07-27-2010, 07:36 PM | #26 |
It followed me home?
Re: Is something wrong here? thought I'd be lower...
after pulling the shims, right now there are no cups in the arm but here a picture
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-27-2010, 07:39 PM | #27 |
What brand drop spindles are you using?
07-27-2010, 07:40 PM | #28 |
Not sure what they are, I didnt buy them. I think they might be chassis tech though
07-27-2010, 07:42 PM | #29 |
Garage wrench
those cups look a little tall, how tall are they?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
07-27-2010, 07:49 PM | #30 | |
And the cups look to be too tall. I'd say at least a half inch can be removed. Last edited by edflores; 07-27-2010 at 07:50 PM. |
07-27-2010, 07:50 PM | #31 |
2" but it wont go all the way down even with them out.
07-27-2010, 08:05 PM | #32 |
I installed them
07-27-2010, 08:07 PM | #33 |
67-72 parts collector,…
Adam,...
That plate in the picture is your upper plate,... correct? Do you have any pics of the lower a-arm in this same configuration? You're not running a lower a-arm plate also???
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-27-2010 at 08:09 PM. |
07-27-2010, 08:13 PM | #34 |
here are a few I took yesterday, nevermind the rag in the LCA please I just set it there so the bag wouldnt rub the bump stop that I will be grinding off later. Not sure if these are what you need
07-27-2010, 08:16 PM | #35 |
more
07-27-2010, 08:18 PM | #36 |
I don't see how you could get any lower.
The cups can be cut down to 1.625" total height,... and the bag will take up approximately 3". I think you are as low as possible. I would be worried about your upper ball joint bolts, cutting the rubber boot at full drop. You might want to turn them around.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-27-2010 at 08:20 PM. |
07-27-2010, 08:22 PM | #37 |
Im going to take a guess on the situation. You may have 2.5 drop spindles, not 3".
Also, your tires are too tall. Do a 245/35/20 instead. Lastly, your cups are too tall. Cut as much as you can |
07-27-2010, 08:46 PM | #38 | |
turn them around?
07-27-2010, 08:57 PM | #39 | |
Garage wrench
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 07-27-2010 at 10:26 PM. Reason: lack of intelligence |
07-27-2010, 09:31 PM | #40 |
Laid Lo
Ok, a couple things:
1: The bolts for your upper ball joints are in backwards. The nut should be up with the bolt head down. 2: You do have drop spindles, I can plainly see the back of the spindle in one of your pics. It is higher (more towards the middle) than stock ones so it's a drop spindle for sure but may not actually be 3" probably a 2.5" or 2". You have to flip the bolts for sure.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
07-27-2010, 09:48 PM | #41 | |
I'm almost 100% sure they are 3" spindles as they rubbed my 15" rally's pretty good, I dont think a 2.5" spindle will cause any rubbing
07-27-2010, 10:01 PM | #42 |
GM Addicted
what would flipping the bolts on the ball joints change??
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
07-27-2010, 10:04 PM | #43 |
Laid Lo
Probably won't change anything for his getting lower problem but it will keep the bolts from cutting into the rubber boot.
07-27-2010, 10:08 PM | #44 |
Laid Lo
More info on ball joint install and a pic of moog install instructions here:
http://67-72chevytrucks.com/vboard/s...d.php?t=384744
07-28-2010, 05:04 PM | #45 |
pull the bags and shocks to check the travel of the ball joints, thats the easy way, the, add parts back in until you find the binding point.
07-29-2010, 09:27 AM | #46 | |
its just $$$$$
I think they are 2.5" Drop Spindles Cut the cups down to 1 5/8" DON'T go to a 245/35..you will hate yourself if you do |
07-29-2010, 10:09 AM | #47 |
Just Z your frame and call it a day...
07-29-2010, 10:22 AM | #48 |
Happy to be here
Dude, put your sawz-all away....
07-29-2010, 12:34 PM | #49 |
A sawz-all and a welder can fix anything though...
It looks like his bag is fully compressed so I don't think modding the ball joint angle will help any. I have 3" spindles on mine and I know my arms didn't max out the ball joint like that when I was running this same set up. My lower cups were a lot shorter than that too. |
07-29-2010, 02:19 PM | #50 |
Wrong post
