11-27-2009, 04:22 PM | #1 |
California Quadrajet?
Question for the Quadrajet gurus on here. I was running the numbers from the Quadrajet on my '72 GMC and came up with something interesting. 7040511. As far as I can decipher, this carb was made in 1970 and is a California emissions carb. What is the difference between it and a regular Quadrajet? Can I rebuild it back to regular specs or should I look for a different core?
And no, I'm not interested in putting a Holley or Edelbrock carb on it!
-Tony Money is no object... once it's in your wife's hands. 1972 GMC Sierra 1977 Ford LTD II 2000 Pontiac Grand Prix (wife's ride) |
11-27-2009, 04:46 PM | #2 |
Re: California Quadrajet?
Its probably just a little lean. When you build it check the size of the main metering jets. They usually run about .072-.073. There are variations in the metering rods but I'm not familiar with the sizes. You may want to decrease the tension on the sec. air valve springs.
11-27-2009, 04:47 PM | #3 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
