11-21-2009, 01:40 AM | #52 |
Re: 79 C10 swap with L92 with 6L90
New detailed pics.
Took the fenders out and we are waiting got radiator support to be delivered on monday so we can start to fit the esclade radiator on it. Custom Transmission Cross-member Transmission looks comfortable Hope everyone have a great weekend Last edited by v502; 11-21-2009 at 01:41 AM. |
11-21-2009, 10:27 AM | #53 |
nice! have you tried to put on the a/c compressor yet? and how long is that new tranny? looks like the new crossmember is quite a bit forward away from that bend on the driverside framerail. i was worried about the 80e being so long that the mount would have to be on that bend. looks great man! cant wait to see mine sitting in there like that.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
11-21-2009, 10:52 AM | #54 |
Still plays with trucks
Griffin makes a direct fit radiator for our trucks that has the trans cooler built into it. $585
http://www.summitracing.com/parts/GRI-6-573AR-BAX/ You don't need the custom LSx car style custom built one with inlet & outlet on the passenger side. You can use the truck style long upper hose that crosses over to the driver side and use a standard configuration radiator.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
11-21-2009, 11:19 AM | #55 |
subscribed
11-21-2009, 11:26 AM | #56 |
thanks for posting that link 68TT! saved!!
11-21-2009, 04:18 PM | #57 | ||
I don't think the bend is there anymore cuz i think they smoothed them out cuz i was under there was no bend and the frame had some work done to it i will ask about that for you menace cuz once i saw the trans was in i just didn't ask cuz and i got my self worried about something else as usual Hopefully the link might help you i know its comparison with 4l60 but that might give you an idea http://www.ls1tech.com/forums/conver...80e-6l90e.html I am not going to use the a/c compresor cuz i have to fabricate the frame and am i dont want to do that. I going to use the S&P bracket Quote:
11-21-2009, 06:53 PM | #58 |
67-72 parts collector,…
Just found this build thread.
Wow! What is your budget for this build? $20k? You sure aren't scared to spend the cash. I'll be watching this one!
11-22-2009, 03:06 AM | #59 | |
I am pushing my budget to the limit not because of this project but cuz i took the chance and worked on two of my cars on the same time the other one is done and had to step back on couple of stuff on the truck cuz my bank account is bleeding |
11-22-2009, 10:34 AM | #60 |
thanks for the reply and link. its hard to tell where the mounting positions are. guess i'll just wait and see
11-28-2009, 12:55 PM | #61 |
nice work.
11-28-2009, 06:22 PM | #62 |
FYI on the radiator, on my 86 when I swapped in the LT1 I measured the stock radiator and ordered a aluminum radiator from Summit. They have universal ones in various sizes, When I ordered mine they were less than 200 bucks. I made some brackets out of 1 inch angle aluminum. Late model Camaro fans bolt up to it like they were made for it. Use a stand alone trans cooler and you will have a bullet proof cooling system for cheap.
I'll go snap a pic, the radiator is out of the truck now. |
11-28-2009, 06:31 PM | #63 |
Here you go, excuse the dust. By the way, the radiator is 31x19 overall. The core is about 26 inches. Leaves plenty of room for AC lines on the right side.
12-01-2009, 03:46 AM | #64 |
Update
Thanks Ceeten for info i already got mine figured out. After alot of thinking i made up my mind on my exhaust design. I wanted something diffrent. I made it that way cause i don't want the sound to be under the car. The muffler will be more on the quieter side. I switched the side of the cutouts so it can flow more and gives me a nicer tone. The exhaust tips will come out before the rear tires. The radiator support The esclade radiator with electric fans. Custom made brackets we used esclade bushing is totally newer different design we got them just to complete the package. We tried the esclade A/C condenser but i was kinda big so we went with universal one hopefully it wont be as hard to fit. Lower pic is brackets. Last edited by v502; 12-01-2009 at 04:05 AM. |
12-01-2009, 03:59 AM | #65 |
We got the new drive shaft. It was heavy and looked beefy.
I got the Posi-trac with 3.08 gears. The old stuff is on the right and the new stuff is on the left. New Battery bracket my old one was rusty. Corvette fuel filter on left and Bosch fuel pump on the right. Last edited by v502; 12-01-2009 at 04:06 AM. |
12-01-2009, 10:36 AM | #66 |
very impressive update buddy! i love the exhaust idea
and the core support looks awesome!!
12-01-2009, 11:36 AM | #67 |
I would definitely just use the bungy cords to hold the radiator .
Seriously, it is coming along really smoothly. What made you choose a 3.08 gear, especially with that transmission? Ed |
12-01-2009, 12:15 PM | #68 |
Ed[/QUOTE] I was wondering the same thing? I would have thought at least 3.73.
I can still count my vehicles on two... wait three hands. |
12-01-2009, 12:37 PM | #69 |
The 6L80 & 6L90 only have a 33% overdrive but their first gear is really low at 4.027 and second is almost the same as a T-400's first gear at 2.364 so the 3.08's will do fine.
It will have the equivalent first gear ratio of a T-400 running 5.00 gears.
12-01-2009, 01:14 PM | #70 |
Holy Crap! That is a short first gear. The Sierra Denali uses a 3.42 rear gear.
6L80e 1st Gear 4.027 2nd Gear 2.364 3rd Gear 1.532 4th Gear 1.152 5th Gear 0.852 6th Gear 0.667 Reverse 3.064
12-01-2009, 01:21 PM | #71 |
That's a heck of a jump from 1st to 2nd, but I now kinda understand the 3.08 gear. I still think I would have gone a bit steeper though .
12-01-2009, 03:56 PM | #72 |
Thanks guys
The truck originally had 2.76 which i was going to keep but i was worried that it keep shifting between 5 & 6 with road waves so i thought 3.08 will be nice. If i feel that the truck is lazy i change sometime. |
12-01-2009, 04:08 PM | #74 |
At 65 mph and assumed 28" tall tires you will be at 2046 rpm in 5th and 1602 rpm in 6th so I think it will probably stay in 6th on the freeway with the power that L92 makes. With shorter tires it will definitely stay in 6th.
Tags |
6l90, l92, swap |
