Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-02-2009, 06:53 PM   #76
AJs72K5
AJs72K5's Avatar
Re: AJs 72 Pavement Pounder build
Originally Posted by jaros44sr View Post
Nice flat black VC's and air cleaner, got a closeup of the DS cowl, back of head. How much clearance is there?
Post up about prop. valve, curious to see how it works out
Nice improvements so far...
Driver's side is tighter than the passenger side. Even with the butchering the PO did to the firewall.
Will put more details up next weekend about the prop valve. From what I've read, most are gutting the factory prop valve and just putting the adjustable one inline on the rear brakes. Essentially what I have to do now, except I already paid $100 for a prop valve from Inline tube that was supposed to take care of this.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 02-02-2009, 09:59 PM   #77
jaros44sr
jaros44sr's Avatar
Thanks, will wait for your reply. By your answer, I take the PO didn't do a very good job on the cowl, hope I never turn into a PO
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-03-2009, 07:39 AM   #78
vtblazer
vtblazer's Avatar
maybe you should start a thread or sumthin'.
vtblazer is offline   Reply With Quote
Old 02-03-2009, 09:36 AM   #79
jaros44sr
jaros44sr's Avatar
Now that is just toooo funnie
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2009, 06:46 PM   #80
AJs72K5
AJs72K5's Avatar
UPDATE 02/07/09: The rest of my bday parts showed up. A friend with access to a waterjet cut some tow hooks for me. There is a serious cool factor about cutting metal with water. He did a killer job on them...no issues with fitment. 3/4" steel
Didn't get anything done on the brakes today cuz I was sick all week. The engine is having some fuel delivery issues too. More updates soon, I hope.
- AJ
Old 02-07-2009, 06:54 PM   #81
vtblazer
vtblazer's Avatar
Stout!
Now go out and find a reason to use em.
Old 02-08-2009, 01:52 AM   #82
Jtrux
I'm a poor spectator
Jtrux's Avatar
So what do you do, put d shackles through those holes?
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 02-08-2009, 03:17 AM   #83
BLUE THUNDER
BLUE THUNDER's Avatar
Dude those rock!!!!!! Can he make me a pair?
BLUE THUNDER is offline   Reply With Quote
Old 02-08-2009, 11:46 AM   #84
AJs72K5
AJs72K5's Avatar
You got it. The bottom hole is for a d-ring shackle.
- AJ
Old 02-08-2009, 09:31 PM   #85
BLUE THUNDER
Hey AJ, hook us up with the tow hooks. They are really sweet and totally functional. I need a set.
Old 02-08-2009, 09:56 PM   #86
AJs72K5
AJs72K5's Avatar
Was really a one time deal by a friend on another board. They were $150 (mostly from the waterjet time).
- AJ
Old 02-28-2009, 08:48 PM   #87
AJs72K5
AJs72K5's Avatar
UPDATE 02/28/09: Been kinda quiet the past month after the engine fire on 2/08. Most of the damage was to the hood, the firewall, the distributor cap, and a whole bunch of wiring. Huge thanks to everyone that offered support, help, and parts after the fire. You guys are great!
Here's the pics of the carnage.
The good news is that insurance covered most of the damage. So, I've spent the past couple of weeks deciding what direction to take with the truck. To fix the firewall properly, the engine would need to come out. As long as the firewall was getting worked on and the engine was out, "might as well" get the hacked up firewall patched correctly. So, I started tearing the front clip off to prep for pulling the engine. Here's how far I've gotten as of this afternoon.
If you look close under the dash, right above the tranny hump, you can see the sheet metal that is just screwed in to cover up the hole they cut.
A whole big mess of parts that came off
And well, I figured as long as the engine was out I "might as well" do a little upgrade. I picked this up used from a member from a fellow board member.
More to come...
- AJ
Old 03-01-2009, 03:03 PM   #88
BLUE THUNDER
Nice fuel injection set up. Glad to see insurance is covering most of the damage.
Old 03-01-2009, 06:56 PM   #89
lks dcvn
lks dcvn's Avatar
AJ - what else do you need to get it up and running again - maybe I got something you can use...shoot me a PM with what you need.
lks dcvn is online now   Reply With Quote
Old 03-02-2009, 11:00 AM   #90
vtblazer
vtblazer's Avatar
Old 03-02-2009, 12:32 PM   #91
Burt4x4
Burt4x4's Avatar
Throttle responce is amazing!!!!!!!!!!!!
I did take it to a Dyno shop for the final tune ~ highly recomend that, unless you're a super tuner
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-02-2009, 02:20 PM   #92
Jtrux
Jtrux's Avatar
Looks like it'll be better than ever. I look forward to hearing how it performs with the fuel injection.
Old 03-03-2009, 10:53 PM   #93
AJs72K5
AJs72K5's Avatar
Update 03/03/09: Got a little help from one of the guys at the shop tonight. The engine is out and the truck is ready to go to the body shop.
Closeup of the hacked up and bfh'd firewall.
More updates as stuff happens
- AJ
Old 03-03-2009, 11:59 PM   #94
BLUE THUNDER
Dude, I knew there was something about your Blazer that I was drawn to. The origional color is Ochre. Just kidding dude, are you gonna paint the whole thing? You're almost there.
Old 03-04-2009, 12:46 AM   #95
AJs72K5
AJs72K5's Avatar
Sorry man. Original color is orange. One of the POs painted it yellow, like bright yellow, at some point, but no ochre.
Plan is to paint the whole truck in a couple of years. Don't have the funds to do the paint job I want....especially after buying the fuel injection.
- AJ
Old 03-04-2009, 07:55 PM   #96
vtblazer
vtblazer's Avatar
Fix it & drive it, save the full on resto for later.
Old 03-04-2009, 08:38 PM   #97
AJs72K5
AJs72K5's Avatar
That's the plan
- AJ
Old 03-04-2009, 11:10 PM   #98
CTENTA1
Registered 1971 K5
On that close up picture of the firewall, i see some valve cover indents. is that the typical area you come across problems with installing big blocks? was that the case with you?
Nice truck!
CTENTA1 is offline   Reply With Quote
Old 03-04-2009, 11:33 PM   #99
AJs72K5
AJs72K5's Avatar
Nice truck!
Coercing a big block into a 1st gen K5 requires either some sort of "modification" to the firewall, installing a body lift, or moving the engine forward. Unfortunately what the PO did to mine is fairly common...although I have see a couple done considerably cleaner.
- AJ
Old 03-06-2009, 11:29 PM   #100
AJs72K5
AJs72K5's Avatar
Update 03/06/09: Finally off to the body shop.
Time to start ordering parts to get the engine setup.
- AJ
