Old 08-17-2009, 08:14 PM   #1
heiny0
Cab Mount Hockey Pucks????
Is it true that you can use hockey pucks for cab mounts? if so how thick would the need to be. please help thanks
heiny0 is offline   Reply With Quote
Old 08-17-2009, 09:48 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Cab Mount Hockey Pucks????
http://www.google.com/custom?domains...D%3A1%3B&hl=en
LockDoc
Leon
Old 08-18-2009, 06:08 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
welcome to the forum from central Ohio!
a puck could be used... but it isn't the best idea...
Old 08-18-2009, 06:35 AM   #4
cdowns
cdowns's Avatar
you could get a bonch of used boots and cut up the soles for mounts too// why bother original replacements are available cheaply to do the job correctly
welcome to the board. OAKDALE?? is that the long island one?
Old 08-18-2009, 11:21 AM   #5
Naterman35
A Canadian body lift.
One puck is close to the stock height of the bushing. Adding multiple give you a body lift. Each puck is a inch of lift.
Look at most body lifts... There longer bolts and rubber peices. So you want that 3" body lift then enough hockey pucks for 4 on each mount and longer hardware.
Naterman35 is offline   Reply With Quote
Old 08-18-2009, 12:10 PM   #6
au03z71
au03z71's Avatar
Famous last words...
au03z71 is offline   Reply With Quote
Old 08-18-2009, 02:28 PM   #7
mclairmo
You can also buy one inch aluminum donuts for about $5 each online. I plan to buy them when i lift my body one inch.
mclairmo is offline   Reply With Quote
cab, hockey, mounts, puck, pucks
