Originally Posted by Bennett--G4L
David do you still have your original 67 rear in the truck. How is your track width between the front and the rear tires with the same backspacing? Do the fronts stick out.
Yep its the original. I thought the front looked wider so i measured and it's about 3 inches wider overall in the front. They won't stick outside of the fenders but I just need to see how it is once it's all together to figure out if I want to do anything about it. Does anyone know if the front was wider stock? I converted the front from drums to disc as a part of the ECE 4/6 drop and there was no mention of the spindles bringing them out.
