11-09-2010, 02:25 AM | #426 |
Re: Project: Recycle
Just got home from the shop.
Both the main rails are void of gouges, rust-pits, & production scars. Everything has a nice consistent 60 grit finish so the rails should look fairly smooth after blasting & color. Tomorrow morning, I'll hook up the trailer & head back to the shop to load them up (I already have all the other parts & x-members @ the house). After everything is in the same place, I'll take an inventory to make sure nothing was over-looked. If the parts match my 'list', I'll stop by 2 different PC shops for quotes. Price pending, I'll leave the parts @ one of them. I would put up some pics but my computer crashed & I'm using a borrowed laptop. Hopefully by the time the parts are done, I'll be able to start loading up some pics again.
11-09-2010, 10:27 AM | #427 |
67cheby
cant wait to see it , i am hopefully about 1 month away from doing this myself, all of my rear suspension is done already, so it will just be the main frame rails and the front suspension, anyway i am excited for you !!
11-09-2010, 08:10 PM | #428 |
And, poof . . .... It's all gone!
11-09-2010, 08:46 PM | #429 |
I'm just glad to be here!
Looks like it is all there. What about the front spindles and the rear end housing? What color are you going to use?
I forgot to ask, are you going to bolt the complete assembly back together and not have any welded/rivet'd cross members? Are you going to use grade 8 fasteners?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 11-09-2010 at 08:54 PM. Reason: added last 2 questions... |
11-09-2010, 08:48 PM | #430 |
1 thing at a time is progress.
Never seen one taken down that far. Very interesting.
Alan
Philippians 2:14-16 |
11-09-2010, 10:23 PM | #431 |
I guess the 'usual' is the front splash pan, shock x-member, & Panhard bar x-members remain in place even when stripped down for PC-ing.
Since I had to re-work each of the rear x-members & the front splash pan was in the way of some frame tweaks, everything had to come out. I thought about the re-assembly process & the 'pros/cons' of just using nuts/bolts or if welding would be necessary. I haven't decided one way or another but I'm always open to others experiences.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-09-2010 at 10:24 PM. |
11-10-2010, 01:38 AM | #432 |
60-66 Nut
Bolting it back together shouldn't be a problem. Of course I'm sure you would be using grade 8 hardware and squaring it up. You wouldn't want to be welding on it after powder coating anyway
11-10-2010, 01:55 AM | #433 | |
And yes, everything (and I mean everything) is MINIMUM GRADE-8 hardware.
11-10-2010, 02:15 AM | #434 | |
There's still more to do so there will be a 2nd PC load. The T/A x-member is yet to be finalized (always used 1pc driveshafts & Porter has got me convinced a 2pc is the better way to go this low). Once everthing is reassembled, I'll be able to finish up the trans x-member. After that, both will get coated along w/any other 'forgotten' items. The spindles, calipers, & a-arms will be epoxied.
11-10-2010, 11:24 AM | #435 |
Happy to be here
Houston, we have lift off...
11-10-2010, 12:39 PM | #436 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-11-2010, 01:59 AM | #437 |
11-11-2010, 10:11 PM | #438 |
Does that new dually tow that trailer good enough for ya?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
11-12-2010, 04:04 AM | #439 |
It works pretty darn good.
The current ride height is screwing w/my view when backing (I can't see the end of the trailer @ all) & it's a thirsty SoaB. But, since there's no payment, I'll live w/it until the LS swap. I just got home from the shop. It's been a long, but productive day .
11-12-2010, 05:34 AM | #440 |
there these backupcams out there mounted in the numberplatesuround , havent checked prices lately but they where reasonably priced i might be a solution to the backup problem if you can get it either to look underneat the trailer or between the trailer and the car on top of it
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
11-12-2010, 08:57 AM | #441 | |
Alot more lo-tec than a camera, but that's how I roll Here is a link to the driveway markers at Home Depot.. they are $2.29 a piece! http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 Last edited by lakeroadster; 11-12-2010 at 06:22 PM. |
11-12-2010, 11:24 AM | #442 | |
In the interim, we dropped the t-gate. I'm always nervous about that decision though.... Thanks for the suggestions guys!
11-12-2010, 11:29 AM | #443 |
Slots go on anything!
LS swap!!
The '64 is coming along great. How long until the parts are back?
1974 Jimmy- 5.3/4L80e/NP241 |
11-12-2010, 12:43 PM | #444 |
good idea those antenna's
11-12-2010, 09:17 PM | #445 |
Who said I'm still waiting
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-12-2010 at 09:17 PM. |
11-12-2010, 10:26 PM | #446 |
After the ls swap maybe some bags?
11-13-2010, 01:33 AM | #447 |
I'm doing the dually like my other 'tow-trucks' before it. Spindles & cut a coil up front w/flip kit & driveway built AOL set-up. Think budget.... I would love to do Ride Techs Air bar set-up but can't justify the coin for the amount of drop (if I could even find that amount of coin).
I've looked for suspension info on that HHR shop dually but have only found a few pics. Anybody know if any info on specifics are online?
11-13-2010, 10:23 AM | #448 |
67cheby
dont be STINGY with the PICS then.....come on just give us a little pic fix !!
11-13-2010, 11:31 AM | #449 |
I'll get some today. It's basically the same 'ole pics.... now w/a splash of color vs. bare metal (black is a color).
11-13-2010, 11:36 AM | #450 |
67cheby
"basically the same pics with a little color"........we dont care , that is like your girlfriend saying she doesnt want to undress in front of you ..cause she is feeling a little FAT..... WE DONT REALLY CAR WE JUST WANT TO SEE UM !!
