Old 11-15-2009, 10:11 PM   #1
463
463's Avatar
a space saver work bench
here's what i installed on the wall of the shop. it's a 3'x7' solid wood door with a lexon tuff top. this is attach to a hinged to a 2x4 that is lag bolted to the wall studs. folded down work hight is 36". there is two free hinged angle iron legs mounted to the under side of the door that free swing under there own weight as the door is moveing from the up to the work position giving the bench it's support. to put the work bench back out of the way i just lift the bench up till it's vertical and the legs move with the bench then the latch locks and holds it secure it it's storage position. the 2nd work top is 48" wide and 22" deep. it to is hinge to the under side of the fold up bench useing loom cover chain to hold it in the horizontal position. there is a fix mount light behind the small tool storage shelf for the 2'x4' work top. i added this as a extra smaller bench as when a truck is in the bay. the main 3'x7' bench is to tight to work around. i also ran a power cord to the outside edge of the bench for power tools. i think that 800 lbs would not be to much of a load for the main bench. the small 2x4 top will hold 80 lbs. the nice thing about this it out of the way till i need it and when i need it it's clean and ready to go at a moments notice.
Trueman
463 is offline   Reply With Quote
Old 11-15-2009, 11:21 PM   #2
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: a space saver work bench
Good Job, Thanks for Sharing......
I like the Fact that it would always be Clean to work on , Fixed location work tables always seem to become a catch all
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 11-17-2009, 02:33 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
That is an awesome idea. Well done!
Frizzle Fry is offline   Reply With Quote
Old 11-17-2009, 07:23 PM   #4
jjjmm56
jjjmm56's Avatar
Cut a big hole in the wall and it will be self cleaning.
jjjmm56 is offline   Reply With Quote
Old 11-17-2009, 09:30 PM   #5
1lowdiesel
1lowdiesel's Avatar
isn't that just nifty. nice work.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 11-18-2009, 01:19 PM   #6
UltraBlue71
UltraBlue71's Avatar
Sweet Idea, I might just benchmark it from you.....
As they say imatation is the most sincere form of flattery....
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 11-28-2009, 12:12 AM   #7
mvfd70
mvfd70's Avatar
My problem is I would never be able to fold it back up. I can't find the top of my workbench now. Good idea though. I like it.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
