04-16-2010, 12:27 AM | #176 | |
60-66 Nut
Re: My whole braking system - thinking out loud
I'll put your name on a set, and get them over to the powder coaters tomorrow. I'll send you a PM to work out payment details.
As for the proportioning valve, some guys are using the stock disc/drum one with success, others use the disc/drum with an adjustable in the rear line, and others run only an adjustable in the rear line. There is also the disc/disc proportioning valves. I would say it will somewhat depend on which calipers you use. If you're going with the Wilwood dual D52's, they recommend using the 1.5" dia piston models in the rear with the 2"up front to help maintain some of the braking bias. So I guess decide which calipers you are going to use and then we can go from there. Quote:
04-16-2010, 12:42 AM | #177 | |
60-66 Nut
Do you have an application for those rotors? It sounds like you setup and drilled the holes on a CNC? How long do you figure it took you to turn the original rotors into hubs? It seems like someone already makes aluminum hubs that will work on the truck spindles. I'll have to find them and see how much they are.
04-16-2010, 12:55 AM | #178 | |
04-16-2010, 01:42 AM | #179 |
60-66 Nut
That's right, that was one of them. Thanks Scot. Chris Alston makes them too, but I don't know if they're available seperately. Are the KORE3 hubs available in a 5x5? The website just says the have a dual 5 x 4 3/4" pattern.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-16-2010 at 01:42 AM. |
04-16-2010, 08:41 AM | #180 | |
BMW & ASE Master Certified
As far as the rotor its from a 2003 newer dodge ram 1500. As far as the new pattern I used a template I created in Autocad. Before I attached it to the face of the rotor, I got a pick and poked a small hole where the chevy pattern was (makes center punching it supa easy. I attached the pattern to the face of the rotor with some stuff called butyle aka dumb dumb (it's like sticky tack but for cars) and stuck it onto the face of the rotor. Turned it upside down and moved the pattern untill everything lined up. Silmply took a center pinch and hammer to mark the new pattern. Removed template and center punched the new holes a second time. Used a 1/8 bit to start with, then progressed to 17/32. Later I chosed 17/32 becuase it was a hair larger than 1/2 to give me a little wiggle room incase a hole was not 100% on the money. I will put a picture of the pattern I am refering to. Clint edit: heres the screenshot of the pattern I whipped up... the ones with the (X) is the dodge, and the other... obvious.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 04-16-2010 at 07:48 PM. |
04-16-2010, 09:24 AM | #181 |
They are available in dual patterns. Mine are 5x4.75 & 5x5.
04-16-2010, 06:14 PM | #182 |
PorterBuilt Man Crush
True on the above
I have been talking back and forth with Tobin at KORE3 the last couple of days. I am getting ready to buy their kit with 14" front and 6 piston C6/Z06 setup and 13.4 4 piston on the rear. If you skip the parking brake it is actually a reasonably priced kit. I just need to make sure the calipers will clear my wheels.
The 72 will live again |
04-16-2010, 08:51 PM | #183 | |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
04-16-2010, 09:41 PM | #184 |
looking at kore3's site, its around 1100 bucks
http://www.kore3.com/proddetail.php?prod=10336-03 nice stuff but just out of the budget... plus that might be way too much brake for a normal truck...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
04-16-2010, 10:34 PM | #185 |
Granted I said reasonably priced..for what you get. I am looking at getting their complete kit as I described minus the calipers since I have a hookup for GM parts at cost. This will cost me 1500 plus whatever the calipers cost me, so I am hoping to be right at 2-2100 for the total cost.
I compare this against what I bought from ECE which was a 4 wheel disc brake kit all stock parts with CD&S rotors for $1500. This means I get the bigger rotors and much much better calipers for around 600 more than the other kit cost me. That is reasonable to me.
04-19-2010, 06:32 PM | #186 |
67-72 parts collector,…
Got my Captainfab D52 rear caliper brackets today.
Excellent quality product! Thanks again for designing and manufacturing these brackets.
04-19-2010, 11:49 PM | #187 | |
60-66 Nut
Thanks for the compliment Keith
04-21-2010, 09:34 AM | #188 |
looking forward to getting my captain fab d52 caliper brakets, my willwood calipers and disc/disc prop. valve came in sat via fed ex truck. i also went yesterday and got the rotors and a dual diapram booster to go on one of cap. fabs booster brackets. everything is painted and disassembled ready for an upgrade, i cant wait to see the difference manual brakes to four wheel power disc brakes make. lolife 99 did you get your lines yet, just wondering if anyone has figured that part of the process out yet? also what brake pads to use, hmmmm.....?
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
04-21-2010, 10:00 AM | #189 | |
Any line that accepts a 7/16-20 banjo bolt will work. Speedway Motors sells them in rubber ($39/pair) or steel braided ($49/pair) for a reasonable price. Make sure you get D.O.T. approved brake lines. Any stock D52 pad will work. (Same as the front disc brake pads)
04-21-2010, 10:10 AM | #190 |
Happy to be here
Really? Makes you wonder why any one buy rubber if stainless is only $10.00 more. I guess thats for the retro builds.
04-21-2010, 10:27 AM | #191 |
Don't the rear brakes use hard lines?
1968 LWB C20 / AC / Wood Bed |
04-21-2010, 10:32 AM | #192 | |
Part# 617-8563 $39.99/set (Includes banjo bolts, clips, and brackets) Steel braided: Part# 617-8562 (front 16" hoses) $49.99/set Part# 617-8564 (rear 8" hoses) $49.99/set
04-21-2010, 10:34 AM | #193 |
Rear disc brake calipers require a flex line.
Ususally a steel line is mounted to the rearend housing and then converted to a flex line at each rear wheel.
04-21-2010, 10:36 AM | #194 |
Happy to be here
Thanks for sharing the part #s Keith.
Normally yes. In this application they are using front calipers on the rear so it requires the same soft line.
04-21-2010, 10:41 AM | #195 |
It'd be alot cooler if you did
I might add that I found out the hard way that the front flex lines for a 67-72 are much shorter than those for a 73-87.
04-21-2010, 03:16 PM | #196 |
Wow - I just realized i screwed up! I ordered four of the same front caliper . For the back I need the one with the smaller piston ? I ordered from jeff and he said something about it but i thought he was talking about rotor width ? Can someone chime in on this - Thanks
04-21-2010, 03:33 PM | #197 | |
04-21-2010, 03:53 PM | #198 |
04-22-2010, 01:21 AM | #199 | |
60-66 Nut
Your parts shipped out today. If you didn't get an email with tracking info, let me know. Thanks.
04-22-2010, 07:24 AM | #200 |
i got my smaller piston calipers (willwood) from jegs, i belive they measured 1.25 or 1.5, i know the front calipers measured 2.0. i will have to double check the rear calipers measurement to be certain
