08-10-2010, 11:45 PM | #1 |
Rack & Pinion on Stock Crossmember?
I am looking for a way to mount a rack and pinion to a stock 67 C10 crossmember. I have seen the Flaming River setup, but it looks expensive. How can I make a bracket to bolt a used rack in front of the crossmember, but low enough to miss the pan?
Also, what rack would be long enough to span a truck, have the right threads for the C10 tie rod ends, have the steering shaft in the right spot, and be tough enough to handle getting beat up? It looks like all the MII racks need studs welded on the front crossmember to mount, and that would be fine, if I could find someone that will sell me a bracket with a stud on it that would weld to the front of my crossmember. Now thats the type of DIY article I wish the magazines would publish. |
08-11-2010, 11:33 AM | #2 |
Re: Rack & Pinion on Stock Crossmember?
I too am interested in this! You can buy new x-members but like you said, they are expensive. Maybe you would have to cut out part of frame? IDK
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
08-11-2010, 11:54 AM | #3 |
When you guys get it figured out, be sure to share the results w/the group. What's wrong w/just getting a spec built factory ball & sector style box & using high quality steering parts?
08-11-2010, 11:57 AM | #4 |
Well, mine is bagged so I would need to somehow mount it above the frame or in it I think.
08-11-2010, 01:38 PM | #5 |
what advantage does the R&P offers over a stock style steering box?
08-11-2010, 02:24 PM | #6 | |
Never Ending Projects
The recirulating ball boxes (like stock) worked fine for their entended use but they will not be as good as a R&P setup. If you look almost all auto companies have moved over to R&P setups.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-11-2010, 02:36 PM | #7 | |
One of the best aftermarket companies around that does the suspension thing (Detroit Speed; ran by former GM drivetrain engineers no less) utilize OE steering box set-ups vs. a R&P swap. I think a R&P offers better packaging for certain applications for sure, but a recirc-ball box built right w/the correct supporting hardware can work as well.
08-11-2010, 02:52 PM | #8 | |
Agreed that stock boxes CAN work well and that is what I had on my Camaro (well aftermarket quick ratio stuff) since I was still using the stock sub-frame. I was REALLY deep into the Pro-Touring scene before my divorce and had to sell my Camaro. When it came to all out handling, most of those guys would spend the bucks to get things switched over to R&P since they were building seriously handling cars. No one who switch every wanted to go back to a stock box/draglink system ever. YMMV
08-11-2010, 08:17 PM | #9 | |
it has very very little to do with handling and everything to do with lower manufacturing & assembly costs (less parts) and more profits for the OEM's. it's called marketing. I spent quite a lot of time doing work flow, time studies, automation/machining and in process inspection processes for one of the largest producers (TRW) of both recirculating ball boxes and R & P units. guess which one costs a LOT less to manufacture? |
08-11-2010, 09:31 PM | #10 |
My point earlier was that DSE uses the recirulating ball boxes on many of their builds w/great success. Their R&P set-up is only available w/their Hydroformed sub-frames.
I equate DSE's front HF sub-frames to an aftermarket frame/part. And they're a high end part @ that (beyond Dropmember territory in 'truck-speak'). If they use the stock/OE sub-frame on a build, they'll use upgraded OE style boxes w/upgraded steering parts as it's not worth retro-fitting a R&P set-up because it won't be optimum. I feel there's much improvement available just w/the stock stuff w/o the hassle of trying to figure out all the PROPER geometry required to truely benefit from the R&P swap.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-11-2010 at 09:34 PM. |
08-11-2010, 09:27 PM | #11 | |
Active Member
There are a lot of parts in either system. The road feel is controlled by the valve and torsion bar. All power racks use a large diameter torsion bar to provide more “feel”. Most steering boxes can be had with new large diameter torsion bar and have the exact same feel as a rack and pinion. Most center links are curved to fit around the engine and mount the inner pivots in a position to minimize bump steer. All rack and pinions must be made straight, making a less than ideal inner pivot location. The exception is when the upper and lower control arms can be repositioned and changed to minimize bump steer. Power rack and pinion moving parts: 1 Rack and pinion has an input shaft connected to a torsion bar. 2 The torsion bar is connected to a control valve. 3 The control valve is connected to a pinion gear. 4 The pinion gear meshes with the rack gear. 5 The rack gear is runs back and forth thru the rack housing. 6 The rack housing is mounted on rubber bushings. 7 The end of the rack connects to the inner tie rod pivot. 8 The inner tie rod pivot is connected to the outer tie rod pivot. 9 The outer tie rod pivot connects to the steering knuckle. 10 The steering knuckle is connected to the upper ball joint. 11 The upper ball joint is connected to the upper arm pivots. 12 The steering knuckle is connected to the lower ball joint. 13 The lower ball joint is connected to the lower arm pivots. 14 The steering knuckle is connected to the inner and outer wheel bearings. 15 The inner and outer wheel bearings are connected to a wheel hub/rim. 16 The rim is connected to a rubber tire. Power steering system moving parts: 1 Steering box has an input shaft connected to a torsion bar. 2 The torsion bar is connected to a control valve. 3 The control valve is connected to a rack gear by a ball screw assembly. (Typically the ball screw is preloaded and has zero backlash.) 4 The rack gear meshes with the sector gear/pitman arm. 5 The rack gear is runs back and forth thru the box housing. 6 The pitman arm connects to the center link. 7 The center link is connected to the idler arm. 8 The end of the center link connects to the inner tie rod pivot. 9 The inner tie rod pivot is connected to the outer tie rod pivot. 10 The outer tie rod pivot connects to the steering knuckle. 11 The steering knuckle is connected to the upper ball joint. 12 The upper ball joint is connected to the upper arm pivots. 13 The steering knuckle is connected to the lower ball joint. 14 The lower ball joint is connected to the lower arm pivots. 15 The steering knuckle is connected to the inner and outer wheel bearings. 16 The inner and outer wheel bearings are connected to a wheel hub/rim. 17 The rim is connected to a rubber tire. Just a little more info to look at when trying to compare the different steering systems. Danny Nix CPP |
08-11-2010, 03:04 PM | #12 |
heres what i found, is a temporary mount but u get the idea.
http://c10forum.com/forum/showthread.php?t=3388&page=9 post 309,327-330 |
08-12-2010, 06:36 PM | #13 |
Thanks for the info. Sounds like there is a large manufacturing impact here, but what better way to judge performance than to load up 1000 backyard truck builders with a cheap R&P alternative and let them hit the street?
I took a look at http://c10forum.com/forum/showthread.php?t=3388&page=9 and having to notch frame seems extreme. I guess the reason the MII subframes get away with R&P is that the C-arm pivot shaft is a lot shorter? Looks like the stock C-arm has a bump in the stamping in the worst spot to sneak a rack shaft through. Would tubular C-arms have helped here? What about if he had dropped the rack down below the frame, and more forward, like I think Flaming River does? I think it has to be simple, cheap, and use available parts. |
08-12-2010, 06:46 PM | #14 |
Tubular arms definately would have helped but the frame notch is necessary. With the truck laid out if you draw a line from mounting point to mounting point on the spindles you will see it passes directly through the frame. Both Porterbuilt and Suicide Doors aftermarket cross members use this same method of notching the frame.
08-12-2010, 07:07 PM | #15 |
This has been one of those "there has to be a cheap and easy way to do it" topics for quite a while.
In short, there isn't a cheap or easy way to slap a rack on the factory crossmember and have an engineered result. You can slap it on and get the truck to go down the road, but if it isn't located in the proper spot it won't be a fun driving experience. Proper location requires a solid understanding/knowledge of suspension and steering geometry, and is best verified with a suspension analyzer software to ensure desired results. DV8 has done a good job of putting it together on his truck, but I am sure a lot of time/measuring/cutting/welding went into it. And I also know that he has more than an average understanding on suspension geometry.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-12-2010, 07:19 PM | #16 |
08-17-2010, 09:03 PM | #17 |
C-20 Long Stroker
Hey,
That reminds me of the old two out of three. Cheap Fast Quality You can have any two but never three. Wish someone made a good dropmember for a 1952 Suburban without having the wheel tucked in so far or have to use wheel spacers to get the desired look or track. Thanks, Dan
"A Hand Shake Is Your Word." Decodan ************************ 1951 Chevrolet Suburban 1952 GMC Suburban 1963 Mercury Comet 2-dr (Sorry, I know) 1963 Mercury Comet 2-dr Parts Car, (better than what I originally started with) 2010 F-150 4WD 2015 Subaru Outback (what the hey, got to have one that is not a gas hog) |
08-17-2010, 10:11 PM | #18 |
It's in the works.
08-19-2010, 10:45 AM | #19 |
Okay, the $64 question is.... what rack are they using in that pic above?
08-19-2010, 08:08 PM | #20 |
08-19-2010, 08:53 PM | #21 |
Cool. Never thought they would have been wide enough. Good info to know.
08-19-2010, 10:51 AM | #22 |
looks like a mustang II rack to me.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
08-19-2010, 10:54 AM | #23 |
I didn't think the MII racks were wide enough. The pivot point for the shafts were inboard too far to match up with the control arm rotation.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... Last edited by chevy_mike; 08-19-2010 at 10:55 AM. |
08-19-2010, 10:41 PM | #24 |
Truck and auto performance nut
I've also heard of t-bird racks being used.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
08-19-2010, 10:51 PM | #25 |
Here is the website with the truck build..
http://okcminis.com/showthread.php?t=8849 |
Tags |
pinion, rack, steering |
