Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-07-2010, 11:23 PM   #101
VA72C10
VA72C10
VA72C10's Avatar
Re: 71 Blazer "Finishing Touches"
Originally Posted by Slick67 View Post
Wow! It's been a long time since I looked in on this one. You rock!! It is really looking great, wish I lived closer so I could come by and give you a hand!
Thanks, just got back from block sanding. Primer is on it...
Had a few setbacks and made a decision to do a second coat of primer after some filler. After I put my daughters in bed I will get back on and post up some pictures.
Old 07-07-2010, 11:38 PM   #102
Slick67
Sofa King Crazy!!
Slick67's Avatar
Cool. All us picture wh*res need a fix! G'night kids!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-08-2010, 12:26 AM   #103
VA72C10
VA72C10
VA72C10's Avatar
Well, here are pictures from Tues night to bring you up to speed...
Got my rear panel mounts and tailgate parts painted up
Then started taping....
Old 07-08-2010, 12:33 AM   #104
VA72C10
VA72C10
VA72C10's Avatar
Then, I get a text late morning today....big gust of wind and the paint booth leaned over. Didn't do any damage to the truck but the plastic ripped and since the wind was on and off....we decided to move the truck inside the shop after all....so a day wasted on a booth....oh well. things happen.
Jason got a first coat of primer on everything but the new tailgate and the doors. Came by to block sand this evening. A couple spots that looked fine before primer need more attention (amazing how it shows things up) so we're going to use some "icing" (lightweight filler/putty) to get those perfect and then sand and apply one more coat of primer before paint. The truck is coming out so nice and everything else is so nice we decided to take the paint job to the next level.
Took the hood off and sanded that down...had some runs in the finish that weren't going to be up to par with the build. Re-doing the fenders even though the PO had jammed them because there were some scratches from his fitting them on. And re-doing the windshield frame because of some small scratches.
Here's the hood, some of the blocking tools we used, and the SPID which I'm not sure I'd posted before...
Old 07-08-2010, 12:35 AM   #105
VA72C10
VA72C10
VA72C10's Avatar
Some of the parts in primer
Old 07-08-2010, 12:37 AM   #106
VA72C10
VA72C10
VA72C10's Avatar
And the blazer in primer....got it and all the parts blocked out nicely tonight. The primer is like glass but there are those few spots we want to touch up so one more final coat after that tomorrow and then blocking one more time before sealer, paint, and clear.
Old 07-08-2010, 12:39 AM   #107
VA72C10
VA72C10
VA72C10's Avatar
For those that hadn't followed from the beginning, the windshield frame, dash, and firewall are all finish painted already. So the windshield was installed after the paint. We're re-painting the frame for some scratches (from the top going on/off) but just taping off the gasket since it's already painted and cleared under the gasket.
Old 07-08-2010, 12:46 AM   #108
treveiger
treveiger's Avatar
Awesome blazer i love those things. what kind of texture paint did you put underneath? Was that for rust proofing?
treveiger is offline   Reply With Quote
Old 07-08-2010, 06:19 AM   #109
67chevy1series
67chevy1series's Avatar
great job hope my 67 pickup comes out that good on bottom and top
67chevy1series is offline   Reply With Quote
Old 07-08-2010, 08:39 AM   #110
mcbassin
Still Learning
mcbassin's Avatar
Looks like some great progress! Sorry to hear the wind won't give you a break. I need to get a few of those sanding blocks.
Old 07-08-2010, 09:23 AM   #111
VA72C10
VA72C10
VA72C10's Avatar
POR 15 was applied to the entire frame, undercarriage, in the rocker boxes, and in the cowl. Then the PO used bedliner for durability in any areas where rocks could get thrown up. I finished a few spots he hadn't gotten to yet (rear wheel wells and inner fenders)
Thanks. Really happy with it so far.
Thanks. Not a big deal. It's worked out fine just means my project took over his entire shop The blocks worked great for some of the body lines like the top rail and the curves/wheel arches. However, some parts it was still better for just good old hand sanding. They do make tons of other blocks but it would be too pricey to buy all of them you needed unless you did body work only full time.
Old 07-08-2010, 10:00 AM   #112
sourkraut
sourkraut's Avatar
looks great! i bet you are getting excited!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 07-11-2010, 01:00 AM   #113
VA72C10
VA72C10
VA72C10's Avatar
Definitely. There have been several delays including primer that kept drying in the paint gun hopper due to a bad batch in combination with the heat...but we're still pressing on.
Got all the parts with one coat of primer and block sanded. they all look great. have some small work to do that Jason used "icing" on tonight (light filler)
His plan now is to have it in color and clear by Thursday at the latest. He's as ready as me to have this done as he has other projects waiting in addition to his daily flow of small jobs like timing chains, axles, pinion seals, ac compressors, etc etc...
Here are some more picture of parts after sanding...
Old 07-11-2010, 01:04 AM   #114
VA72C10
VA72C10
VA72C10's Avatar
I worked on a couple of small projects tonight. Got a aluminum ring for the 4wd boot that came with machine marks. Been working on polishing up. got that finished up tonight. Before:
During:
Getting there...600 grit wetsanded with liquid aluminum polish
Better...1000 grit
2000 grit and a buffer....
and finished
Old 07-11-2010, 01:09 AM   #115
VA72C10
VA72C10
VA72C10's Avatar
Also rebuilt a tach dash I bought off ebay....
Polished the lens, cleaned it all up, and installed new bulbs, printed circuit, and bezel
Old 07-12-2010, 08:58 PM   #116
0331grunt
Now what??
0331grunt's Avatar
Looking great! The aluminum polished up amazing!! Awesome work!
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 07-12-2010, 11:07 PM   #117
mcbassin
Still Learning
mcbassin's Avatar
Nice work! I got some stuff I need polished whats your address?
Old 07-12-2010, 11:08 PM   #118
mcbassin
Still Learning
mcbassin's Avatar
ooops
Old 07-13-2010, 01:01 AM   #119
VA72C10
VA72C10
VA72C10's Avatar
Thanks! It was a lot of work...probably too much time for such a small part...but the details make it sometimes....right???
See above.....no thanks
ooops
Old 07-13-2010, 01:10 AM   #120
VA72C10
VA72C10
VA72C10's Avatar
Went through my final boxes of parts to come up with a final list (until I start final assembly and find more things I need )
Seems like I have or have ordered everything minus some weatherstrip for the top. Got it all ready to take over to the garage as soon as paint is dry/cured.
I spent a little while cleaning up the visors more and also cleaned up the shift boot...it was a little dirty compared to the ring I polished up for it
Both came out looking like new so I was pleased
no before....
After....
here's the boot before
and comparing the old ring to new.....a SLIGHT improvement....
Can't wait to see it all together
Old 07-13-2010, 02:48 AM   #121
67chevy1series
it shall look rather smashing
Old 07-13-2010, 10:35 AM   #122
hgs_notes
GEARHEAD
hgs_notes's Avatar
Unbelievable good fortune finding this truck. Can't wait to see the paint on it.
hgs_notes is offline   Reply With Quote
Old 07-14-2010, 12:38 AM   #123
VA72C10
VA72C10
VA72C10's Avatar
thanks!
I feel very fortunate....I'll feel more so when I sell it....
I am really looking forward to paint too
Now the plan is Thursday....we'll see....he's got a lot going on right now....and I really don't want to rush it....it's such an awesome blazer the final sanding/paint has to be up to the level of the rest of the truck.
Got some more final parts ordered today and hopefully will have the carpet and the weatherstrip on the way tomorrow...
Old 07-16-2010, 01:49 AM   #124
VA72C10
VA72C10
VA72C10's Avatar
Well, no color yet...but the good news is it's getting slicker and slicker....
Jason sprayed a second coat of primer the other day, block sanded it with 320, and used "icing" lightweight filler to touch up a few areas he wasn't happy with. this stuff is very thin and fills super small variations. Here's a picture with the icing sanded down...
Then he sprayed the third and final coat of primer. Then we blocked with 320, 400, and just for grins 600 I'm happy I decided to do the 600 because now the primer is SUPER smooth and actually has a reflective sheen it's so smooth. Should lead to an awesome paint job. Glad we've taken the extra time to get this thing RIGHT!!!
Old 07-16-2010, 01:52 AM   #125
VA72C10
VA72C10
VA72C10's Avatar
the amazing part to me is that the areas you see in the top picture looked perfect and felt perfect after the first block sanding on the first coat of primer....it wasn't until he broke out additional lights and put them at differing angles that he saw that. Probably would have looked great w/out this extra work but now it will be a really nice paint job!
