Old 11-16-2010, 07:21 PM   #1
Mrtn15
Mrtn15's Avatar
Why is my motor bogging down?
I have a 1986 chevy silverado 305 or 350 motor with turbo350 tranny! And when I'm going about 65 down the highway and gas on it. It seems like it sputters or bogs down very fast and many times. And it makes my truck speed up slow down speed up slow down
Mrtn15 is offline   Reply With Quote
Old 11-16-2010, 09:14 PM   #2
hugger6933
Re: Why is my motor bogging down?
First check the state of tune plugs, wires, cap, rotor. then check for clogged fuel filter then check for fuel pressure if you have'nt found after all that try a known good carb, to rule out clogged jets or intermedite curcuits. Also put a vac gauge on it run it to duplicate the problem and watch the vac to see if it drops that would indicate a clog in your exhaust system. Jim
hugger6933 is offline   Reply With Quote
Old 11-16-2010, 09:23 PM   #3
77shortstep
77shortstep's Avatar
I would start with the fuel filter, then plugs cap and rotor which never hurts unless you have recently replaced them. Also if you know where a good reliable carb is it would be easy enough to switch and test.
77 CHEVY - SHORT BED STEP SIDE 2WD
02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT
77shortstep is offline   Reply With Quote
Old 11-17-2010, 09:19 AM   #4
rollinhard
rollinhard's Avatar
Poor some menthal hydrate in the tank. Might be water in the gas aswell. My 86 305 would bog and sputter and be screwy untill I poored some in then its was good after that. Its had sat for quite a while before I got it and the cat was rotted inside aswell cut that out and made big diff aswell. Couple suggestions to try also.
Curtis
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 11-17-2010, 09:58 AM   #5
willett
Another Day, Another Dollar
willett's Avatar
i agree with checking yout fuel filter fuel filter first, its cheap and easy to do.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-23-2010, 05:16 PM   #6
Mrtn15
Mrtn15's Avatar
Thanks to all of you! I will try them, I replaced cap and rotor this weekend
Old 11-23-2010, 05:19 PM   #7
RED-85-Z51
A failing EGR valve on a carbed engine can do weird things
RED-85-Z51 is offline   Reply With Quote
