Old 06-07-2010, 02:49 PM   #1
Redcap
TH350 & NP203 to NP205?
I have a TH350 married to a NP203 that has been used pretty hard and I don't trust it at all. I'd like to replace it with a NP205 and have access to one off of a TH350 (and adapter), but I'm curious to know if this is a direct swap or if driveshafts will need to be shortened/lengthened or if there are any other snags with this swap?
Thanks!
Redcap is offline   Reply With Quote
Old 06-07-2010, 07:13 PM   #2
70 beast
Certified Hobbiest
70 beast's Avatar
Re: TH350 & NP203 to NP205?
there will be drive shaft alterations but otherwise its a bolt n go swap.
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 06-07-2010, 11:55 PM   #3
MacSic66
Active Member
MacSic66's Avatar
agreed! i did it in my 75, bolt on, moved the t-case crossmember to the next set of holes, driveshafts will have to be adjusted, shifter comes up in the same hole even..
No vehicle is "too nice" or "too straight" to cut up.
MacSic66 is offline   Reply With Quote
Old 06-11-2010, 08:34 PM   #4
84 400
Sb 400 club
84 400's Avatar
Just did it this past winter
Truck was a 1977 k10 Short bed. THERE IS NO NEED TO MOVE THE TRANSMISSION CORSSMember If using a th350!! in a truck that had a th350!
You need to lengthen the rear drive shaft and get a shorter front shaft. On the front shaft you can get a drrive shaft out of a truck optioned with a sm465np205 witch is the shortest shaft out there and get a longer slip yoke. I have the part number if needed. Or you can cut down the np203 front drive shaft. You will also need the 4 bolts to attach the adapter to the transmission in which the top two need to be longer then the bottom two. I would also do new mounts.
Also double check that both use 27 spline? input and out put shafts. There are a few odd balls with 30splines?
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
