Old 12-23-2009, 11:01 PM   #1
jnesto
!966 C-10 Drums
I am trying to change my six lug rear drum into a 5 lug and i was wondering if i could just simply change just the drum part were the lugs are located?
MARRY CHRISTMAS!!
jnesto is offline   Reply With Quote
Old 12-24-2009, 01:20 AM   #2
jgarverick
Re: !966 C-10 Drums
the lugs are on the axle itself. you would have to swap them or redrill for 5 lugs and use 5 lug drums. pretty sure thats right. can anyone confirm?
Jason Garverick
64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread
69 AMC Javelin 360/auto - 417 stroker (soon)
68 Scout (Basketcase)
06 Ram HEMI SWB Reg Cab Daily Driver
US Army Vet
jgarverick is offline   Reply With Quote
Old 12-24-2009, 02:00 AM   #3
LILRED66
LILRED66's Avatar
Re: !966 C-10 Drums
Correct indeed, Grasshopper.
LILRED66 is offline   Reply With Quote
Old 12-24-2009, 02:09 AM   #4
NF65Fleetside
NF65Fleetside's Avatar
Re: !966 C-10 Drums
Have to do a complete rear swap or replace the axles. here is a fairly priced kit from CPP
http://www.classicperform.com/Store/...k/6569RACK.htm
NF65Fleetside is offline   Reply With Quote
Old 12-24-2009, 02:33 AM   #5
jnesto
Re: !966 C-10 Drums
thats the thing the lugs are not on the axle they are on the drum part. if i take the drum of the lugs come off.
Old 12-24-2009, 02:45 AM   #6
Captainfab
60-66 Nut
Re: !966 C-10 Drums
Something doesn't sound right here. On a C10 the wheel studs are pressed into the axle flange. Is the axle and all coming out with the drum? You can convert to 5 lug, but you first have to change out the axles to aftermarket 5 lug axles. Then you can upgrade to the larger 5 lug brakes by changint the backing plates, drums and all internals. This should be able to be found at a local wrecking yard.
Old 12-24-2009, 03:07 AM   #7
NF65Fleetside
Re: !966 C-10 Drums
Its not that simple....this kit is splined to work with the OEM rearend. Even if you go to a shop they still respline your originals and or fit adaptor style backing plats. Its almost better to do it correctly and just get a new rearend off a donor...this way you can get better freeway gearing too! BUT the kit is descent too.
Old 12-24-2009, 09:08 AM   #8
jgarverick
Re: !966 C-10 Drums
what model rear do you have? it sounds like its not a 12 bolt.
Jason Garverick
US Army Vet
Old 12-24-2009, 11:18 AM   #9
62gmc910
62gmc910's Avatar
Re: !966 C-10 Drums
Me thinks we're havin' terminology issues here
The brake drum is just the the "capped tube" about 11 by 2 inches on the end of the drive axle. the drive axle holds the wheel studs (another missname because they are spline cap srews) Any production 1/2 ton rear drive axle assembly (also shortened to axle to add to the confusion) that I, and I would guess most of us, have seen have the wheel stud drawn thru the axle shaft's flanged end.
6 bolts were mentioned which on a 66 chev or canadian GMC should indicate a semi floating GM corporate 12bolt (named for the 12 bolt cover pan)
Does this put us all on the same page???
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-24-2009, 03:43 PM   #10
ravens65
ravens65's Avatar
Re: !966 C-10 Drums
CPP for the front and a Trans/Am rear end swap 4 wheel disk - that the ticket - if interested I can walk you thru it
Chow Eric
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline   Reply With Quote
