Old 02-25-2010, 07:50 AM   #51
Thealien
Thealien's Avatar
Re: LS engine swap info
Yeah I didn't want to use any AN hose (trying to keep it factory looking) so it was easier to just swap the fitting from my old pump to my new pump and use my stock 72 lines. Cost was $0.00
Old 02-25-2010, 10:10 AM   #52
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Ditto, same here.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 03-05-2010, 03:49 PM   #53
low_84_inchaska
low_84_inchaska's Avatar
is it true that if i am running the truck intake, i do not need the corvette regulator filter unit? I can just run the external fuel pump and a filter to the rail that on the truck intake has a integrated regulator?
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 03-05-2010, 03:55 PM   #54
glock35ipsc
If the fuel rail is the older version, 2003 and older I think, that has the integrated regulator with two ports on the rail (inlet and return), then correct you don't need the Vette filter/regulator.
If it only has one port, then you will need to use the Vette filter/regulator.
Bob
Old 03-05-2010, 04:30 PM   #55
low_84_inchaska
should have stated it is a 5.3 out of a 99 gmc 1/2 ton. I have been reading and reading and reading,,,my mind is melting...there is tons of info but i cant just pull it all together ahha.
thanks!
Old 03-05-2010, 04:33 PM   #56
glock35ipsc
LOL, I understand completely! You are good to go with just a regular filter.
Bob
Old 03-05-2010, 04:39 PM   #57
low_84_inchaska
i dont want to hijack the thread, i probally should just continue on my project thread but i dont think i will get the hits like on this thread..... so do i just run new lines of my current fuel tank on my 84 to the pump to the filter to the rail and then run the return back to the tank?
Old 03-05-2010, 04:46 PM   #58
glock35ipsc
You will need fuel injection rated fuel line, filter, clamps, and of course the fuel pump. Try to use either as much solid line as possible, or stainless braided line. Try to keep FI rated rubber hose to a minimum, as in just connections.
Supply line from the tank, to the filter, then the pump, then to the engine. All 3/8" (-6AN).
Return straight from the engine to the tank. 5/16" (-4AN).
Do you have two tanks? And if so, do you plan on keeping both operational?
Bob
Old 03-05-2010, 04:56 PM   #59
low_84_inchaska
glock, i transferred to my build thread, i didnt want to muddy up this thread.
thanks for the help glock!
Old 03-08-2010, 05:22 PM   #60
Shon
Let me know if you need any LSx parts!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 03-19-2010, 09:17 AM   #61
low_84_inchaska
how did you do the power steering?
Old 03-19-2010, 09:22 AM   #62
Shon
my set up was from a van that had hydraboost steering so I had an LT1 PS resevior and that is what I got for the res. I mounted it over next to the windshield wiper fluid res.
Can see it here:
Old 04-05-2010, 10:32 PM   #63
Hart_Rod
Hart_Rod's Avatar
Is the VIN stamped on the block anywhere? I can't seem to find it. I'm tTrying to figure out exactly what year my motor is. It's supposed to be an 06, but I just want to make sure prior to ordering my harness.
Hart_Rod is offline   Reply With Quote
Old 04-06-2010, 09:53 AM   #64
Clyde65
Clyde65's Avatar
the block year doesnt matter until you get into the 2007 ( GEN IV) year and they changed some sensor locations, If your ordering a harness just tell them if it is DBC or DBW. Correct me if I am wrong but this is what I was told.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-06-2010, 09:54 AM   #65
Shon
that is the way I understood it. If the motor and PCM came together and you are 100% sure, that information can be pulled from the PCM.
Old 04-06-2010, 12:45 PM   #66
Hart_Rod
Hart_Rod's Avatar
Thanks for the info. I just ordered my Fuel Injection wiring harness. This is the information I sent to John at Speartech. Let me know if I you think I have overlooked something:
Wiring harness for a 2006 5.3, 4L60E with a MagnaCharger.
Motor #: I couldn't find the VIN number (picture included)
Tranny # 616CHYD42093461 (picture included)
Injector # : 17113739, 44 lbs (picture included)
Computer Service # : 12589463
Maf # : 25168491 (this number is on it also, 7664630A)
O2 Sensor 1 (SQUARE): 12589321 (picture included)
O2 Sensor 2 (TRAPAZOID): 1259986 (picture included)
Tach module # :12588923 (picture included)
Pedal #: unknown (picture included)
Harness length: Standard length
Cruise control, Air conditioning, delete rear O2's, pedal harness, no emmissions, CEL
Old 04-07-2010, 09:04 AM   #67
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
In doing some research I was unable to come up with a cure for my return line issue. I have a truck intake with regulator and return. I wanted to switch to the corvette filter with regulator and ditch the return line from the engine but stick with the truck intake because it's tall and I think it fits the engine bay better than the shorter car intake (not to mention the car rails all seem to have the feed pipe pointing to the left instead of back towards the firewall). What I did was replace the left fuel rail with a non-return rail part number 12602113. Then you can toss the return pipe that attaches to the rail and you're left with only the feed pipe. You can also get retainer kit part number 89017378 to replace the one that was originally for both tubes, I plan to just trim the one that was there.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 04-07-2010, 09:12 AM   #68
Shon
Or you can get a different set of fuel rails that does not have said FPR on it from the trucks, I do not have a good pic of it but it accomplished the same thing as mentioned above. Heck, I think I got a spare fuel rail here that does not have a FRP on it.
Old 04-07-2010, 10:18 AM   #69
glock35ipsc
Over on ls1truck, ls1tech, et al, the guys that are building up GenIII's with LS6 and other aftermarket intakes practically give the 04 > truck intakes and rails away.
Bob
Old 04-07-2010, 11:47 AM   #70
Shon
If you want to go big, I can ship you a 102mm FAST intake for the truck for $840 and $30 for the intake gaskets if you want them too.
Old 04-28-2010, 03:28 PM   #71
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
lots of great info here
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-31-2010, 07:38 PM   #72
72gmcshorty
72gmcshorty's Avatar
Is there some way to id year of motor online using the computer/ecm number? I have same prob as guy before, not sure of year of motor and i don't have a transmission yet...(po i bought from said he "thinks" it was from a 2006).
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-10-2010, 11:31 AM   #73
68GMCCustom
Theres a 3 digit code (like DCP) that doesn't match the RPO number (LS1, L92, etc)...the dealers Parts dept) don't seem to know what it means... but someone at GM has to.
Kurt -
Old 06-10-2010, 11:41 AM   #74
Clyde65
Clyde65's Avatar
Does anyone know of a good tuner in the DFW metro?
Clyde65
Rebuild of Clyde
support our troops!
Old 06-10-2010, 12:18 PM   #75
68GMCCustom
Try Brian. He even has a dyno.
Exatorq
Kurt -
