Old 10-18-2009, 12:01 PM   #126
HotRodYJ
HotRodYJ's Avatar
Re: Cross Member Drop?
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 10-18-2009, 12:16 PM   #127
joe231
joe231's Avatar
Have you test fit the engine with the York in your frame? Looks like it might hit the frame....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 10-18-2009, 03:15 PM   #128
HotRodYJ
HotRodYJ's Avatar
I did take measuremements. In my set-up it will be very close to the upper control arm bushing but yes it should fit. Remember my motor sits higher above the frame rail than anyone elses.
Old 10-18-2009, 06:48 PM   #129
joe231
joe231's Avatar
Oh yeah
I didn't realize it sat that much higher...
CHEVY ONLY
Old 10-18-2009, 08:39 PM   #130
HotRodYJ
HotRodYJ's Avatar
Fits like a glove...
Old 10-18-2009, 08:48 PM   #131
joe231
joe231's Avatar
Very nice!!!
CHEVY ONLY
Old 10-18-2009, 09:07 PM   #132
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very cool man that ride is really progressing..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-19-2009, 10:52 PM   #133
Tagg33
Tagg33's Avatar
The York looks great there, too bad we all can't put it there.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 10-20-2009, 01:09 AM   #134
Frizzle Fry
Frizzle Fry's Avatar
Three-deuces and a serp, very cool! Nice job on the York mount and pulleys.
Frizzle Fry is offline   Reply With Quote
Old 10-20-2009, 01:14 AM   #135
Tagg33
Tagg33's Avatar
Do York's have to be mounted vertically like you have it or could it be 90 degrees left or right too? Seems like every York I have seen mounted is vertical does that have to do with the internal oiling?
Ryan
Old 10-20-2009, 06:48 AM   #136
HotRodYJ
HotRodYJ's Avatar
From everything I have read they can be mounted either way and I initially planned on laying it horizontal, but then if you think about the oil laying in the crankcase portion of the thing, just laying there on it's side it seems to me the oil would tend to leak past the piston and into the chambers. In my mind vertical is the best way so this can't happen.
Old 10-30-2009, 10:19 AM   #137
HotRodYJ
HotRodYJ's Avatar
Finally got money in my pocket, drawing of the bed sides I need and Half of a rear fender in my truck ready to drop off at the sheet metal shop today to get everything I need for the stretched step side bed and fenders. Wouldn't you know it, they're closed on Friday's. Looks like it will be Monday before I can get this stuff underway. Dang it!
Plan is since I have to go to the shop to buy the new metal sheet anyway, why not just let them bend it for me too since they've got the equipment. So I will get brand new bed sides which is simply flat sheet with a 90 degree bend and then a roll at the top. Then for the fenders I cut one of mine in half and I'll let them bend me a pair of 32" long panels which match the cross section of the fender half that I give them. Then all I have to do is weld in the extension panels and the fenders will be done. I'll remove the stock stake pockets from my old bed and weld then to the new bed sides and they will be basically done as well.
I can't wait!
Old 10-30-2009, 11:56 AM   #138
joe231
joe231's Avatar
CHEVY ONLY
Old 11-04-2009, 07:56 AM   #139
TimE
Hey Y'all!!
TimE's Avatar
Just got through catching up on your build. Looking good!!
Any updates?
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 11-04-2009, 08:03 AM   #140
HotRodYJ
HotRodYJ's Avatar
I did drop off my "order" at the sheet metal shop Monday. Waiting to ge the phone call that it's ready to pick up then I can get back into metal work. That beats body work any day!
I'm hoping today might be the day, but I wont know till the phone rings. You can't push these guys of it will cost you double. Whenever they work it in is fine by me.
Old 12-06-2009, 10:02 PM   #141
HotRodYJ
HotRodYJ's Avatar
I finally now have the sheetmetal for the new longer bedsides and fender extensions. The hardest part is finally off to a really nice start. I only had enough time this weekend to weld up one of the fenders but it went really well...
Old 12-06-2009, 10:21 PM   #142
joe231
joe231's Avatar
Nice work
that looks good
CHEVY ONLY
Old 12-07-2009, 12:13 AM   #143
Captainfab
60-66 Nut
Wow those are some nice looking pieces that you had made......nice job welding it up too. Those look like they would be a real b***h to make.
Old 12-07-2009, 03:39 AM   #144
tdave00
Restoring a 68 SWB
tdave00's Avatar
Wow! Did you make those pieces? They fit great.
BTW...I picked up a set up of those shorty headers a few weeks ago. I test fit them and it looked like it might be a tight fit hooking them up to the exhaust because the headers come close to the crossmember. Thoughts?
tdave00 is offline   Reply With Quote
Old 12-07-2009, 04:44 AM   #145
Frizzle Fry
Very nice work on the fender extension.
Old 12-07-2009, 08:11 AM   #146
HotRodYJ
HotRodYJ's Avatar
No I had a local sheet metal shop bend them for me. They also bent new bed sides for me. The bed sides are 9'-4" long. They could not do the roll on the tops of the bedsides, so I will be welding a stick of round tubing there instead to finish them off.
On the headers, Mine won't be hard to hook up at all with a tight radius bend. I honestly haven't looked at that very hard because it doesn't look like it will be a problem for me. In a stock application I don't know.
Old 12-07-2009, 04:08 PM   #147
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I'm really diggin' this project!! Keep up the great work on this one of a kind BEAST!!
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 12-07-2009, 08:45 PM   #148
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
that fender looks great. keep up the great work!
Mordachai is offline   Reply With Quote
Old 12-29-2009, 03:22 PM   #149
justpball
justpball's Avatar
coming along great!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 12-29-2009, 09:58 PM   #150
HotRodYJ
HotRodYJ's Avatar
Both fenders are now stretched and I built one bedside today. Goal is to have the bed basically together and maybe sitting on the truck by end of the weekend. We'll see.
Also got 4 new air bags ordered along with a long skinny 5 gallon air tank that will go behind the rocker panel outboard of the frame rail on passenger side. Should be here by end of week.
