Old 09-12-2010, 09:16 PM   #1
mcrich01
Question 5 lug bolt patten
I have a 89 Burban with a 5 lug bolt patten how hard is it to change to a 6 lug patten???????
Rakkasan 4 life
mcrich01 is offline   Reply With Quote
Old 09-12-2010, 10:36 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 5 lug bolt patten
Swap the axles and brake drums from a 4x4 rear axle.
The front can be done with a set of aftermarket 6-lug rotors that are used on the 67-70 disc brake conversion kits.
Early Classic Enterprises is a good source for the rotors. Just make sure your rotors are the 1.25" wide version, and it will be a bolt on.
Keith
Convert to disc brakes.
Old 09-13-2010, 06:53 PM   #3
mcrich01
Thanks Bro for the info but >>>DAMN do I have too swap the axle.......lol
Rakkasan 4 life
Old 09-13-2010, 07:17 PM   #4
nbpro
http://67-72chevytrucks.com/vboard/s...ight=6-lug+2WD dont no if this will help good luck
nbpro is offline   Reply With Quote
Old 09-13-2010, 07:54 PM   #5
lolife99
lolife99's Avatar
I think you can just swap the two axles out of a 4x4 rearend and slide them into your housing.
Keith
