01-26-2011, 12:22 PM | #1 |
73-87 a-arms to 67-72 truck
Has any one put a 73-87 stock a-arms to a 67-72 chevy truck? I have a 71 cross member on a 67 truck but wish to put 73-87 a-arms for suspension. will the stock springs work with this and the spindles? also is it difficult?
01-26-2011, 01:03 PM | #2 |
Happy to be here
Re: 73-87 a-arms to 67-72 truck
Many, many times. Please take a moment to read here and you will find the topic covered extensively...
01-26-2011, 01:04 PM | #3 |
67-72 parts collector,…
73-87 arms will bolt right on a 71 crossmember.
Stock springs will work also. The spindle will have to be a 73-87 spindle to match the a-arm's 73-87 ball joints. Also the 73-87 outer tie rod is different from the 71-72 tie rod.
01-26-2011, 01:05 PM | #4 |
Are you using the steering linkage from the '71 also?
01-26-2011, 01:10 PM | #5 |
was thinking of it. does that have to go to?
01-26-2011, 01:12 PM | #6 |
You need to use the 71 centerlink and inner tie rods.
If you have 71 spindles you can use the 71 outer tie rods. If you have 73-87 spindles, you need to use a 73-87 outer tie rod.
01-26-2011, 01:18 PM | #7 |
I do have the 71 spindles and center link. so they'll swap rite out, thats cool... the 73-87 upper ball joint will work w/ the 71 spindle?
01-26-2011, 01:24 PM | #8 | |
The upper needs to be changed to the 71-72 ball joint, to work with a 71 spindle. But, the 73-87 lower ball joint will work with your 71 spindle.
01-26-2011, 01:36 PM | #9 |
thank you for your imput... your very helpful
