Old 03-16-2010, 02:42 PM   #26
TyKby2
TyKby2's Avatar
Re: 1974 SWB C10 (The Mistress)
Originally Posted by 69BBsuburban View Post
Metallic green base.....candy green over the top, and a little gold pearl in the clear to top it off....
that would look pretty good to but if i do a candy green or red I'll do a gold base and if I do a blue or purple candy I'll do a silver base. great suggestion though.
Kevin
1974 Chevy C-10 (The Mistress)
1971 VW Bus
1973 VW Super Beetle
1996 Jeep Cherokee
TyKby2 is offline   Reply With Quote
Old 03-16-2010, 02:45 PM   #27
jchav62
1962 C-10
jchav62's Avatar
Originally Posted by TyKby2 View Post
I lowered the over the weekend but haven't done the front yet, don't really have the money to do the front, so it's staying where it is for now. It's still a little to high but untill I get more money it will have to do. roughly 3 inches is what takeing two leafs out amounts to, i want to go 6 inches all the way around.
Have you considered cutting a loop off the front coils? Very commonly done.. That's how mine is lowered in the front.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-16-2010, 02:51 PM   #28
TyKby2
TyKby2's Avatar
yeah I considered doing that this weekend but ran out of time. so i think i'm gonna wait and put 3 inch drop coils, 3 inch drop spindles, and 6 inch drop mono leafs in the rear, later on down the road.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-16-2010, 02:59 PM   #29
lolife99
67-72 parts collector,…
lolife99's Avatar
Skip the drop leaf spring.
Put your removed leafs back in,... and do a flip kit.
Much cheaper.
Keith
Convert to disc brakes.
Old 03-16-2010, 04:18 PM   #30
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Yeah...that would work great...but, if ya never had sprayed a candy before, spraying a metallic base close to the candy coat, you run less risk of "tiger stripes" and blotchiness...
HOK has candy bases for avoiding such issues...to be used with their concentrates...
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 03-16-2010, 04:27 PM   #31
dan76
When considering paint choices/color, don't forget how you're going to use the truck. A DD, cruiser, or trailer queen? Additionally where are you parking? In a garage, carport or in the open? Some colors won't survive daily exposure to sunlight and you'll cringe when the first stone chip or parking lot ding appears on a DD.
Good luck and post a threat on your build progress.
dan76 is offline   Reply With Quote
Old 03-16-2010, 04:55 PM   #32
TyKby2
TyKby2's Avatar
Much cheaper.
you don't have to put a c-notch on the truck with the drop springs though, and I've priced out the two and the springs are only 20-30 bucks more than the flip kit. I was going to do a flip untill i found those springs. I'm all about easy bolt on stuff. Sorry if I sound hateful, I don't have good forum etiquette.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-16-2010, 04:58 PM   #33
TyKby2
TyKby2's Avatar
I probly wount do a candy because of this reason, but I have a buddy thats paints cars and trucks for a living so i'd probly get him to paint it anyway.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-16-2010, 05:05 PM   #34
TyKby2
TyKby2's Avatar
Def. not a trailer queen cause whats the point of having a vehicle if you can't drive it. but it will not necessarily be a DD more of a cruiser/once or twice a week driver. wont haul much with it except ass.
once i figure out how to post a build tread I'll let you guys know.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-16-2010, 05:23 PM   #35
69BBsuburban
A flip is many times a better way to go, as ride quality stays the same (load capacity), unless the flip has less than a few inches of frame clearance, which with dropped leafs, you'll have the same issue anyway....
Neither of my trucks are C-notched and are flipped...they're just not ridiculously low.
As far as candy paint...the HOK system is a pretty foolproof way to go and get a nice looking "candy" style paintjob....even for a DD or cruiser....
Pinstriping by Josh
1930 Ford Model A
Old 03-16-2010, 07:03 PM   #36
lolife99
lolife99's Avatar
I've had two daily driver 73-87 trucks with flip kits and no c-notch.
No loss of load capacity either.
Keith
Old 03-16-2010, 11:05 PM   #37
TyKby2
TyKby2's Avatar
IDK I'll have to think about it, I just figured it would be easier to do the spring instead of the flip kit.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-17-2010, 01:40 AM   #38
lolife99
lolife99's Avatar
Here in Missouri,... you can almost always bet on having (at least one) seized leaf spring bolt, that goes through the spring eye.
Remove the bumpstop metal bracket directly above the rearend, use shock extenders to correct rear shock angles,... and you will be fine with a flip kit.
Get your truck lowered and running/driving good,... and then worry about the paint.
Just my 2 cents.
Keith
Old 03-18-2010, 03:29 PM   #39
TyKby2
TyKby2's Avatar
Thanks to 69BBsuburban for suggesting House of Kolor paints, I think I just found the color I want to paint her. The name of the color is Branywine.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-19-2010, 02:29 PM   #40
TyKby2
TyKby2's Avatar
I still would like more suggestions though, because paint won't come for a while yet. I still need to do some rust control, get two front fenders, and get the body straight. but any paint color suggestion is greatly appreciated.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-19-2010, 03:57 PM   #41
69BBsuburban
I usually don't like red, but that red above is nice...
Keep in mind, red is generally more expensive than other colors....especially if ya have a special color mixed up.
Pinstriping by Josh
1930 Ford Model A
Old 03-19-2010, 04:20 PM   #42
TyKby2
TyKby2's Avatar
Yeah, red is usually more, but some green is ridiculous spent $90 on a pint of green paint for my wheels on my bug. but I'm still open for more suggestions, red doesn't have to be the final say, who knows I may find a Pink or Purple I like.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-19-2010, 05:00 PM   #43
69BBsuburban
Pink and purple would kick ass....just 'cause most guys are too chicken to run it...
I'll have a pink rig soon, metalflaked, with purple fogs and lacing.....
Pinstriping by Josh
1930 Ford Model A
Old 03-19-2010, 07:33 PM   #44
TyKby2
TyKby2's Avatar
Come to think, I do like the pink on those Mary Kay Caddies.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 03-19-2010, 07:41 PM   #45
Ger
I like that green, was thinking about when I do up my 81 swb to go with a new color. I'm using my 81 lwb for the parts on the new project.
Ger is offline   Reply With Quote
Old 03-19-2010, 11:02 PM   #46
TyKby2
TyKby2's Avatar
yeah when I paint mine want something different. after I painted my bug semi-gloss black with bright green trim I started to see more black and green vehicles, atleast one in every car show not including mine.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 04-13-2010, 09:38 PM   #47
TyKby2
TyKby2's Avatar
here is a test green I don't know how to feel about it yet, I kinda like it and I kinda don't. what do y'all think, oh I have one of the wheels I am using test fitted on the truck aswell
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 04-13-2010, 09:43 PM   #48
TyKby2
TyKby2's Avatar
I have seen a green called Synergy Green, and it's on a new Camaro at a local Chevy dealer, sorry I don't have a pic but I didn't have a camera, I'll try to take one and post it tomarrow.
Kevin
1971 VW Bus
1996 Jeep Cherokee
Old 04-14-2010, 12:38 AM   #49
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
That is an awesome green! It rivals any "custom mixed" green out there. It is as bright as antifreeze.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 04-14-2010, 12:42 AM   #50
TyKby2
TyKby2's Avatar
the guy said it's a very very limited color for 2010, but should be available on all for 2011
Kevin
1971 VW Bus
1996 Jeep Cherokee
