Old 03-11-2010, 10:03 PM   #1
indyrenegade4x4
indyrenegade4x4's Avatar
new project 1987 K5 blazer 4x4
I got this for $245.00 bucks. Has an 89 blazer motor in and has several wiring issues. Needs new doors and rocker panel. Have an extra back tailgate glass for it and a back bench seat and two buckets I need to get rid of.
indyrenegade4x4 is offline   Reply With Quote
Old 03-11-2010, 10:10 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: new project 1987 K5 blazer 4x4
Not bad at all!
tvblazer78 is offline   Reply With Quote
Old 03-11-2010, 10:16 PM   #3
Tony_SS
Tony_SS's Avatar
sounds like a good deal!
Tony_SS is offline   Reply With Quote
Old 03-22-2010, 01:02 AM   #4
z3pr68138
z3pr68138's Avatar
What kind of wiring issues ?? Could be as simple as a salvage yard wire harness.
z3pr68138 is offline   Reply With Quote
Old 04-29-2010, 08:09 PM   #5
indyrenegade4x4
got some parts collected for it. Got a set of 38x15.5x16.5 dick cepek fun country tires. Two 12" front lift springs. I got a 5.3 ls motor.
Old 04-30-2010, 12:46 PM   #6
justpball
justpball's Avatar
nice brah, now get to work! LOL and post up pics as you go!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-30-2010, 09:47 PM   #7
indyrenegade4x4
pulled back carpet out and rust is pretty bad. Not sure how to approach it. A southern rust free tub would be the best way to go. Gonna put older 350 in it for summer and drive it around. Then over the winter do some body work of some sort and motor swap,lift etc.
Old 06-14-2010, 08:37 PM   #8
indyrenegade4x4
worked on engine last week and it is seized up at the moment. Going to pull it apart and see how bad it is. Other motor I had is junk. It was free at least. Not sure what to do if this motor is complete trash. Started taking core support out today so I can get to motor easier.
Old 06-15-2010, 08:40 PM   #9
indyrenegade4x4
got core out tonite and got most of the front of motor taken apart. Took valve cover off and looks real nice and clean in there. If this motor is trash im going to go talk to guy I got it from and find out what he was thinking for letting it sit.
Old 06-16-2010, 09:23 PM   #10
indyrenegade4x4
got heads off and motor turned over by hand. No rust in motor cylinder walls. Need gasket set and motor can go back together
Old 06-26-2010, 10:39 PM   #11
indyrenegade4x4
got the top end put together today and cranked over under its own power I have to hook fuel and wiring back up
Old 08-02-2010, 01:36 PM   #12
70stroker
70stroker's Avatar
any updates on this?
70stroker is offline   Reply With Quote
