04-14-2009, 05:28 PM | #26 | |
67-72 parts collector,…
Re: Project: NO-LIFE,...
This truck will eventually be a 5-lug truck like I had originally planned. My 71 rearend ended up being junk. (too much money to justify rebuilding for this truck) I have a certain set of wheels in mind for it that require it to be 5-lug. As soon as I can find a cheap rearend the 6-lug wheels will come off. (my "pet peeve",... it the track width of these trucks not being addressed when selecting wheels) I had originally planned 15x7's and 15x10's to help pull the rear wheels out to the edge of the fender wells, to match the front. I've had this assortment of parts for quite a while,... waiting for the right truck to come along. I'm determined to keep it a low buck project. The first thing out of most peoples mouths is, "When are you going to paint it?" They don't understand when I say "never". I want a truck to drive, haul junk, and use. This ones perfect. It just needs a little more work. Someday the blazer will get a frame off. But really,... it's just a beater too.
04-14-2009, 05:41 PM | #27 |
Blaze-Air
Your Blazer is a sweet beater. I bet if you just put a few pieces of sheet metal on it, you would do a reclassification upgrade to it. That truck is very straight. To me, I think a beater is a vehicle one can park in a shopping mall lot and door dings won't stress you out...BTW 454/TB400 for 69
04-14-2009, 07:20 PM | #28 |
VA72C10
I like the idea of keeping it the way it is and USING it. Some people get a 90's S10 or toyota or 80's/90's pickup and use that as their "Beater" Why spend a couple grand on one of those when you can have a 67-72 and slowly fix it the way you like and it will grow in value...
I am looking for a "beater/work truck" right now and plan to do similar (Lower, good drivetrain, and no/cheap paint) I would love to find one in your trucks' condition for a deal but most I find need some paint so I'm planning a satin black for now unless I luck out.
Looking for a 67-72 swb or blazer project in or around VA. |
04-19-2009, 01:17 AM | #29 |
I got a PM wanting a few in "progress pics" of the suspension work.
I realize now I didn't take too many. The a-arms and front shocks are the old ones I took off the blazer. Front 6-lug rotors and "conversion" brake hoses are from ECE. Calipers are new '73 calipers (cheaper than 71-72 calipers) from my local parts store. Here's a few,...
04-19-2009, 01:25 AM | #30 |
I should have taken pictures before I put the bed back on.
04-19-2009, 01:33 AM | #31 |
Here's a shot of the low point of the truck. The a-arms.
I have cheap Summit Racing brand 3" drop springs (actually made by Ground Force) and McGaughy 71-72 drop spindles. The tie rod sleeve is a conversion sleeve made by POL (Performance OnLine). It's required to connect the inners to 71-72 outers. Actually the inners are 67-70 "outers" used as inners for the correct thread. (long story,... but neccessary) I also went with manual disc brakes due to the position of the 6-cylinder stock air cleaner. Also,... I stole this idea from member tcb-1. (for a cleaner look).
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-19-2009 at 01:36 AM. |
04-19-2009, 04:44 PM | #32 |
Lookin good so far.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
04-20-2009, 01:57 PM | #33 |
Tot Roddin'
Now I have two manual setups to work off of.... I still need to get up there and see that thing. Awesome work on plumbing the brake lines, clean as can be!
I have been tempted by Joe with that air cleaner...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-27-2009, 02:16 PM | #34 |
Re: Project: NO LIFE,...
A little update on project NO LIFE:
With the help of many board members, and vendors,... I finally got the interior back together on my '69 swb project. I had a buddy stop by and help me set the seat back in. A good friends son installed the PUI seat upholstery that I got from member Musclerodz. I installed a rubber floor mat from Brothers. (Not exactly like an OEM mat, but that's ok) Other new parts include, new window and door weatherstrips, window regulators and door controls, all new interior and exterior door handles, stainless sill plates, new gas tank cover, all new pedal covers, new dash bezel and lense, 3-spoke cushion grip steering wheel, and a refurbished tilt (Thanks, KevsClassics!) I got alot of used parts from the classified section on here. (Worlds best place to find parts) I also installed new/used door arm rests, defrost vents, glove box door, (and a spare dash pad not installed yet), seat belts, and I'm sure I forgot something. Also a big thanks to Tim Christian. I waited for a month for my local Goodmark dealer to get me a rear sport bumper, (still waiting?),... so I called Tim and I had one in three days. Great service. Just installed the offical "NO LIFE" plates also. Here's a few pics,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-27-2009 at 02:22 PM. |
07-27-2009, 02:38 PM | #35 |
VA72C10
Nicely done. That looks great!
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 07-27-2009 at 03:50 PM. Reason: typos |
07-27-2009, 03:18 PM | #36 |
Under Construction
looks good!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-27-2009, 04:09 PM | #37 |
Blaze-Air
Wow that looks great. The tilt w/cushion grip wheel is very nice touch. Great job!!!
07-27-2009, 04:35 PM | #38 |
Coming along nicely, I like the look of the rubber mat in there, basic.
I'm going to need a full rear 3/4 view pic of the truck to truly enjoy the sport bumper. You really have me considering bringing my truck down a bit more.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 07-27-2009 at 04:37 PM. |
07-27-2009, 04:53 PM | #39 |
Thanks for the comments.
Rubber mat doesn't fit that great. Too wrinkly around the hump area for a "low hump" mat. And it doesn't look like an original GM mat. It looks more like a "rubber version" of carpet. Plus it comes way oversized. Alot of trimming involved. I may change it out if I go with a "high hump" and th-400 tranny.
07-27-2009, 06:31 PM | #40 |
Blaze-Air
07-27-2009, 06:55 PM | #41 | |
07-27-2009, 07:05 PM | #42 |
nice!
07-27-2009, 07:05 PM | #43 |
07-27-2009, 07:21 PM | #44 |
Blaze-Air
So you found a home for the BB you have?
Has it got to the point of need more than want? |
07-27-2009, 07:43 PM | #45 |
Tot Roddin'
That turned out great!
Glad to see you had some help drop by this weekend.
07-27-2009, 08:18 PM | #46 | |
I have my old 454 that I pulled from my 67 Camaro. It's a low miles '74 truck motor that still has the standard bore. (lower end has never been apart) I think I can do a re-ring/and bearings,... and have the heads checked out for not too much money. It has an old 268 Comp Cam that should be fine in this truck. I really wanted to do a small block,... but I can't find one that doesn't need a rebuild. So I'll use what I have.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-27-2009 at 08:19 PM. |
07-28-2009, 06:38 AM | #47 |
Really nice
70 SWB STEPSIDE 70 BLAZER 09 challenger |
07-28-2009, 06:53 AM | #48 |
Looks good, you are keeping the out side as is right!
Kevin LFD Inc. |
07-28-2009, 07:36 AM | #49 |
Correct. Not touching the outside.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-28-2009 at 07:37 AM. |
08-03-2009, 09:44 AM | #50 |
'69 Chevy SWB
I wouldn't either Keith, it's perfect!!
