Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-09-2010, 12:15 AM   #1
big_c_snow
v8 swap question
Hey all, I have a 93 Bravada that I am putting a 383 into and I have a few problems. The main one is, with the correct oil pan and motor mounts, no matter how much I try to add in spacers, the oil pan still sits on top of the front differential. Is there a different set of mounts that I should use? Different oil pan? Help... this is getting irritating. Thanks!
94 Ford Aerostar AWD
Which is useless in Florida...
86 FJ1200
Daily Driver
big_c_snow is offline   Reply With Quote
Old 03-09-2010, 02:38 AM   #2
FLEET72
FLEET72's Avatar
Re: v8 swap question
You need a different oil pan. Depending on what year motor you have, one of these should work or if you are good with a welder (oxy/acetylene or tig) you can make your own using the sump from the original v6 pan and the v8 pan.
http://www.v8s10.com/Pages/Parts_S10-4x4OilPan.html
http://www.v8s10.com/Pages/Parts_S10-NewOilPan.html
http://www.summitracing.com/parts/ADD-716411A/
http://www.summitracing.com/parts/HAM-1099/
What motor mounts are you using?
EDIT: I just reread your post, you said you are using the correct pan, which one are you using?
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-09-2010, 05:59 AM   #3
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
is the AWD t-case and front axle setup the same as the standard 4x4? that'd be the only reason I could see...
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 03-09-2010, 02:02 PM   #4
Damien
Damien's Avatar
The front end is the same as the 4x4. The transfer case is what makes it awd or 4x4.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-09-2010, 10:16 PM   #5
chevy2racr
chevy2racr's Avatar
i can't imagine why Big C could have problems if its same as standard 4x4. theres plenty of 4x4 s-10s out there....
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 03-09-2010, 11:54 PM   #6
big_c_snow
Hey,
I am using the Advance Adapters oil pan, and JTR style mounts with 2.8 frame side mounts, if that helps anything.
86 FJ1200
Daily Driver
Old 03-10-2010, 01:02 PM   #7
chevy2racr
chevy2racr's Avatar
look like this one?
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 03-10-2010, 04:56 PM   #8
big_c_snow
Yeah, that's the one I have.
86 FJ1200
Daily Driver
Old 03-10-2010, 07:40 PM   #9
crazycory1
This front diff has a solid axle on the passengers side, no accuator
crazycory1 is offline   Reply With Quote
Old 03-12-2010, 06:50 PM   #10
Damien
Damien's Avatar
Could you post some pictures of what you have?
