Old 05-05-2010, 08:00 PM   #1
jfweaver
To Blast or???
Are you guys blasting the cabs or hand sanding? Just need help getting rust off my cab.
anyone know what it cost to blast the cab?
jfweaver is offline   Reply With Quote
Old 05-05-2010, 08:26 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: To Blast or???
Kabwe on his 55-58 build thread just posted to me a source for blasting that charges $250 to blast his cab and said everyone else quoted him $400. Now $250 is better of course, but either price strikes me as pretty reasonable compared to the EFFORT and MESS that manual sanding would be. I'm going to have the components of my '46 bed blasted using his source, then later the hood and front fenders and I'll decide on the cab itself later.
Dan in Pasadena is offline   Reply With Quote
Old 05-05-2010, 08:41 PM   #3
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Re: To Blast or???
I don't recommend sand blasting on these trucks. The sand gets caught up in between the roof panels, cowl panels, etc. Then it collects moisture and rots from the inside out.
I do however recommend soda blasting, it's blasting with baking soda. Works just as well as blasting and doesn't warp the metal. If it does get stuck anywhere it dissolves.
Cameron Gunlock
Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750
addicted2dunes is offline   Reply With Quote
Old 05-05-2010, 08:45 PM   #4
4DSEVEN
4DSEVEN's Avatar
Re: To Blast or???
I decided to go the sand blasting route and was glad I did. It wasn't cheap as it cost me $1600 cdn for the entire truck.
When I bought the truck the fenders were already smoothed, sanded and in primer. I decided that since I was doing most everything I might as well do the fenders over just to know what truly lies beneath. Man what an eye opener that was. The end result was 3 new fenders.
4DSEVEN is offline   Reply With Quote
Old 05-05-2010, 11:23 PM   #5
Thadious
Re: To Blast or???
I blasted all mine myself... cost me about $500 in the end, and I built my own pressure blaster, rented the 90 cfm compressor and 11 bags of medium crushed glass. Absolutely no warpage and I sure ain't no pro.
A fine painting begins with a fresh canvas!
Just my two bits, since I prefer to do everything myself... it's a pride thing.
Cheers!
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 05-06-2010, 01:41 PM   #6
Dan in Pasadena
Re: To Blast or???
Cheers!
Ted.
"Thadious J. Whoopee, You're the Greatest" Sorry, I couldn't resist. With that screen name you must have gotten this before now. I can't remember what cartoon it came from though?
As to the blasting, can we get more info about "making my own pressure blaster". I'd love to see how you did that.
4DSeven, You're right about a clean canvas. Your truck in pieces looks so clean - excellent! Not like working on a rusty old piece of crap like many of these trucks start out prior to painting.
Old 05-06-2010, 02:21 PM   #7
Thadious
Re: To Blast or???
No idea... never heard it before actually. The tag came from someone asking me one day what 'Ted' was short for... Thadious? And it just kind of stuck.
I'm just one of these people that refuse to pay someone good money for something that I think that I can do myself... and besides... you learn something in the process and have new tools left over in the end!
Not to hyjack a thread... but the pressure blaster started out as good clean 30 lb propane tank, purged and cleaned, with 2" nipple cut out and welded to the top, a handfull of 1/2" ball valves, some flexible line, a pressure regulator and relief valve and a pressure guage fitted. Then a long length of flexible brake hose with a deadman valve at the end. Mount the whole thing to a 2 wheel dolly with a leg out the front and you're good to go. (Would highly recommend spending the little bit to have it hydro'd for safety!).
There's a pic of it in my build thread.
Cheers and good luck,
Ted.
Old 05-06-2010, 10:16 PM   #8
mr48chev
mr48chev's Avatar
Re: To Blast or???
If you take the cab to a blaster make sure that they do sheetmetal on a regular basis as some of the guys who normally blast heavy or farm equipment may be too heavy handed with the blaster and warp the panels. If you can find one that is tied in with a powder coater they may be more used to items that need a fine touch.
Old 05-07-2010, 12:01 AM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: To Blast or???
Phineas J. Whoopee was the mad scientist from the cartoon Tennesee Tuxedo
Old 05-07-2010, 09:18 AM   #10
chevyrestoguy
chevyrestoguy's Avatar
Re: To Blast or???
And Chumley, too! (that was a line from the cartoon). Didn't Professor Whoopee use the 3-Dimensional Chalkboard to prove his theories?
I need one of those.......
chevyrestoguy is offline   Reply With Quote
Old 05-07-2010, 11:28 PM   #11
solidaxel
solidaxel's Avatar
Re: To Blast or???
............... O H BOY, watch out, he said alot !!
We spent many, many hours trying to straighten out these problems on doors and hood and the back of the cab on TWO projects.
Be careful who you chose, these cabs and sheet metal will WARP big time !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-08-2010, 01:56 PM   #12
54 jimmy
54 jimmy's Avatar
Re: To Blast or???
my cab is going on the 21st to get blasted. this guy does p coating too and i have seen some of the stuff he has blasted came out nice no warping.i asked for a quote he said $60.00 an hour. that is a good price i think. he also said if it only takes an hour and a half it will be $70.00.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 05-12-2010, 11:07 AM   #13
56ClassicTruck
Re: To Blast or???
I talked to guy out that dose plastic blasting he said it just takes off paint not rust an no damage to the metal what do you guys think of that.
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 05-12-2010, 11:35 AM   #14
Dan in Pasadena
Re: To Blast or???
I've heard all these warnings about warping sheet metal and I'm going to be asking a LOT of questions before I commit to someone. I've got Kabwe's referral to a guy and two other guys through people I trust too, so I should be able to find 1 of 3 that knows how to do sheet metal and will do it reasonably priced.
Old 05-12-2010, 12:26 PM   #15
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: To Blast or???
Well I've been getting my cars blasted for years and never had a issue so I can speak on that. The place I go does cars all over California its most of their business so they can't go around messing up peoples cars or they will be out of business. They use a very fine sand that looks like powder its so fine. Also I use SPI epoxy primer and they will not honor the warranty if you soda blast the metal. Soda blasting leaves a residue that does not help adhesion. I can only go by my experience and I have had zero problems with media blasting.
Dan here is an link to an article that was done on the place I recommended, read it you may like it. It was one of the reason I chose them because I don't know anybody that put time, love and money in the cars like the lowrider crowd.lol The chrome alone could buy a house in some states.lol
http://www.lowridermagazine.com/tech...ing/index.html
Kabwe is offline   Reply With Quote
Old 05-12-2010, 01:24 PM   #16
Dan in Pasadena
Re: To Blast or???
Kabwe,
Thanks so much for the link. Unfortunatley I can't access it from my work computer but I'll defintiely look forward to reading it tonight.
If the place primarily does cars then I would agree they are VERY careful not to warp anything or word would get out and they'd lose business fast.
