08-14-2009, 11:43 AM | #26 |
Re: Any 12 sec daily drivers
I don't know, but I think it's a better idea to have a set of wheels/tires for the strip, and just switch them when you get there. Also, just noticed you have 17's, so now I really have no idea.... sorry for the confusion Have you checked out BFG Drag Radials? Last edited by Jim_PA; 08-14-2009 at 11:45 AM. |
08-14-2009, 12:41 PM | #27 | |
If its going to be a huge pain in the butt to make the truck a 12 sec DD then I was going to just make it a nice DD & shop for something else later. Traction seems to be the huge issue to overcome with a truck build. Last edited by CB24; 08-14-2009 at 12:45 PM. |
08-14-2009, 01:20 PM | #28 |
Don't have any track times, but to me, even tho I am curious, it really doesn't matter. After a 35 year wait, a rather large investment in the engine, and in this late stage of my life, we would rather cruise and enjoy than race her and risk breakage at any given moment. She is driven daily with some road trips, usually not more than 120 miles round trip.
383, Eagle forged crank, Crower 5.7 Stroker Sportsman rods, 8:1 Aries blower pistons w/-28.73 cc dome, Isky blower cam, World heads, Weiand 671 blower, BDS 8 nozzle bug catcher controlled by FAST ECU, TH400 w/trans brake, 3400 stall, 4.88, spool, 31x18.5R15L Hoosier Pro-Street Radials on 15x14 Convo-Pros. Joe |
08-14-2009, 01:35 PM | #29 |
On a budget like Fred Sanford
Drag radials were designed for automatic transmissions.....don't waste your time/money on a drag radial if you have 3 pedals. Not saying it can't be done, but it's HARD. Everything else has to be dead nuts to make 'em work. Bias ply's are the ticket with a clutch. ET Streets are DOT approved.....I dead hook with them on 6800rpm clutch dumps in my camaro.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
08-14-2009, 09:57 PM | #30 | |
motor exploder
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
08-14-2009, 09:59 PM | #31 |
motor exploder
you sir, are one BMF!!!!
08-15-2009, 03:33 AM | #32 |
hi from the uk
just finished building c30 full size crew cab weighing almost 3 ton fitted merlin 572 mild tune so great on street with a turbo 400 transbreak runs pump gas runs 13.06 @102mph going to make some bigger headers and change rear gears so should just dip into 12 soon can be seen on youtube under merlinman572 |
08-22-2009, 02:20 PM | #33 |
My truck was a daily driver when I ran 12.8 a while back. It was a 82 C10 with a stock 6.0L with a small cam. I had tons of problems with the truck at the time, so I'm sure it could have gone much faster.
There's guys running 12's in extended cab trucks with 5.3L engines...and still daily driving them. So you may want to check out these Gen3/4 motors.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 08-22-2009 at 02:20 PM. |
08-29-2009, 06:52 PM | #34 |
At the body shop.
Guess i oughta go looking around more been hanging out on the 73 board 12.20s 1.67 60ft and driven 45 miles each way to the track
" That didnt make it any newer " " Dont antique the equipment " |
08-30-2009, 05:21 AM | #35 |
Dr. Frankenstein
jesus that looks like a tank?..... what gets it moving so nice?
I Wanna Go Fast!! |
08-30-2009, 02:54 PM | #36 |
At the body shop.
9.5:1 sb 400 th475 9inch cal trac bars and 325/50 drag radials
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 08-30-2009 at 02:56 PM. |
08-31-2009, 10:32 AM | #37 |
I saw a bb twin turbo,d,injected street rod that drives on the street and does the quater in 8 sec.was wild,I guess ther isn,t much power until the turbos wind up so he can drive it fairly normal
08-31-2009, 09:34 PM | #38 |
You can cruise around all day with a 1000 hp cars on the street with a turbo setup.
http://www.nelsonracingengines.com/
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
08-31-2009, 10:35 PM | #39 |
12.40 S ON MOTOR YES I DRIVE IT, SUM TIMES
http://i648.photobucket.com/albums/u...Picture008.jpg |
09-01-2009, 08:28 AM | #40 |
What ya got in it to get those times?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-01-2009, 03:06 PM | #41 |
Dr. Frankenstein
hmmmmm i bet a big turbo or two smaller sized ones would move along quite nicely when hung on a big block.....**** here goes another transformation for my 55'
I Wanna Go Fast!! |
09-01-2009, 06:33 PM | #42 |
468 , glide , 373 gear
02-01-2010, 01:57 AM | #43 |
Ready to go fast!!
72 super.... what kinda power are you making?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
02-01-2010, 06:38 PM | #44 | |
1977 GMC Sierra Grande |
02-01-2010, 07:24 PM | #45 | |
Like I said though, there are people that make drag radials work in stickshift/transbrake cars and are going FAST with them. With a well prepped track and optimally set up car they'll work just as good as a bias ply, and likely will end up being a little faster on the big end. My personal experience with DR's and clutch dumps is they would dead hook and then immediately unload, followed by wicked tire shake. Got sick of doing it the hard way and went to ET Streets, gets outta the hole good now.
02-01-2010, 07:51 PM | #46 |
It is definitely tough with DR and a stick. A DR will hook up better then a standard radial. If you are only worried about going fast in a striaght line don't bother with DR.
02-03-2010, 01:38 PM | #47 |
You have the same problem I do...too much torque, not enough tire! A 275 50 R 17 is about 11 in wide and 28 tall. I run 285 60 R 17's which are 11 wide and 31 in tall. You can probably find something like these which do just about as well as a slick but they are D.O.T. legal :
02-03-2010, 02:00 PM | #48 |
My 67 shortbed stepside has a curb weight of 3255 lbs. My 2008 Corvette is 3400# so these trucks are not that heavy unless they're 4WD or have a monster motor up front. The factory lit shows 2700-3300 # delivery weight depending on no bed, stepside or fleetside and a GVW of 4400 #.
02-04-2010, 12:24 AM | #50 |
Ready to go fast!!
regan our trucks look very close!!! except mines a 72...
