01-16-2009, 01:48 PM | #1 |
LWB to SWB swap - frame differences?
I'm converting a 72 LWB to SWB and found a 67 SWB frame. Before I get too far down the road. Are there differences in the frames from 67-72? For example, I measured the radiator support mounts on both frames and there is a difference in the widths. Just want to make sure I know any other differences going in.
Thanks! |
01-17-2009, 02:56 AM | #2 |
Re: LWB to SWB swap - frame differences?
All I can add is I discovered there must be MAJOR differences in brake line routing and mounting-'72 disc lines no fitty! Only other thing may be coils or leafs on rear susp.
01-17-2009, 01:11 PM | #3 |
Texas Big Wig
For 67 frames, I know of the following to be different: Core support mounts, steering box mounts, & no notch outs in the frame around the engine
01-17-2009, 03:08 PM | #4 | |
The Older Generation
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-17-2009 at 03:14 PM. |
01-18-2009, 12:27 AM | #5 |
Thanks for the info guys. Sounds like not too much to worry about.
Tags |
frame swap |
