01-19-2010, 01:28 PM | #1 |
CPP Modular spindles with some Wilwood Flavor!
Wow we all want the best but dont always have the pocketbook to have the best. CPP now has a Wilwood Dual piston caliper that bolts right onto our new spindles. I took a couple pics of the kit if you want one give me a call. FOR MEMBERS OF THIS SITE ONLY I WILL INCLUDE THE $75.00 CALIPER MOUNTING BRACKETS FOR FREE WITH THE PURCHASE OF A SET OF SPINDLES FOR $299.00 OR I WILL TAKE THE $75.00 OFF A COMPLETE KIT IF YOU WANT IT AS PICTURED. Let me know how you want your kit and i will make it happen! This deal is
01-19-2010, 02:10 PM | #2 |
Re: CPP Modular spindles with some Wilwood Flavor!
Where'd these pictures come from?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-19-2010, 04:11 PM | #3 |
67-72 parts collector,…
So what's included for what price?
1) Spindles 2) brackets 3) Wilwood caliper 4) Slotted rotor 5) Braided brake line 6) dust cap Can you break down the pricing and the total savings for everything "as pictured"? Last edited by lolife99; 01-19-2010 at 04:15 PM. |
01-19-2010, 04:13 PM | #4 |
That's just the D52 Wilwood caliper that will bolt on any other C10 drop spindle without the bracket.
I'm not trying to bust your chops,... just trying to figure out the savings. Thanks. Last edited by lolife99; 01-19-2010 at 04:14 PM. |
01-19-2010, 04:41 PM | #5 |
You are totally correct, i bought a qty purchase on calipers and i highly doubt anyone can touch us on the caliper pricing. Yes that caliper will fit all kinds of applications no doubt.
01-19-2010, 04:47 PM | #6 | |
1) spindles $299.00 2) brackets FREE with purchase of above (spindles) 3) wilwood calipers $300.00 Pair 4) slotted and drilled rotors $189.00 a pair 5 braided brake lines $50.00 6) dust caps free with above purchase. Last edited by CPPJEFF; 01-19-2010 at 04:51 PM. |
01-19-2010, 05:40 PM | #7 |
are the rotors 5x5 or can I get them in 5x 4/34?
01-19-2010, 05:46 PM | #8 |
Wow i owe you lunch for mentioning this, i almost forgot! Yes we can make this ina 5 on 4 3/4 pattern on the NEW 13" kits but not the factory 12" rotor.
01-20-2010, 02:50 PM | #9 |
I rethought this answer and yes it will bolt to other spindles, but that same "other spindle" will push the wheels out, so its kind of counter productive.
01-20-2010, 04:02 PM | #10 |
Hey Jeff,... When you say "push the wheels out",... compared to what?
Drum brakes? Yes. Stock disc brakes from 71-87? How much do the other guys drop spindles push the wheel out in relation to "stock height" disc brake spindles? Just trying to compare apples to apples. Last edited by lolife99; 01-20-2010 at 04:03 PM. |
01-20-2010, 04:20 PM | #11 |
How much a side do the CPP spindles narrow the track?
01-20-2010, 05:12 PM | #12 |
01-21-2010, 10:59 AM | #13 |
I have the modular spindles and CPP upper a-arms, I installed them, put it on the ground then decided to make a few more changes during the "long cold winter". The sprindles are very beefy and look and fit great. I did not however get the fancy brakes, I will be stuck with my "stock" disks. I did the spindle swap from another 2 1/2 inch drop to move the wheels in I would on occasion rub on the inner fender bolts on a dip, nothing bad but I needed to fix it. I think this will give me the necessary clearance and retain my drop.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-21-2010, 11:18 AM | #14 | |
01-22-2010, 03:58 AM | #15 |
ok so what can you do for those who already have "regular" spindles? i have a dropmember to take care of my track width issues.
btw my buddies have purchased several parts from you and the only thing that was ever a problem was a hydroboost setup, but just setting it up properly was the issue. I believe it was taken care of already but that was the one thing of literally hundred of parts my friends have ordered from you. We have the luck of being just a 30 minute drive away anyways |
01-22-2010, 11:13 AM | #16 |
show off
01-22-2010, 11:52 AM | #17 | |
01-22-2010, 03:44 PM | #18 |
sorry if i phrased that wrong. I was seeing if you could put together a kit for me for the "other " spindles? can you pm or post prices for a 12" kit and 13" kit? Thanks
and its not a truck, nor is it mine. Only in my dreams. ha |
01-22-2010, 04:09 PM | #19 |
No sweat, sorry for the comfusion. We dont make a 13" rotor for the old spindle. The old spindle uses a factory 12" rotor. Thanks
01-22-2010, 06:16 PM | #20 |
Jeff, I want to make sure on this. I have the new modular spindles with the factory rotor, I have not driven this as I making a few changes. This will all work correct?
Well to back up, this is not a factory rotor I changed to a 6 lug disk brake several years ago but believe it to be a replacement only with 6 lugs. everything seemed to fit and I did drive it out and back in the shop but not any more. Thanks Dave
01-22-2010, 06:26 PM | #21 | |
01-24-2010, 09:31 PM | #22 |
Nice kit.
Are there any dual piston calipers that will directly bolt onto regular drop spindles (like I already have)? I would but this kit buy I don't want to buy modular drop spindles when I already have a pair of regular drop spindles.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 Last edited by Painter D; 01-24-2010 at 09:52 PM. |
01-24-2010, 09:40 PM | #23 | |
The Wilwood D52's in these pics will work. I got mine from Jegs for $164 each,... but I think CPPJEFF has a better deal from CPP at $150 each. |
01-24-2010, 09:53 PM | #24 |
Here's a couple pics of mine on Belltech spindles.
01-24-2010, 09:58 PM | #25 |
Under Construction
that's good to know. I would not have known that the d52 would have bolted up to our ece drop spindles. may have to look into this in the future. just to be certain these will bolt up to the 72 ece drop spindles as well as 73-87 correct.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-24-2010 at 09:59 PM. |
