the fact that proper speaker installation is the most important factor in determining how good, or how bad, an audio system will sound. It is absolutely true that less expensive, moderate-quality speakers installed properly will sound better than even the highest quality, most expensive speakers installed poorly. However, those same high-quality speakers, when installed properly, can produce truly outstanding sound quality in an audio system, and that's what we want!
While there are hundreds of different car audio speakers available, ranging from subwoofers to tweeters, the same basic installation guidelines apply to all of them when it comes to maximizing any speaker's sound quality potential.
The mounting requirements for a subwoofer are well documented and relatively obvious. Being a large speaker that will move a lot of air necessitates that it be installed in a well-built, solid enclosure. Most installers and enthusiasts understand this fact (even though, unfortunately, they don't always install them this way).
But what about the higher-frequency speakers: the midranges and tweeters? In most installations, much less attention is paid to these speakers than to the subwoofers. In fact, many systems that do produce good low-frequency response from the subwoofers do not produce the same performance from the rest of the speakers in the system, quite often because the midrange and tweeter speakers are poorly installed, severely limiting the system's true sound quality potential. But with just a little additional effort in the installation of these speakers, the system can sound really good.
Of course, you can go to the most extreme levels for speaker installation, spending hundreds of hours on the design, fabrication and detail when building an ultra high-end system for sound quality competition, for example. But in the real world, for those of us who simply want to upgrade our car audio systems so they sound good when we drive them every day, what are the minimum requirements to ensure that the speakers will sound their best?
For the purposes of this article, let's assume that everything in the audio system connected before the speakers will provide a clean, undistorted signal to the speaker, with sufficient power to reach the desired listening levels for the system. Also for our purposes, we're not going to excessively burden ourselves with optimizing the system for staging, imaging and other qualities that would require many, many hours to achieve. We're going to look only at the installation of the speakers themselves in a simple OEM speaker upgrade system design, and what it takes to achieve excellent frequency response, acceptable volume levels, minimal distortion, and eliminate annoying resonance and rattle issues, with minimal effort.
MIDRANGE (AND/OR MIDBASS) SPEAKER INSTALLATION
How the midrange speakers are physically mounted will have a tremendous impact on how the system will sound. The midrange speakers will handle everything from around 60 to 90Hz on the low end up to around 3,000Hz on the high end, depending on the manufacturer's recommended crossover points. This frequency range represents the most critical 5+ octaves of the 10-octave audible frequency range. Subwoofers operate in only the lowest two octaves or so, and the tweeters in the highest three octaves. And, most of the information in music, the majority of the vocal range, and in fact the majority of everything we listen to, is contained in the frequency range reproduced by the midrange speakers.
So, if the midrange speakers don't sound good, then it's very likely that the entire system will not sound good either. And ensuring that they sound good is in large part determined by the quality of their installation. While a midrange or midbass speaker isn't as large as a subwoofer, it still must be very solidly mounted. The moving mass of the speaker cone, especially at high output levels, will try to move the entire speaker, and the surface it's mounted to. If it's not mounted properly on a solid, non-resonant surface, it may cause parts of the mounting surface to rattle, buzz and cause unwanted noise and distortion.
If the OEM speaker locations are used, the mounting structure will likely need to be strengthened and stiffened. The very thin metal and plastic (which is becoming more ubiquitous) that the OEMs use may work decently for low-powered, less-than-great-sounding OE speakers. But we are installing high-quality gear, and want it to sound good, so the mounting surface needs to be improved.
Depending on the vehicle, this may entail simply using good hardware to install the speaker. Or it would mean adding some additional structural material, completely reconstructing the panel, or even building a dedicated enclosure.
Also, if there are holes in the mounting panel, like the access holes in the door panels to allow service of the window and lock mechanisms, they must be sealed off so that the back wave from the speaker doesn't interfere and cancel out the front wave that we want to project into the listening space. Small holes (less than an inch in diameter or so) can be sealed easily using the adhesive-type panel damping materials. Larger holes will need a more solid structural material to be utilized.
Material selection for these purposes can range from ABS plastic, to fiberglass, to aluminum, or even steel. For door installations, wood or MDF usually isn't a good choice because when it gets wet from rain, it can warp, swell, or break down and fall apart. And, backstrap or small thin brackets won't do much good either, as they cannot provide any real strength for the panel, or help seal large holes.
The sound quality improvement will be directly related to the quality and effort put into the structure. Build it right and it can sound great.
ACOUSTICAL TREATMENTS
Even when the mounting structure is built solid, any areas around and behind the speaker need to be treated so that they do not resonate or vibrate and detract from the sound we want to hear. A number of sound deadening and damping materials from any of several manufacturers can handle this. Metal panel vibrations, as can occur with door outer and inner panels, can be controlled with adhesive-backed mass damping materials. Adhesive-backed absorptive foam and/or reflection-controlling silicone rubber materials can be used to attenuate and control the back wave from the speaker cone, preventing it from reflecting off hard surfaces behind the speaker and then coming through the cone, causing distortion.
MIDRANGE/TWEETER MOUNTING PROXIMITY
The number one question regarding high-frequency speaker placement is, "Where does the tweeter go, relative to the midrange?"
It's a good idea, if possible, to keep the midrange and tweeter close together. This will minimize problems caused by separating them by large distances. These problems include comb filtering and other frequency response problems, instruments and vocalists that seem to come from multiple locations, arrival time issues, etc. In general, separating the midrange and tweeter make it much more difficult to tune the system's overall sound quality response.
In fact, quite often, a good speaker choice is a set of properly designed coaxial speakers. They can sound very good, with very minimal effort. With coax speaker designs, the speaker manufacturers know exactly where the tweeter will be relative to the midrange, and the system can be designed more critically. With even the best quality separates, the manufacturer must make assumptions about where the tweeter will be mounted, and if they are not installed accordingly, the speaker system's response may not be optimized.
Also remember that just because an OEM tweeter is mounted in the A-pillar with the midrange low in the door or kick panel doesn't mean that is where it will really sound the best. While the highest frequencies will seem to be high up above the dash, the overall sound will probably not be coherent across the audible frequency range, especially around the crossover frequency, and it will be difficult to make the system sound its best. Even if mounting the tweeter close to the midrange will place it low in the door or kick panel area, in most every case, it will sound better there with minimal effort, than if they are separated.
Sure, if you are using some serious processing power and have many hours to design the system, you can make it sound really good with the speakers separated. But we're talking about making systems sound good without extensive vehicular modifications, thousands of dollars and many hours in the install bay.
Once the system is tweaked with the midrange and tweeter close together, if there is the desire to raise the overall soundstage, a second set of tweeters can be used, carefully mounted higher in the A-pillars and crossed over very high (above 10,000 Hz). Done carefully, this can help with the apparent stage height, without detracting from sound quality of the primary midrange/tweeter system.
Conclusion
These are just a few techniques, tips and guidelines that can help make your system sound its very best. While it may not be possible to accomplish all of these things in every installation, the more effort that can be put into the installation, the better the system will likely sound.
We all know that subwoofers are really important and help provide the low frequency foundation in any system. But, the speakers reproducing the majority of the music in the range above the sub-bass range are what will truly determine how the system will really sound. Design and install the higher frequency speakers the right way, and the system will have the potential to sound awesome. Install them poorly, and there will be no possible way to make the system sound good.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
