Closed Thread
Old 01-24-2010, 09:58 PM   #26
Painter D
Painter D's Avatar
Re: CPP Modular spindles with some Wilwood Flavor!
Yes.
The Wilwood D52's in these pics will work.
I got mine from Jegs for $164 each,...
but I think CPPJEFF has a better deal from CPP at $150 each.
Really?
I was under the impression you had to buy different spindles for "any" dual piston calipers to work.
Also ,just to make sure were on the same page: I have 2.5" drop spindles with stock calipers and stock rotors right now. The D52's will directly bolt onto these spindles and work with stock rotors, correct?
What does "modular" mean anyway?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline
Old 01-24-2010, 10:18 PM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by 69chevyshort View Post
Really?
Correct.
They make a set of calipers for 1" and 1.25" standard 12" rotors.
They are a direct replacement for your stock caliper,... except these are aluminum and look alot better.
The only thing I don't know for sure is if I need Wilwood pads. I have pads on mine that came with my SSBC rotors. I'll call Wilwood this week.
They also make a single piston caliper to use on rear disc conversions.
Look here:
http://www.wilwood.com/CaliperList.a...0Dual%20Piston
lolife99 is offline
Old 01-24-2010, 10:21 PM   #28
lolife99
lolife99's Avatar
Modular?
I guess that means with the swap of a bracket,... you can bolt on a 13" rotor and bigger caliper.
I needed something to work with my 1" wide 12" rotors and Boss 338 wheels.
Here's the Jegs link:
http://www.jegs.com/p/Wilwood/Wilwoo...75719/10002/-1
lolife99 is offline
Old 01-24-2010, 10:23 PM   #29
Painter D
Painter D's Avatar
HHMMMM....Good to know.
THANKS for the help.
Old 01-25-2010, 11:26 AM   #30
CPPJEFF
Yes as stated above the Wilwood Calipers will work with the old style spindles, I will give you a set of calipers and braided hoses for $300.00 to all site members. Great question!
CPPJEFF is offline
Old 01-25-2010, 05:14 PM   #31
edflores
I dont know if anyone has asked before, but do you do wholesale or reseller accounts at cpp?
edflores is offline
Old 01-25-2010, 05:20 PM   #32
SCOTI
SCOTI's Avatar
I understand the black powder-coated Wilwoods are back-ordered while the reds are available. Do you have both options in stock for shipping?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 01-25-2010, 05:26 PM   #33
CPPJEFF
I just spoke to Dustin from Wilwood on friday and he said the only color was red, nothing about black ever being made, i will call and reconfirm. Thanks
CPPJEFF is offline
Old 01-25-2010, 08:29 PM   #34
Painter D
Painter D's Avatar
I'll see if I can swing the money on Friday. I'm assuming the number in your avatar is where you can be "easily" reached?
Old 01-26-2010, 07:07 AM   #35
n2billet
Village Idiot....
n2billet's Avatar
I was told (by Wilwood) that they are going to make black......at least I hope they do since I've had some on order for almost two months
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline
Old 01-26-2010, 11:43 AM   #36
CPPJEFF
Sounds good! Let me know.
CPPJEFF is offline
Old 01-26-2010, 11:44 AM   #37
CPPJEFF
Hence the reason they probably did not offer those to us when we made the purchase. Thanks for the headsup.
CPPJEFF is offline
Old 01-26-2010, 02:58 PM   #38
CPPJEFF
Ok i just got off the phone with Dustin at Wilwood and they WILL NOT be making black in the "52" caliper. Hope this helps clear up the myth.
CPPJEFF is offline
Old 01-26-2010, 09:15 PM   #39
Painter D
Painter D's Avatar
Too bad about them not making them in black I'd rather have it than red. Guess I'll have to paint them black since I know a decent painter that can do it for free.
Old 01-26-2010, 10:46 PM   #40
Se7en Deuce
Se7en Deuce's Avatar
Wow i owe you lunch for mentioning this, i almost forgot! Yes we can make this ina 5 on 4 3/4 pattern on the NEW 13" kits but not the factory 12" rotor.
do you have a 13" rotor for 6 lugs?
Se7en Deuce is offline
Old 01-27-2010, 11:12 AM   #41
CPPJEFF
Yes we have them in 6 lug.
CPPJEFF is offline
Old 01-27-2010, 01:56 PM   #42
DKN
Active Member
We have 13" rotors in every bolt pattern. We currently stock forged hubs for these spindles in 6-lug, 5 on 5", and 5 on 4-3/4".
Danny Nix
CPP
DKN is offline
Old 01-28-2010, 12:20 AM   #43
Painter D
Painter D's Avatar
CPPJEFF
I tried to get through today but was unsuccesful I'll try again tomorrow. I was also curious if you guys offer a direct OEM replacement 12" rotor (drilled and or slotted)? If so, and the price is right I might pick up a set of those as well.
Sorry if I missed the answer somewhere.
Old 01-30-2010, 12:35 PM   #44
Painter D
Painter D's Avatar
Order placed, THANKS JEFF.
I'll post pics after the install, I ordered some drilled and slotted rotors also. If everything goes well I'll get the rear disk brake kit too.
Old 02-01-2010, 12:37 PM   #45
CPPJEFF
Thanks for the order bro!
CPPJEFF is offline
Old 02-05-2010, 09:18 PM   #46
pcmcobra
pcmcobra's Avatar
hey jeff...on those braided lines...are they the round banjo type or the square(have to grind down) type?
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline
Old 02-06-2010, 12:50 PM   #47
CPPJEFF
Round, the word grind makes me want to throwup!! Just my 2 cents on grinders!
CPPJEFF is offline
Old 03-11-2010, 01:24 PM   #48
mac72
Jeff I just recieved my d52's what a quality piece for the price! Wilwood really had thier thinking caps on for that one.I appreciate the discount too
Thanks Mac
mac72 is offline
Old 03-11-2010, 01:39 PM   #49
CPPJEFF
Thanks Mac
Mac it is truly a great design, it was something that everyone was waiting along time for. I appreciate the buisness. Also i am just waiting on bumpstops for your lower tubular arms.
CPPJEFF is offline
Old 03-16-2010, 03:31 PM   #50
tommyd241
tommyd241's Avatar
"$75.00 CALIPER MOUNTING BRACKETS FOR FREE WITH THE PURCHASE OF A SET OF SPINDLES FOR $299.00"
Is this offer still good?
tommyd241 is offline
Closed Thread
