Old 01-13-2009, 08:50 PM   #101
theyammieguy
accepting donations
theyammieguy's Avatar
Re: Whose on Steelies? Post 'em up!
here's my junk
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-13-2009, 09:23 PM   #102
Ont67shortbox
It is tubbed,but it is also coil spring/trailing arm,the rear is stock length,wheels are 15x12 with 8 inch backspacing
Ont67shortbox is offline   Reply With Quote
Old 01-13-2009, 10:01 PM   #103
Originally Posted by brendonak View Post
Can you get like a 255/55 or 265/50 tire for the 16.5?
No,those are newfangled sizes for light vehicles.16.5s are for truck tires.
Old 01-13-2009, 10:33 PM   #104
CG
BlahBlahBlah
Here is my 71 K20 when I first got it with the black wheels. Then I changed them over to a little bit narrower white wheel.
And here is my 71 K10 with white wheels. I love the look of these wheels on these trucks.
Old 01-13-2009, 10:37 PM   #105
nds1968
nds1968's Avatar
I am going to run one of these combos with 15x6's in front and 15x8's in the rear.
nds1968 is offline   Reply With Quote
Old 01-13-2009, 10:57 PM   #106
thirdstreettito
Resident of Here
thirdstreettito's Avatar
CG, your K20 is hot! What are the specs?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-13-2009, 11:00 PM   #107
CG
BlahBlahBlah
Ummm...its stock, lol. Tires are 33 x 12.5 16.5. No lift, 350 4sp. Nothing special, but I like it. Im the second owner.
Old 01-13-2009, 11:44 PM   #108
thirdstreettito
Resident of Here
I couldn't tell, Special-K posted some with 15x8's and they look like 15x11's because of the WIDE tires. I love the looks of it.
~Bradley~
Miss having a truck
Old 01-14-2009, 12:10 AM   #109
CG
BlahBlahBlah
Im not positive on the width of the wheels. I think they are a little over 8 inches...Im getting old and forgetful...lol.
Btw...I hope Isabella comes over here before you change your latest av...that thing cracks me up. I think she will like it.
Old 01-14-2009, 12:13 AM   #110
pcorriveau951
pcorriveau951's Avatar
CG, very nice truck!!! can you measure how far from the ground to the wheel opening is on your truck in the front? it would be much appreciated
Thank you, Phil
pcorriveau951 is offline   Reply With Quote
Old 01-14-2009, 12:54 AM   #111
phipp13
THE DAMN YANKEE
phipp13's Avatar
Here's a pic of a steelie, the other ones kinda busy
phipp13 is offline   Reply With Quote
Old 01-14-2009, 01:10 AM   #112
CG
BlahBlahBlah
Thank you, Phil
Green truck or black truck? Green is here, black one is stored in a barn at my inlaws.
Old 01-14-2009, 01:32 AM   #113
pcorriveau951
the green truck
Old 01-14-2009, 01:50 AM   #114
CG
BlahBlahBlah
37.5 inches off a cement floor.
Old 01-14-2009, 03:32 AM   #115
pcorriveau951
CG, Thank you very much
Old 01-14-2009, 06:59 AM   #116
CG`s green truck started with black 9.75s like the white GMC and red Chevy I showed.All have 12.50/33 x 16.5s on 9.75 x 16.5 wheels.His white wheels are 8.25 x 16.5.
Old 01-29-2010, 04:38 PM   #117
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Here's mine 16.5 Kelsey hays, I have five of them. I think their the same as special-k's but their closer to 11" wide.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-29-2010, 07:15 PM   #118
NC67Chev
NC67Chev's Avatar
To 67 C-30 (or anyone else that can advise),
I was planning on posting a question about using original steel wheels after I complete my power disc brake conversion and 2.5/4 drop. It seems like the people on this post likely hold the answer to my question, so I'll just post here. I've found some 15" 6 lug disc wheels that will enable me to use my original hubcaps. However, I've read a couple of posts that seem to say that there is an issue with control arm clearance with 15" wheels after a 2.5" spindle drop. Is this the case? If so, how did you get around it?
Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 01-29-2010, 07:54 PM   #119
vectorit
What?
vectorit's Avatar
Here's mine, just some old 16.5's with BFG 33x12.50 rubber.
They aren't the originals to the burb, but they have been on there for close to 30 years. They are date stamped 1969.
I still have my original 16.5 splits though.
Eventually going to some similar steel wheels, but in a 16" or 17" diameter after I get other things taken care of.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-29-2010, 08:53 PM   #120
highperf4x4
Mine are Cragar Nomad 2's
Tires are Cooper Cobra GT's
Suspension is stock
Front 15x8 with 255/60/15
Rear 15x10 with 295/50/15
I like the old school stuff but not necessarily stock. Just what I had in high school!
highperf4x4 is offline   Reply With Quote
Old 01-29-2010, 09:41 PM   #121
SCOTI
SCOTI's Avatar
Thanks!
To answer your question about 'interference', there is some but it varies w/the back-spacing. Narrower wheels require less trimming of the lip around the BJ edge of the lower a-arm; wider wheels w/more back-space might require more.
Hop over to the suspension forum & post up your wheel size & back-space. See if someone might have that combo to give you a more specific answer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-29-2010, 11:53 PM   #122
2bits
2bits's Avatar
Suspension is stock
Looks awesome to me! I wouldn't change a thing. Not paint it either, nothing. It's perfect!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 01-30-2010, 12:08 AM   #123
highperf4x4
Thanks. I already primed the hood though. I was planning to repaint it factory colors. The interior is already shaping up. Just need to build my custom oak center console. I guess I could sand the hood back down and let it go again!
Old 01-30-2010, 12:30 AM   #124
2bits
2bits's Avatar
Looks good either way, you got the style I like, just like in high school.... Love it... My old steelies:
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 01-30-2010, 12:41 AM   #125
highperf4x4
That's sweet. Got more pics of that truck?
