#1226 | |
I'm just glad to be here!
Re: My 1965 build thread
Still looking good...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#1227 | |||
1 thing at a time is progress.
Thanks, but I haven't figured it out yet. It came with the truck Quote:
![]() Quote:
Alan
Philippians 2:14-16 |
#1228 |
Sat around the shop tonight depressed and unmotivated. I finally got off my arse and did something. The booster will work out great (unless I'm missing something) with the wedge removed. It leveled it out and I can hook up the brake pedal rod. In the meantime I wanted to share this little trick, most of ya'll probably already know. It's basically the old way of making gaskets out of rolled gasket material. One of many things I learned from my Dad.
I wanted to make a template of the boosters bracket holes. So I wouldn't risk scratching the firewall. First lay a piece of paper over the part you want to template ![]() Once you locate and tap with a ball peen hammer lightly (the hammer cuts the hole out) install a bolt to lock the paper in place and repeat for the rest of the holes. ![]() ![]() Then use it for whatever you need it for. This is what I used it for. It not only locates my holes, but protects the firewall. ![]() Here is the booster angle now. ![]() Pedal rod adjusted to a drop fit with the brake pedal against the rubber bumper. ![]() Pedal rod is almost center of the hole. ![]() Also tweaked the right door at the top corner. I couldn't do it while fitting cause I would have pushed the cab off of the stand. So this is how I did it. ![]() Use a clean rubber hammer (no metal shavings) and use care doing this until you get a feel for it. Don't freak if you hear a little popping and cracking. Don't get mad at me if you screw something up. It's best to see it done first, but most don't have that luxury. Just take your time. When you push find a strong part of the door like the edge and use the palm of your hands to push. I've messed things up over my years, but I chalk it up to a learning experience and repair the damage done. ![]() After shot, it's better. ![]()
Alan
#1229 |
Member of the longbed union.
Looking good Alan, How did you paint your booster. I've heard it's really easy to screw them up with paint.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#1230 |
Alan, I'm just curious why you don't want to run the wedge and bracket horizontal like they came from the factory?
#1231 |
Registerd User
Good job Alan. They used a peice of 4x4 and a big hammer to get mine to fit.
#1232 | |||
![]() Quote:
![]() Quote:
Alan
#1233 |
got ya
#1234 |
Shloooooong bed member #2
Alan, by looking at your pictures I have figured out two things for you.
1-I know why your door won't line up. 2-I know where your missing rubber mallet is. See attached picture. ![]() Really nice work Alan, Thanks for sharing your secrets.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
#1235 |
Hey Y'all!!
![]() Nice work Alan!
Just hopin' I live long enough to finish something!!! |
#1236 |
Sunburst C10!!!
Does IMHO mean in my honest opinion??
Gage 1967 C10 Shortbed Stepside |
#1237 |
![]() Join Date: Mar 2008
In My Humble Opinion from what I understand but honest is good too
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
#1238 |
Sunburst C10!!!
thanks
#1239 |
Nice work.......Alan
#1240 |
Thanks Tim
![]() Thanks, glad you found it. I love this place. Stop by sometime.
Alan
#1241 |
Happy birthday to me, Happy birthday to me, Happy Crapday dear Alan Happy Crap day too me........
I had all intentions of getting some crap done today, but the crap got me instead. I was on here this morning waiting for the wife to get out of the shower and I heard the down stairs toilet bubbling............What the heck (I new what it was, but didn't want to admit it on my day.) I grew up on a septic tank and never had it pumped. This new one lasted 8 years. I found out these new divided tanks need to be pumped every 3-5 years. It was packed full on the inlet side. The guy said you could probably walk on it. Nah that's alright. ![]() That's gonna set back my parts buying even more. ![]() I removed all the rock I just put down cause I knew they wouldn't take their time with it. The tank had 2 about 18"x18" concrete plugs for access. It has been years since I had seen a septic tank. The last one I saw had 3 sections that made up a lid. And the new one even had a filter on the exit end. I couldn't believe it. ![]() The man at work ![]() All finished ![]()
Alan
#1242 |
Sunburst C10!!!
Happy Birthday Alan its my little bros also
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 05-31-2009 at 04:09 PM. |
#1243 |
![]() Join Date: Jan 2009
Happy Birthday Alan and sorry to hear about your septic system.
I had the same problem with the door seals on my '63. After I glued the seal into place, the door would not close. I basically just pushed the seal on, no tension, when I got to the end I had about 6” inches left that I cut off. I let it sit for about a week also thinking the compression of the door would fix it. It didn't. I finally pulled the seal off and then put it back on with a little tension. When I got it glued back in place I had another 4-6” of slack. I think it's got to be put on somewhat tight, just not sure how tight. I know that's not a lot of info but hope it helps. Great progress!! Don
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 05-31-2009 at 04:45 PM. |
#1244 |
Daring to be Different
HAPPY BIRTHDAY ALLAN. It sucks to have that happen on your B-Day.
I just had the Metzler rear tire on my bike grow a bubble the size of a hand ball. It happened in Palm Springs, and had to have the bike towed home. There goes some of my parts money too. ![]()
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#1245 |
Happy B-Day to you......
![]() ![]() ![]() ![]() ![]() Talk about a S***y party!!! ![]()
#1246 |
You was not kidding yesterday when you told me to stick around and I could help do some digging. Hope everything come out alright. Happy birthday Alan.
#1247 |
Happy birthday septics suck sometimes..
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#1248 |
#1249 |
One day...
Happy Birthday man!
#1250 |
Happy Birthday Alan!! Great looking truck btw!
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
