Old 03-07-2009, 07:10 PM   #51
Hart_Rod
Hart_Rod's Avatar
Re: Parting 1971 Suburban (NM)
Originally Posted by MrGoodpliers View Post
I need one of the chromed plastic headliner bows. I like to use all push-in/bolt-on trim clips (ala 69-70) because they pull up nice and tight, unlike 71-72 that bulge and you see the tape. I'd be interested in all of them that you have.
Unfortunately all of the headliner and all of the bows are gone. I'll see how many of the clips I can come up with. Do you need the upper trim to?
Hart_Rod is offline   Reply With Quote
Old 03-07-2009, 10:57 PM   #52
sourkraut
sourkraut's Avatar
sorry, will have to pass on gauges.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 03-09-2009, 08:31 AM   #53
Hart_Rod
Hart_Rod's Avatar
No worries.
BTTT
Old 03-09-2009, 12:15 PM   #54
NPilot1975
NPilot1975's Avatar
Rob,
Found some pictures of what I need. It is the area of the inner cab where the sun visor mounts and the left side where upper fender mounts (the captured nut area.) I also need the entire dash, unbolted and the pinch welds drilled out at the windshield area. Let me know.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-09-2009, 08:48 PM   #55
Hart_Rod
Hart_Rod's Avatar
Originally Posted by NPilot1975 View Post
Rob,
How 'bout I bring you this.........
Old 03-09-2009, 08:57 PM   #56
NPilot1975
NPilot1975's Avatar
That looks about right. The cab is actually visually rust free. I will have to see once I start stripping it. How is the dash, is it AC? If you start cutting the burb up, I think the 2 patch panels I need would end up being pretty small.
Old 03-09-2009, 09:19 PM   #57
Hart_Rod
Hart_Rod's Avatar
Non ac dash. Radio has been cut for the new style radio. It will be easier for me to cut it across the rockers and roof. I can bring it when I come this fall.
Old 03-11-2009, 08:28 AM   #58
Hart_Rod
Hart_Rod's Avatar
bump
Old 03-11-2009, 08:56 AM   #59
jorgensensc
jorgensensc's Avatar
sent you a PM.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-12-2009, 09:11 AM   #60
Hart_Rod
Hart_Rod's Avatar
bttt
Old 03-12-2009, 10:48 PM   #61
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
Yes Rob, thanks for asking. I could use the suicide knob on the steering wheel..........hehe I will wait to see whats left and clean up the scraps like I always do. Talk to you soon my friend, Mike
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Old 03-12-2009, 11:04 PM   #62
mdunn
Do you still have the rear hatch latches? I need the two that bolt to the side of the top for the rear hatch to latch to for my 72 Blazer. Thanks for your help.
1972 Blazer CST 4x4
mdunn is offline   Reply With Quote
Old 03-13-2009, 11:01 AM   #63
Hart_Rod
Hart_Rod's Avatar
You saw that, huh?! That was the first thing I pulled off, . I'm not sure if I'm going to use it yet, if I don't I'll let you know. I'm getting ready to start chopping the Burb up in a couple of weeks, so send me your wish list, . Take care.
Are you talking about 1 or 2? Let me know.
Old 03-13-2009, 08:51 PM   #64
mdunn
Looks like the Burbs rear hatch mechanism is different than the Blazers. I was thinking they were the same. It would look something more like #2, but I can not see it that well. Sorry, maybe I am confused on the interchangability. Sorry for the confusion.
1972 Blazer CST 4x4
Old 03-13-2009, 09:06 PM   #65
Hart_Rod
Hart_Rod's Avatar
Here's a better picture:
Old 03-14-2009, 12:39 PM   #66
vectorit
What?
vectorit's Avatar
PM sent
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-14-2009, 07:12 PM   #67
mdunn
Thank you very much for the better picture. I can clearly see these are not the same as the Blazer. Thanks again for your time and help.
1972 Blazer CST 4x4
Old 03-14-2009, 11:07 PM   #68
jeremiah king
jeremiah king's Avatar
Hi Im in need of a good set of rear door panels for 3rd door and ds rear non door. how are yours? shipping to 92025?
jeremiah king is offline   Reply With Quote
Old 03-15-2009, 09:01 AM   #69
Hart_Rod
Hart_Rod's Avatar
Originally Posted by vectorit View Post
PM sent
PM returned.
No worries. I'm sure someone on the board has what you need.
Passenger side is good. Someone cut a 4" corner off of the drivers side, . The part that is cut off is behind the seat and hard to see. Let me know.
Old 03-16-2009, 08:29 AM   #70
Hart_Rod
Hart_Rod's Avatar
ttt
Old 03-16-2009, 02:44 PM   #71
Number98
Prestige Worldwide
Number98's Avatar
Just a friendly bump for ya Rob.......
Number98 is offline   Reply With Quote
Old 03-16-2009, 04:14 PM   #72
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Do you still have the rear wheel well inner tubs?
JJ
ChuckDriver is offline   Reply With Quote
Old 03-16-2009, 05:22 PM   #73
Hart_Rod
Hart_Rod's Avatar
JJ
Yes, what all do you need?
R/
Old 03-16-2009, 10:18 PM   #74
ChuckDriver
Would like to get the inner wheel well that bolts to the floor. It can be cut from the outer at the factory seam. I want to use them to mini-tub my 57 short bed.
Thanks,
Johnny
Old 03-17-2009, 10:12 AM   #75
Hart_Rod
Hart_Rod's Avatar
Thanks,
Johnny
PM sent.
