Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 11-12-2010, 06:50 PM   #1
sider68
sider68's Avatar
Scratch Marks In Windshield
How do you buff them out. Start out with rubbing compound? Never done it before,please help.
sider68 is offline   Reply With Quote
Old 11-12-2010, 09:26 PM   #2
70BLAZERX2
Re: Scratch Marks In Windshield
you can use "BONAMI" that you can get in most grocery stores..and make it a paste...Use a terry cloth make a paste..and buff it out,
If they are deeper scratches..Eastwood sells "Rhodite" that will really clean up the whole thing good.
70BLAZERX2 is offline   Reply With Quote
Old 11-13-2010, 09:06 AM   #3
cdowns
cdowns's Avatar
besst for deeper scratching and pitting is to replace windshield
alot of the home repairs leave visual distortion anduneven glass surface making wipers ineffective
Old 11-13-2010, 06:54 PM   #4
sider68
sider68's Avatar
Were you kidding about household cleanser? It looks like something off the wipers scratched it. a new windshield isnt an option i got one of those headlight cleaning kits. i wasnt sure on how agressive i could go without making matters worse
Old 11-13-2010, 07:53 PM   #5
70BLAZERX2
bonami is so fine..it will not scratch the glass,it will clean it...Then go over with glass cleaner..
The 1955 chevy's with a 265 V8 used oil ,bypassing the rings..when they were new..Chevy's fix was runs motor around 2,000 rpm...pour a teaspoon of bonami down the carb...3 times...And it would reseal the rings to stop it from burning oil...Yes good stuff..
worked on an old 76 ford 390 that smoked bad...I used quite a bit of it...fixed it..And the truck left here..don't use oil now..
Old 11-14-2010, 11:52 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
There are windshield buffing products out there. Most of them are a cream base and use a foam buffer. I have never tried it and when I looked at it, the cost of a new windshield was worth the effort vice using up all of my time. I found a lot of other things to do instead of trying to buff the windshield and then be POd at the finish on it, when the weather got cold and I had to use the wipers.
Frank
Old 11-15-2010, 07:56 AM   #7
cdowns
cdowns's Avatar
yep winshields are so readily available new and cheap makes no sence to spend time on something that can affect vision when needed most
Old 11-16-2010, 04:47 PM   #8
sider68
sider68's Avatar
is bon ami same as ajax or comet or dutch cleanser?
Old 11-19-2010, 12:15 PM   #9
stich626
x2 bonami on a wool buffing pad..
glass is like new
stich626 is offline   Reply With Quote
