#51 |
Re: [PROJECT] Laidout53 Part II
Thanks guys. I hope to hinge the bed floor so i can show the chassis details....
Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#52 |
VA72C10
![]() Join Date: Mar 2008
Looks great...I'd definitely do the hinged floor!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#53 |
What was I thinking?
It's coming right along..... Looking good! Are you planing on running wide whites on your 69 also?
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
#54 |
thanks justin. im not sure yet, i might run 22's.
#55 |
Hinge it like a tonneau cover.
#56 |
Junior Member
Very nice man. What are you using to cut the curved parts of the rear gussets?
#57 | |
Yep, thats how im thinking of doing it.
#58 |
Well made some progress last night and today. Got the frame gussets welded last night, and today i got the motor in place. Had to make the motor mount tabs and the tranny crossmember. Also picked up a new rearend housing for it since the old one is to wide.
Heres the pictures... Gussets welded (Lots of welding)... ![]() ![]() Tranny crossmember i fab'd up... ![]() ![]() ![]() ![]() Motor mount tabs.... ![]() ![]() Motor in place... ![]() ![]() ![]() New rearend housing, still needs cleaned up (about 4" narrower then the other one)... ![]() What do you think? Justin
#59 |
Well Got the housing cleaned up and the leaf spring mounts removed, and got the axle set in place. Had to switch back to my old 3-link wishbone setup since there wasnt enought room for the parrallel 4-bar. So i got both the lowers tacked in.
Heres the pictures... ![]() ![]() Lower mounts (nut is welded on the back of the tab) ![]() ![]() ![]() ![]() Cut the gusset out of the upper wishbone because the metal i used for it was pitted. Thinking of chroming the link bars.... ![]() Thanks Justin
#60 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Awesome work justin...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#61 |
TNT-MOTORSPORTS
lookin good ..... ! Lots of really nice work ...... ! Is the wish bone gonna be adjustable ?
#62 |
Justin looks great as always! Awesome work keep it up!
What will the ride height be at? As low as possible..... Posted via Mobile Device
#63 |
dude nice work.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#64 | ||
Thanks guys
Justin
#65 |
Junk Yartist
awesome progress
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#66 |
67cheby
![]() Join Date: Sep 2008
super clean !!
#67 |
Thanks guys
#68 |
Work on the frame a little last weekend and some this weekend, got the driveline hoop crossmember made and installed,still needs some kind of gusset. Also got the upper wishbone installed, front tabs on the wishbone still need gussets. I got the body mounts tacked into place also (frames going to be sandblasted so i didnt worry about cleaning them up).
Heres the Pictures... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() What do you think? Justin
#69 |
I think it's looking great! Who wouldn't..... I was about to start wondering where you was. LOL. No progress for a month. Geez... Na. Looking good! Can't wait to see this one one the ground!
#70 |
#71 |
67cheby
BEAUTIFUL work man you are knocking this one out of the park !!
#72 |
VA72C10
VERY NICE! Shame you had to put those crusty cab mounts on...
#73 |
Looking killer !! Get this done then back on to the c-10 !!! Great work !!
#74 |
TNT-MOTORSPORTS
#75 | ||
Thanks man... Thanks man... Haha, i know, thanks man.. Quote:
Soon enough ill be back on it...
