Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Complete Holley Pro-Jection fuel injection system for sale.
system is in good shape but has not been used in 8 years. so fuel injectors may need cleaned. This is the older system that came out before the di. $350 Its, a 650cfm 2bbl. It is easy to adjust. The computer control is located inside the drivers compartment. You just use a vacuum gage and turn the screws. It is NOT the type that needs a laptop to adjust. I installed a vacuum gage in dash on the car and set the control unit on my lap which made it easy to adjust to my cam profile. Then attached the control unit under the dash. Even though it a 2bbl unit, it requires a 4bbl manifold. Its set up for a spread bore manifold and they say to use an adapter on a square bore manifold. I think I have the adaptor and you can have that too if I can find it or they only cost a couple of bucks. But I used a performer and a F4B manifold (square bore) and did a little porting with a dremmel and it fit real nice without an adapter. I bought a new computer for it about a year before I took It off of my Mustang and paid $400 for it. I removed the FI before I sold the Stang and havent had anything to put it on since. ------------------ Toms River NJ -------------------- 71 custom 20 - 307 3onthetree-bone stock 56 working Street rod (under construction) 92 Olds 98 land yhat..(wifes) God bless Ironhead [This message has been edited by DennyB (edited 03-16-2001).] |
