Old 10-19-2010, 05:19 PM   #1
ozman3803
air bags again
Could I install my bags and just use individual schraeder valves for the time being until I set up a bag system? I really want to run bags but since I wont be running the whole set up should I just go with springs till I get the whole package?
ozman3803 is offline   Reply With Quote
Old 10-19-2010, 05:50 PM   #2
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: air bags again
You can do that, that's how mine is set up for now.
JNJchev77 is offline   Reply With Quote
Old 10-19-2010, 06:00 PM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: air bags again
like jnj said, it's quite acceptable to run schraders. to get the same fill in each bag, get a good digital tire pressure gauge, and viola!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-19-2010, 06:33 PM   #4
ozman3803
Re: air bags again
Cool, I was thinking there would less of a chance for a leak since there is less plumbing.
Old 10-19-2010, 07:16 PM   #5
tcb-1
tcb-1's Avatar
Re: air bags again
install all of your fittings with the proper Loctite, wrap a piece of rubber heater hose around the air tubes when they pass through metal, and you should have a tight, reliable system....
Doug
Old 10-19-2010, 08:51 PM   #6
kev2809
low n' slo
kev2809's Avatar
Re: air bags again
ive used loctite on my setup and no leaks. whichever you feel comfortable using, both should work fine.
tcb-1, is that your new ride in the avatar?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-21-2010, 09:12 PM   #7
tcb-1
tcb-1's Avatar
Re: air bags again
why yes it is!! still GM too!
Doug
Old 10-21-2010, 09:26 PM   #8
steppside69
steppside69's Avatar
Re: air bags again
I just use teflon tape, at least 3 full wraps and no leaks
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 10-21-2010, 10:57 PM   #9
ozman3803
Re: air bags again
thanks for the help guys. I may consider just bagging the rear for the time being till I can afford my ultimate bag set up. I bought the truck undriveable. It's tore down to the frame so just trying to get my rolling chassis built and hopefully be able to drive it next summer!
