Old 01-16-2011, 01:02 PM   #26
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: 1982 C10 swb "SS"
looking good, it seems like every one now days that does a ls swap doing a frame off
I would run the gm muscle car pan, that what I got its comes with every thing you need for the swap
http://www.summitracing.com/parts/NAL-19212593/
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-17-2011, 03:56 PM   #27
shenk10
shenk10's Avatar
Thanks for the help on the oil pan, I'll have to look into it. Well I got some more work done today. I got the pass side suspension together, drivers side needs a lower ball joint and one new u-bolt and then I'll finally be done with the front suspension. I was also able to order new engine mounts today, so hopefully next weekend I can get the driver's side suspension done as well as an engine sitting in its correct place. I also decided that I'm going to paint the engine so I am in the process of cleaning it up also.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 01-17-2011, 05:34 PM   #28
nbpro
awesome progress keep da pics comeing
nbpro is offline   Reply With Quote
Old 01-17-2011, 05:49 PM   #29
allengator
allengator's Avatar
great work! keep at it!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-17-2011, 06:19 PM   #30
silvereagle07
silvereagle07's Avatar
Looking good! It should be a fun truck with that engine.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-17-2011, 08:53 PM   #31
turbonewf
turbonewf's Avatar
I'm doing the same thing!!!
subscribed
turbonewf is offline   Reply With Quote
Old 01-21-2011, 10:05 AM   #32
shenk10
shenk10's Avatar
Sorry for the pictures being blurry. But my engine mounts and adapters came in this week so my goals this weekend are to get the front suspension completely back together, get the rear springs on, sandblast the rear, paint the engine, and hopefully mock up the engine although I'm thinking that it wont fit with the tbss oil pan. I should have more pictures up after this weekend.
Jordan
In progress....
Old 01-23-2011, 11:05 PM   #33
shenk10
shenk10's Avatar
Well I got some work done this weekend. I didn't get to the rear like I wanted to, but I got all the front suspension back together and sitting on the ground. I got the steering box cleaned up and put back on along with some steering parts. I just replaced the tie rods over the summer and both the inner tie rod "dust covers" had ripped so I guess I will need to replace them before getting the steering done. I also got the rear leaf springs cleaned up and painted and put on the truck. I got the adapter plates as well as new mounts on the truck. I also got the engine painted and ready to go. Also cleaned up and painted the exhaust manifolds. Just need to get a new oil pan and the engine should be able to go in the truck.
Jordan
In progress....
Old 01-23-2011, 11:06 PM   #34
shenk10
shenk10's Avatar
Jordan
In progress....
Old 01-31-2011, 02:26 PM   #35
shenk10
shenk10's Avatar
Well didn't get that much work done this weekend. I got the rear suspension put back together, for right now I'm going to stick with the 10 bolt. I think it might have 3.07 gears. I have a 12 bolt from a truck that I'm going to build to put in, so I didnt feel like cleaning or messing with the 10 bolt. I also got some engine parts painted. I decided to paint the accessories with header paint. I dont know whether I like it or not. You can see in the pictures but It's basically ceramic paint and is like a flat black. I also ordered a bunch of parts yesterday so this weekend should be really busy.
Jordan
In progress....
Old 01-31-2011, 05:21 PM   #36
inovermyhead
Best price I've found on the oil pan. I got mine from them in just a few days [url]http://www.gmpartsdirect.com/ part #19212593
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 01-31-2011, 05:30 PM   #37
kSStamp0182
LSX addict
kSStamp0182's Avatar
A heads up on the tailswap swap, the entire trans has to be taken apart to get to it. an you will need a speed sensor and reluctor gear. i did this to my 4L80E as it came from a 4x4 silverado.
it MAY be different on yours i dont know, but here is a good source of info on it http://www.ls1tech.com/forums/automa...-4x2-help.html
and http://www.transmissionpartsusa.com/ was the only place i found that sold the reluctor gear individually. just DO NOT buy your rebuild kit their. they screwed me on that. (sent the wrong one (a cheaper kit for the 91-96 trans) and wouldnt take the item back because i opened it. which i understand IF it were the right damn part.) and i ended up getting the kit locally for over $110 cheaper. but hope this helps!!
kSStamp0182 is offline   Reply With Quote
Old 02-01-2011, 05:04 PM   #38
shenk10
shenk10's Avatar
Thanks for the info, I just ordered the summit one though. Coulda saved 50 dollars though. Thanks though.
Jordan
In progress....
Old 02-01-2011, 05:09 PM   #39
shenk10
shenk10's Avatar
Thanks for the info. I still have not decide on anything with the transmission. I still can't decide whether I should sell it and buy a 2wd 4l80e or trade. I guess I would really like trading for a 4l70e 2wd but I don't think that will ever happen. I would eventually like to put l92 heads and ls3 intake on it so I think I might be better off just getting a 4l80e but the 4l70e is a sport package basically so it already has a shift kit in it. So I guess I'm still just looking for options and opinions.
Jordan
In progress....
Old 02-01-2011, 05:41 PM   #40
inovermyhead
Wish I would've come across your post sooner then. I found that one in a google search when I was searching for my pan. And try www.rockauto.com for other parts and search the net for dicount coupon codes too. I've saved tons on parts from those guys.
Old 02-01-2011, 06:20 PM   #41
shenk10
shenk10's Avatar
Thanks, I should have thought about that too, but I got most of my parts from rockauto so far, and they have the cheapest prices I've seen for many parts.
Jordan
In progress....
Old 02-02-2011, 02:10 PM   #42
breeze85cten
How many miles did your engine hav when you bought it? I did the same swap but I tore mine down to the block and cammed it and put arp bolts on mostly everything. I also ran the same pan as the one he recommended because the stock ones hang lower then the crossmember. Mine is also bagged so I had to go with the lower pan or else I would be hitting the pan layed out. Engine looks brand new! good job.
breeze85cten is offline   Reply With Quote
Old 02-03-2011, 03:15 AM   #43
bluex
bluex's Avatar
I do need help with a problem I have. One of my rear cab mount brackets has pretty much rusted through. I though I had remembered seeing them for sale in lmc, but it appears that they only have the front ones. Does anyone know where to get one of these or is a junkyard the only thing other than making one?
Do you still need this? I have one I can send you if you do....
bluex is offline   Reply With Quote
Old 02-03-2011, 10:03 AM   #44
shenk10
shenk10's Avatar
I was told there was 45,000 miles on the engine. I guess I can never be certain of that, but everything looked good on the inside. I was going to tear it down and put l92 heads, ls3 intake, and a cam in it, but I decided I wanted to get everything working and running before I decided to do that. It's funny, the oil pan off an awd is backwards of normal oil pans, I wonder where there crossmember is. The engine didn't start off that clean, because I think it sat outside for a little, but nothing a lot of cleaning can't fix lol
Jordan
In progress....
Old 02-03-2011, 10:04 AM   #45
shenk10
shenk10's Avatar
Yes that would be great. PM sent.
Jordan
In progress....
Old 02-12-2011, 11:53 AM   #46
shenk10
shenk10's Avatar
Well I got a little done last weekend, just haven't had time to get things posted. All my parts I ordered came in so it's just putting everything together. The engine doesnt mount right now though. I think with the swaptech kit they are asking to use different shells than I have so I still have to email them and ask about it.
Got an '87 gas tank, got painted and ready to bolt up
Power steering mocked up, not sure if it is going to clear the frame rail yet
Engine is about an inch off, I hope the different shells will make the difference
Back view, engine just hanging in place
Jordan
In progress....
Old 02-12-2011, 12:03 PM   #47
shenk10
shenk10's Avatar
Here is another picture that shows how much the engine is off
Jordan
In progress....
Old 03-04-2011, 04:36 PM   #48
shenk10
shenk10's Avatar
Well haven't made much progress lately, but did get a few things done. Big thanks to bluex for sending me the rear cab mount. I got it mounted and painted. Also got the brake lines ran and finished up as well as the gas tank and sending unit all in place. Still have to fix my engine mounting problem as well as get the transmission swapped from awd to 2wd. Batteries were dead in the camera today, but did take two crappy cellphone pics.
Jordan
In progress....
Old 03-04-2011, 05:06 PM   #49
mcboomport
mcboomport's Avatar
Looking good man! I love your approach on the build!
mcboomport is offline   Reply With Quote
Old 03-04-2011, 07:18 PM   #50
73gmc454
73gmc454's Avatar
Your makin great progress , Like it ,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
