Old 02-17-2010, 08:13 PM   #251
nuke1
nuke1's Avatar
Re: It’s Just A Pickup
OK OK, I must have gone stupid and blind. oh well. looks nice now.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-25-2010, 04:12 PM   #252
Bruce88
Bruce88's Avatar
More thinking than doing
Minor planning changes, pre/test fittings, and cleaning up for moving forward
Changed the plan to have the frame sandblasted instead of cleaning it up at home. Now just trying to figure out how to transport it down to the sandblaster?
Used a full small tank of propane and a scraper to remove most of the undercoating on the frame prepping/making it easier for sand blasting.
The Blazer stile fuel tank and trailer hitch are from Wes at Classic Heartbeat Pickup Parts.
To save some time lying on my back under the truck fitting the fuel tank and drilling the holes for the hitch over my head I think it’s a perfect time with the frame upside down to do this task.
Decided not to use the nuts and bolts from the fuel tank kit and thanks to Wes for the tip to use a ¼ inch mounting strip between the tank and frame. The mounting strips and felt/tar paper used between the straps and tank do not come in the tank kit. Any peace of rubber a ¼ thick could be used like some old truck mud flaps I just happened to have some molding that would fit the bill.
Some different perspective pictures included, the frame is upside down and sitting on some sawhorses. Might want to keep this in mind when looking at the pictures to minimize any confusion.
Pre fitting should help and make the final installation of the parts easer in the end, I hope it does. Enjoy your build
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 02-25-2010, 04:23 PM   #253
lyrikz
PITbut
lyrikz's Avatar
I am borowing a huge trailer and its at my house now. I will have it for a day or two. Let me know and we can run it over to marysville... Need to know soon..
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-25-2010, 08:24 PM   #254
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Did you get the hitch from ECE?
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 02-25-2010, 11:33 PM   #255
Bruce88
Bruce88's Avatar
I picked up the hitch from Classic Heartbeat and it has the part number and description tag shown above on it.
Old 02-28-2010, 09:51 AM   #256
steppside69
steppside69's Avatar
Bruce88,
Love the build , soaking up this build like a sponge . Can't wait for more, Looks awesome
Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 03-05-2010, 07:19 AM   #257
Bruce88
Bruce88's Avatar
Just keeping busy when things are out
Thanks to lyrikz for giving me a hand getting the frame down to the sandblasters, should be ready to come home in a few days.
When I rebuilt the front suspension a few years back the center section was not accessible to paint with the engine and various parts in the way. The Hammerite paint I originally used held up pretty well on the suspension arms, springs, and drop spindles. Cleaned up the chipped areas and some tape to keep the paint off the rubber parts and zert fittings and gave it another complete coat of Hammerite.
The forward and aft lip areas seem to like to collect water and dirt with no place to go so I drilled some ½ holes to allow this area to drain and not collect as much dirt.
As long as I’m talking about suspension
When I rebuilt the front end I installed some 4 inch drop springs in the rear. I liked the ride height and it definitely was a less harsh ride than the stock springs. But the springs could not carry any load in the bed without sitting down on the frame rubber stops and the shock binding up at its minimum compression.
So to salve the problems, I’m planning on using some 49107 Gabriel Hijacker air adjustable shocks and relocating the shock mounts.
When the truck was all together I had taken some measurements of the shock and suspension travel. I’ve just taken all the measurements and generated a full scale picture to figure out how my modification would work. What you see below is a shrunk picture of what I came up with to fit into the forum (a GIF animation showing the difference between before and after the modification).
CPP (Classic Performance Products) has a shock mount relocator kit that does similar repositioning of the shock mounting holes.
The frame should be home soon and the painting of it will begin, enjoy your build
Old 03-05-2010, 08:52 AM   #258
my67chevytruck
Under Construction
my67chevytruck's Avatar
Bruce, great progress and writeup as always!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-05-2010, 11:00 AM   #259
SCOTI
SCOTI's Avatar
Bruce88, check this out....
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-05-2010, 04:02 PM   #260
Bruce88
Bruce88's Avatar
Originally Posted by SCOTI View Post
I missed that post but looks like I stole that idea. Your presentation is very well done; I’ve heard of it being done but not seen any pictures and wanting to visualize it before I proceeded. Thanks for the additional information and ideas on how to accomplish the shock relocation.
Old 03-05-2010, 04:18 PM   #261
SCOTI
SCOTI's Avatar
Just one way of several to get from A to B....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2010, 10:46 PM   #262
gopokes
gopokes's Avatar
Bruce, Just like everyone else said, awesome write up!! I am just starting to do the repair to my cab, first time doing it. I just want to thank you for taking the time to document this stuff. I will be trying this with this with the cab still on the truck, don't have much space to work, but with the detail you have shown I think I can do it. Thanks for the motivation!!
gopokes is offline   Reply With Quote
Old 03-06-2010, 03:20 PM   #263
kyull67
kyull67's Avatar
Very Nice!
kyull67 is offline   Reply With Quote
Old 03-09-2010, 06:03 PM   #264
CHEMPOWR
CHEMPOWR's Avatar
Thanks for the education!
1969 GMC Wideside SWB 400ci/TH400/373/Disc Brakes/Leaf Springs
1992 Chevy C3500 Ext Cab Dually Silverado 454 TBI
2007 Chevy Corvette ZO6 427ci 505HP
CHEMPOWR is offline   Reply With Quote
Old 03-11-2010, 12:21 AM   #265
JJanzen
JJanzen's Avatar
Bruce,
Great read and great job on the project.....It's a joy you see someone who really cares not only about the outcome but the process as well.
Joel
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 03-17-2010, 12:00 AM   #266
Bruce88
Bruce88's Avatar
It’s not really required for this build, it’s strong enough without modification
But to beef it up a little will not hurt
The rear suspension control arms/swing arms are strong enough for a street truck, but decided to beef them up a little. Approximately every 6 inches did a 1-1/2 inch weld on the top and bottom of the swing arms. If you don’t see the heat/color indication on the other side of the metal you probably have a cold weld that can look good but because it doesn’t have good penetration the weld will be weak and not have the strength needed.
Just got the frame back from the sandblasters with out getting any rain on it, that always a good thing. But the weather doesn’t look like it’s going to cooperate to paint the frame outside, so it looks like Ill be painting the forward half and then the aft half in the garage due to lack of room to do it all at once.
Getting close to the point in the build where things are going to be put together in final assembly. Now if the weather will cooperate and I can get some of the little parts cleaned and painted it might start looking like a truck again soon instead of a hole bunch of parts. Enjoy your build
Old 03-21-2010, 05:35 PM   #267
west9378
west9378's Avatar
Bruce very nice job on your truck, thank you for the inspiration.
West
west9378 is offline   Reply With Quote
Old 04-04-2010, 07:44 PM   #268
Bruce88
Bruce88's Avatar
The last few weeks been waiting for Mother Nature to cooperate a little
A few days have presented them selves to progress
Not being very knowledgeable about painting, probably one of my very weak points. Feeling like a novice alcomist trying to create gold for the first time, trying to fallow the instructions without some of the elements available or understanding the language completely. With that being said this is how I proceeded to paint my frame.
Without having a fully functional paint booth available and the cooler time of year with higher humidity levels I fell back to some basic standards I learned (I forget where) not to paint below 50 degrees or above 70 percent humidity (definitely not in the range recommended by the paint manufacture). Only time will tell if the paint job will last.
I used two (light to medium) coats of Eastwood Rust Encapsulator as a primer/sealer on the sandblasted frame and then 24 hours later two (light to medium) coats of Eastwood Extreme Chassis Black (Satin). It took 4, 14oz. cans of Encapsulator and 4, 14 oz. cans of the Chassis Black to do the frame and swing arms.
Just as a side note I painted the forward half of the frame then used the front end suspension to weight down the front end and lift the rear section for painting on another day. (The pictures are showing the later stage). Yes the nuts and bolts require painting and will be done later (smile).
Just got the rear end back from having it rebuilt with new bearings, seals, and gears changed to 3.42 (no it’s not a posi). I did luck out in that I didn’t have to replace the axles. One of the areas on a 12 bolt that has high mileage that might need attention is the axles; they are the inner race of the outer bearings and might need replacing due to wear or damage.
I used a can of Hammerite (black) to paint the rear end. Not all black paint is created the same and the Hammerite looks to be a different color depending on the light. In the first picture with sun light it looks silver and with the door closed and from the back side it looks charcoal. Just an oddity of Hammerite that I find interesting and different.
With a little time to kill, I thought I would try my hand at creating an animated avatar that reflects how the build is progressing. It is a little different just another way for me to enjoy my build
Old 04-05-2010, 12:54 AM   #269
jojo
printing is my trade
jojo's Avatar
Thats some good work on your build. Always nice to see a good stepside build.
Thanks for writing your build thread with such precision and detail... Its a great read.
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 04-14-2010, 06:09 PM   #270
frog trucker
frog trucker's Avatar
Location: Smack-dab in the middle of "The land of fruits and nuts", Sacramento, CA
Chassis is lookin' great, Bruce! Thanks for the awesome thread . . . loads of neat tips!
frog trucker is offline   Reply With Quote
Old 04-16-2010, 03:06 PM   #271
VA72C10
VA72C10
VA72C10's Avatar
Any recent progress?
By the way, I like the Avatar.
Old 04-17-2010, 06:39 PM   #272
Bruce88
Bruce88's Avatar
What was, What is, Imagining it complete
Not exactly a before and after pictures kind of an intermediate phase.
The brake system on the truck had been neglected for years and decided to replace the complete system to include stainless steel lines (some new and some remanufactured items)
Parts to be used
Master Cylinder --------- Coni-seal - MC250040 (new)
Proportioning Valve ----- Inline tube - VCT103 - (72 Front Disc Rear Drums)
Power Brake Booster ---- NAPA - NBB 5473709
R/H Caliper ------------- NAPA - CAL SE4586 (Remfd)
L/H Caliper ------------- NAPA - CAL SE4587 (Remfd)
R/H Wheel Cylinder ----- NAPA - UP 13388 (not shown)
L/H Wheel Cylinder ----- NAPA - UP 13387 (not shown)
SS Brake Line ---------- LMC - 34-5589 - (72 Shortbed PWR ½ ton)
Tube Union (QTY 3) ---- Edelmann - 123400
Tube Union Tee -------- Edelmann - 130333
(The front and rear brake hoses have not been decided on at this time, possibly custom length, due to the truck being lowered)
The Master Cylinder, Proportioning Valve and Calipers have been painted with VHT Brake Caliper (Satin Black). Then baked in the oven at 250 degrees for 1 hour for final curing.
The Power Brake Booster and brackets where painted with VHT Roll Bar & Chassis (Satin Black).
(Note not all year power brake installations had the support/brace bars used, my 72 did)
Just look at the pile of (spaghetti) stainless steel lines that Ill be installing, no wonder minor tweaking/adjustments will be required to make it fit right (smile).
The frame and suspension should be back together soon and have it as a rolling chassis. And the routing/installation of tubing, brakes & some wiring will begin. I can see it in my mind and pictures will be coming (smile) enjoy your build.
Old 04-17-2010, 06:46 PM   #273
glimmertwin01
glimmertwin01's Avatar
sweet bruce
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 04-17-2010, 11:24 PM   #274
VA72C10
VA72C10
VA72C10's Avatar
Very nice!
Old 04-18-2010, 02:10 AM   #275
Indyuke
Wow! Just read through this and I'm impressed! Gives me some good ideas too. I like the use of the clecos. Brings back memories.
Indyuke is offline   Reply With Quote
