Old 07-12-2010, 06:58 PM   #326
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project: Recycle
That looks very nice. Probably nicer than the ones I was looking for...Sorry I could not help out with a spare set sooner for you.
Once those are painted and back together with new seals, no one will ever know they were so bad...
Great work!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-12-2010, 07:43 PM   #327
SCOTI
SCOTI's Avatar
Great work!
I was intending to send you a PM regarding this tonight. Thanks for the offer regardless!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-12-2010, 09:21 PM   #328
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome work SCOTI; love the cluster and some real nice work on the wing windows.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-15-2010, 11:56 PM   #329
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I'm up to date now. It's hard to keep up with everyones build. Nice work on everything. The vent window looks great.
Alan's Classic is offline   Reply With Quote
Old 07-23-2010, 08:04 PM   #330
SCOTI
SCOTI's Avatar
I'm thinking of changing hobbies..... Anyone have experience basket-weaving?
I still have a rear window gasket that's pinched in the interior corners.... I'm now going to try a different rear gasket from yet another source (3rd attempt). This newest one appears to have 'molded' corners w/the bbw length vs. a 157" straight piece of molding/gasket.
I tried mocking-up the brake lines.... I'm using a collage of year model parts (pre-bent lines) & that doesn't always go as planned. I ordered front lines for a 73-80; front to rear line for a 67-70; & rear housing lines for a 67-70. The first issue I found was there was no 'front' half of the rear line. Apparently 67-70's are considered 2pc thus you need the front & rear while 73-80's are different. Since I ordered the 73-80 front stuff, I'm missing that 'front' portion of line that exits the prop-valve & 90's toward the rear (for the rear brakes).
The pre-bent kit will work as I've mocked them up previously on the PB-DM v1 in my 68 (that's version 1 for those out of the DM loop ). But, the front 'kit' now has to work w/my R&P c-notch reinforcement plates (this is different vs. my other frame/mock-up). I did some preliminary install & needed the control arms, spindle, & caliper in position to ensure everything will co-exist. I grabbed the a-arms only to realize this Dropmember is the revised 'v3' & doesn't use the lower a-arm shafts. Since these arms were originally on my 68 which had the DM v1, the shafts are installed (w/brand new bushings). So.... just to test the fit of everything, I had to knock out a new bushing to remove the shaft (destroying the bushing of course). Now I have to go get another bushing to pop in just to test fit.
I ordered a front to rear fuel line for a blazer. I figured the length difference between the swb truck vs. a blazer could be made up w/a slightly longer rubber line from the tank to frame union. The line they sent is approx the length from the fuel pump area to the back of the cab. No freakin' way it's long enough for a blazer. Now I'll need to splice in some line to fill the gap.
See how well it works for me? 'Scot-Luck'....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-24-2010, 01:18 AM   #331
Captainfab
60-66 Nut
I don't know about the Blazers, but on my '66 Suburban, the steel fuel line from the fuel pump back appears to be the same as a pickup. Then there is another line that goes from under the 'cab' back to the tank. The two are connected under the 'cab' with a short piece of hose in a U shape. Maybe the Blazers are the same?
Old 07-24-2010, 03:47 AM   #332
SCOTI
SCOTI's Avatar
The kit did include another short section of hard line but the 'bends' are waaaaaaay off from what the frames shape is plus the ends of the line had threaded fittings (not sure why).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-25-2010, 01:28 AM   #333
Captainfab
60-66 Nut
Threaded fittings on a fuel line? Strange.....
Old 07-25-2010, 03:41 PM   #334
SCOTI
SCOTI's Avatar
Here's a few pics of what the 'kit' consists of. I laid the long piece out on another swb frame to get an idea of length vs. placement on the frame:
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-25-2010, 03:49 PM   #335
lolife99
67-72 parts collector,…
lolife99's Avatar
Those look like "truck fuel lines",... with the short piece being the line that extends thru the cab floor from the in cab tank.
Keith
Convert to disc brakes.
Old 07-25-2010, 05:34 PM   #336
SCOTI
SCOTI's Avatar
That's what I was thinking as well but all of my OE 67-68 fuel lines & tanks have been scrapped so I didn't have anything to compare it to.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-25-2010, 07:03 PM   #337
franky69c10
chevy runs deep
franky69c10's Avatar
Look'n good
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 07-25-2010, 09:31 PM   #338
lolife99
lolife99's Avatar
It looks like what I just took out of my 70 stepside.
Keith
Old 07-25-2010, 10:15 PM   #339
Painter D
Painter D's Avatar
Look like truck lines to me too.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 07-26-2010, 12:59 AM   #340
SCOTI
SCOTI's Avatar
Guess I'll make a phone call then 'cause that's not what I paid for (next to last line)....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-26-2010, 10:52 PM   #341
SCOTI
SCOTI's Avatar
I called & spoke w/someone today about the fuel lines. He asked me to e-mail him my pics so he could get an idea on the length of the lines. Hopefully there will be some quick follow-up....
Tonight, I just about finished up the front rubber/flex brake line routing. I still have a couple of quick items to cut/clean. Then, I need to figure out how I'm going to attach the lines to the upper ART a-arms to keep them out of harms way....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-27-2010, 09:12 AM   #342
N2TRUX
Happy to be here
N2TRUX's Avatar
..... I need to figure out how I'm going to attach the lines to the upper ART a-arms to keep them out of harms way....
I will be watching for this. I need to do the same on mine. The black zip ties are working, but it doesn't look very high tech.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-27-2010, 09:52 AM   #343
Jonboy
Slots go on anything!
If the zip ties are working, maybe some adel clamps will work to secure them to the frame?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-27-2010, 12:06 PM   #344
SCOTI
SCOTI's Avatar
It's securing them to the arms that's problematic.
They make nice clean 'clamps' for attaching brake lines to tubing (roll cages/frames) but they're only available in .250". The rubber flex lines are .375" & I'm not sure there's enough material to simply drill them out....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-27-2010, 12:22 PM   #345
Jonboy
They make rubber insulated ones. I am not sure, but it seems like there may be different sizes too.
Old 07-27-2010, 12:44 PM   #346
SCOTI
SCOTI's Avatar
I have something on the way to try. Regardless, I'll post up what I eventually use.
No zip ties for me.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-28-2010, 08:55 AM   #347
N2TRUX
Happy to be here
N2TRUX's Avatar
I looked at them again last night when I installed the e3 ride height sensor in the front. I don't see a lot of options. I do not want to drill holes, and a clamp around the arm would be huge. I am waiting to see what you have come up with.
Articles-
"Refining Sierra"
Old 07-28-2010, 09:04 AM   #348
Jonboy
There are already holes drilled in the arms for the brake lines to attach to. Another hole or two (especially with a screw in it) shouldn't hurt anything.
Old 07-28-2010, 09:33 AM   #349
lolife99
lolife99's Avatar
I think Scot and Ken both have tubular a-arms from RideTech.
Keith
Old 07-28-2010, 10:39 AM   #350
SCOTI
SCOTI's Avatar
Correct. We have aftermarket tubular ART arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
