Old 01-19-2010, 08:14 AM   #351
0331grunt
Now what??
0331grunt's Avatar
Re: 1967 C10 Custom Big Window
Looks real good. I like the lines and insulation. I will probably bend my own lines. My stock ones are ok, but I "might as well"..
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 01-19-2010, 12:20 PM   #352
Slick67
Sofa King Crazy!!
Slick67's Avatar
Do it! For the price it is worth it to have new lines. Plus having that feeling of accomplishment......only when it does come out right!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 01-21-2010, 02:46 AM   #353
19723DR
19723DR's Avatar
So I haven't checked in for a while. Wow, you have made a ton of progress on your truck and I have to say that thing is sooooo clean. Great job.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 01-21-2010, 09:56 AM   #354
my67chevytruck
Under Construction
my67chevytruck's Avatar
do you have the column in yet ?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-21-2010, 10:13 AM   #355
Slick67
Sofa King Crazy!!
Slick67's Avatar
I must have been a long while since you're last visit!! I have been lazy for at least a month!
Um....Heath, patience. Waiting to get the elusive motor back from the shop.
Old 01-22-2010, 12:48 AM   #356
my67chevytruck
Under Construction
Um....Heath, patience. Waiting to get the elusive motor back from the shop. [/QUOTE]
dont have much patience left these days... guess ill give you a break.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-22-2010, 11:29 AM   #357
Slick67
Sofa King Crazy!!
Slick67's Avatar
dont have much patience left these days... guess ill give you a break.....[/QUOTE]
I hear ya! Got my side mouldings in last night, gotta get a pic to prove it of course. Going to work on it after noon today, my paint and body guy is there now fixing a couple of things on the paint and getting my breather cover and valve covers ready for paint too. Feels good to be making progress when I am not even there!!! Will be starting to install my fuel neck today also.
Old 01-23-2010, 02:02 AM   #358
Dahawk
Originally Posted by Slick67 View Post
The front crossmember was already installed and now it has to be removed to move it forward suppose we all learn from these builds.....errrrrr. Well better to do it right the first time. The bags in the back were not quite as hard to figure out.
Attachment 445634
Attachment 445635
Attachment 445633
Well, the great Southern weather is not cooperating so 2 weekends without much progress. I will keep the posts and pics coming as the project progresses. Thanks for looking!
how much did you move it up to center it and how? Did you use two bolts instead of all three? I have n sheet metal on my frame, had to go to frame shop so now would be the best time to deal with it. thanks
Dahawk is offline   Reply With Quote
Old 01-25-2010, 11:38 AM   #359
Slick67
Sofa King Crazy!!
Slick67's Avatar
I decided against moving the Xmember forward, it is more simple to shim the rear of the top a-arm and gain about 1 inch instead of going through all of the work and time of moving the Xmember forward to gain 1.25 inches. Also, tubular a-arms correct the geometry some too.
Old 01-25-2010, 12:29 PM   #360
butternut1972
butternut1972's Avatar
Nice work.
butternut1972 is offline   Reply With Quote
Old 01-26-2010, 10:35 AM   #361
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by butternut1972 View Post
Nice work.
I appreciate that!
Old 01-26-2010, 10:59 AM   #362
Slick67
Sofa King Crazy!!
Slick67's Avatar
Alrighty then......back to the pics. Weekend weather was not too bad so I was able to get a couple of things done. I had to create a little more room for the gas tank flange so I pulled out the fuel cell and mounted it on the bottom side of the top of the crossmembers, didn't take a pic....but it was done!!! I took the filler neck of off the tank and went to a muffler shop and had them weld in a pipe to make a flange out of the filler cap. Worked out good. I also had them put a 45 degree bend in the end of a 32 inch peice of pipe to make a fuel filler hose. The 45 degree bend is for clearance of the sending unit. The install of this has not happened yet but the parts are ready and I can cut the crossmember under the bed next weekend to install the pipe and hoses.
All of the wiring for my bags looked like a birdsnest so my friend Ronnie and I pulled it out and started fresh from the valves and rewired everthing all the way into the cab for final install.
I put wireloom around all the wires to clean it up and protect them.
Since we were already doing the wiring I decided to hook up the bag gauges.
My paint and body guy came by on Friday and prepped the rockers for painting again. He closed the doors just a hair too much after he shot the paint the first time and it stuck a little bit. He should have that fixed and my breather cover painted next weekend.
Old 01-26-2010, 11:12 AM   #363
VA72C10
VA72C10
VA72C10's Avatar
Looking good...maybe you could have him touch up the cab corner while he's mixing up paint anyways.....
Old 01-26-2010, 11:13 AM   #364
my67chevytruck
Under Construction
looking good.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-26-2010, 11:20 AM   #365
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yeah, the pic doesn't show it but he sanded down the cab corner on the back too. I hated to see all that paint missing but I know it will look better when he's done.
looking good.
Thanks Heath!
Old 01-26-2010, 11:54 AM   #366
0331grunt
Now what??
0331grunt's Avatar
Nice progress
01 Tahoe- wifes
my, um, build
Old 01-26-2010, 08:20 PM   #367
nuke1
nuke1's Avatar
Heath, that truck sure is coming along, i love it. Out of curiousity, what bag kit are you using and size of bags for the front. Thanks. James
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-27-2010, 09:26 AM   #368
Slick67
Sofa King Crazy!!
Slick67's Avatar
Heath?!?!!? hahhaha nope it's just me.....David!! We can't all be as cool as Heath or you for that matter! I am using the Slam Specialties bags on standard cups, 2600's all the way around with (8) Blitzluft valves and 1/2 inch lines. I appreciate the compliments, coming from you that means alot!!
Old 01-28-2010, 11:36 AM   #369
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here's the update I have been wanting to post, fuel cell filler hose install. The placement has been though out and it looks like it will be a simple install, then again nothing is simple when you actually do it. For you long bed guys I got a measurement for the Summit Fuel Cell and you won't have to buy a flange for the cell. Here ya go.
I pulled the bung out of the fuel cell and had a local muffler shop weld in a 2.25 pipe inside it.
The measurement from the back of the bed floor to the center of the fuel cell filler neck was 26.25 and in the center of the bed. The x-member will have to be cut about 7 inches to allow for the 45 degree bend in the pipe to clear the sending unit. There is approximately 7.5 inches between the x-members under the bed so that worked out perfectly to run the pipe to the side of the bed.
The pipe was left a little long on purpose, 32 inches from end to end. I have options on how to run it through the bed floor to the filler neck now, I can either have the pipe bent at a 90 straight up or use a peice of 90 degree fuel hose from the filler neck to the pipe. And yes this will all be under the bed.
Summit, Jeg's, Speedway, Competition Sales all have fuel filler necks that will work for my application. I will be using a 45 degree neck so that it makes it easier to fill. Since there are already 2 bends in the filler hose and 1 bend in the pipe, my only concern is fuel kickback so I am choosing not to make another 90 in it to get it closer to the rear of the bed (unless someone tells me otherwise). The 45 bend in the filler neck should be sufficient to get it close to the rear.
The big brown truck came by bearing gifts. I was really happy with the quality of these mouldings, plus they were made by MAR-K in OK City, USA. They are on sale right now, and that made them cheaper than the competition can sale and ship their imported, foreign made mouldings!! And check out the packaging!
Old 01-28-2010, 02:55 PM   #370
nuke1
nuke1's Avatar
UUUUUMMMMMMM!!!!!!!! me dumb, i knew that been a long week, still getting use to the new job and what not, sorry. And to think i knew that. me stoooopid!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 01-28-2010, 03:11 PM   #371
Slick67
Sofa King Crazy!!
Slick67's Avatar
It's alright! Look at the amount of people on here, it's hard to keep up with everyone's real name!
Old 01-28-2010, 04:21 PM   #372
my67chevytruck
Under Construction
there is only one ME, the world could not handle 2!
Great progress David !!!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-28-2010, 05:07 PM   #373
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks Bro. I was worried about how to do this and it is simple when you finally get it figured out.
Old 01-28-2010, 10:56 PM   #374
mcbassin
Still Learning
mcbassin's Avatar
The new moldings look awesome! I'm sure they will look even better on the truck. I am assuming your gonna do a spray on bedliner? Or are you waiting to paint the bed floor till after you install the gas filler?
Old 01-28-2010, 10:58 PM   #375
kev2809
low n' slo
kev2809's Avatar
those moldings are gonna look good man. hey whats the status on the motor and trans?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
1967, custom, lwb
